tvzzz
My hard drive is getting full. Is there a way to see all at once which folders are the largest? I know I can open the properties for each one, but I remember years ago before Windows there was a utility called "Keep Track" that showed all the folders and their sizes all at once. That would be very useful!
livix07
Honorable Member
There most likely are third party apps to do that. But have you run the Clean Disk utility to try to free some space?
Here is a way to search for folders and files by size without third party apps:
