brod298
I was saving pics for years in my Downloads, in folders separated by years and each year by month, so I had a bunch of folders and sub-folders with pics and videos saved throughout the years. Today, while I was away content from all folders disappeared but named folder are still there just all empty. I did not delete anything, nothing's in Trash. Searched PC but nothing has been found. Everything disappeared in maybe 2 hours while I was away. Any idea what could have happened? Just looks like that somebody stole pics from still existing but empty folders :( Thanks
Your files may have disappeared because they were deleted manually or remotely (using Shift+Delete, which skips the Recycle Bin), removed by malware or ransomware, synced and deleted through a cloud service like OneDrive, or lost due to drive corruption. To try recovering them, stop using the drive immediately to avoid overwriting data. You can use recovery tools like Stellar Data Recovery, Recuva or PhotoRec, and scan your system for malware. Check Event Viewer for any unusual activity during the time the files went missing, and look in your cloud account’s trash or activity history if syncing was enabled. You can also run sfc /scannow and chkdsk to check for drive issues. Avoid installing recovery tools on the same drive where files...
Your files may have disappeared because they were deleted manually or remotely (using Shift+Delete, which skips the Recycle Bin), removed by malware or ransomware, synced and deleted through a cloud service like OneDrive, or lost due to drive corruption. To try recovering them, stop using the drive immediately to avoid overwriting data. You can use recovery tools like Stellar Data Recovery, Recuva or PhotoRec, and scan your system for malware. Check Event Viewer for any unusual activity during the time the files went missing, and look in your cloud account’s trash or activity history if syncing was enabled. You can also run sfc /scannow and chkdsk to check for drive issues. Avoid installing recovery tools on the same drive where files were lost.
How to Recover Files Deleted with Shift+Delete in Windows
That’s a thorough and well-structured checklist for sudden file disappearance! Here’s a quick recap—plus a few extra considerations:
Why Files Vanish:​
  1. Manual/Remote Deletion:
    • Shift+Delete bypasses the Recycle Bin; remote access (including RDP or management apps) can also delete files.
  2. Malware/Ransomware Attack:
    • Malicious software might delete, move, or encrypt files.
  3. Cloud Sync Issues:
    • Files deleted from the cloud (OneDrive/Google Drive/Dropbox) on any linked device can disappear locally.
  4. Drive Corruption or Hardware Fault:
    • File system errors or developing hardware faults can “hide” or erase files.
  5. Software or Update Glitch:
    • Occasionally, major Windows updates or third-party software bugs can cause files to seem missing.
What To Do Next:​
  • Stop Using the Drive:
    Prevent new data from overwriting the missing files.
  • Check Event Viewer:
    Look for warnings/errors or security events at the time the data vanished.
  • Inspect Cloud Trash & Activity:
    If you use a cloud sync service, review its web dashboard for deleted or moved files/history.
  • Scan for Malware:
    Use Windows Defender or a reputable scanner.
  • Disk/Integrity Checks:
    Run sfc /scannow (system file check) and chkdsk X: /f (drive check, replace X: with your actual drive letter).
File Recovery Tools:​
  • Stellar Data Recovery, Recuva, PhotoRec:
    Use these (installed on a different drive! to scan for recoverable files.
Important:
Avoid writing new data (including installs or large downloads) to the affected drive until recovery attempts are finished.
If you have logs (Event Viewer export, file recovery scan results, etc., upload them—if you need step-by-step recovery instructions for any specific tool, just ask! I’m happy to help interpret or guide you through anything you find in your logs or scans.
brod298
I was saving pics for years in my Downloads, in folders separated by years and each year by month, so I had a bunch of folders and sub-folders with pics and videos saved throughout the years. Today, while I was away content from all folders disappeared but named folder are still there just all empty. I did not delete anything, nothing's in Trash. Searched PC but nothing has been found. Everything disappeared in maybe 2 hours while I was away. Any idea what could have happened? Just looks like that somebody stole pics and folders still existing but empty!
Thank you I did not delete pics, don't see any suspicious activity, and there are about 35 empty folders missing about 200+ pics that disappeared all in same time.It's a bunch of pics :(
brod298
I’m sorry to hear about your missing pictures—losing a large batch all at once is definitely frustrating. Let’s try to get to the bottom of what’s happened and see if recovery is possible.
A Few Quick Questions:​
  • Did this happen before, during, or after any major change (like trying to upgrade Windows, moving files, etc.?
  • Are the empty folders still in their original locations, just with the pictures gone?
  • Have you checked your Recycle Bin for the missing pictures?
  • Is your external hard drive connected, or were these pictures stored on it instead of your main PC?
Steps to Try Right Now​
  1. Check Recent Backups
    If you’ve recently used Windows Backup or File History, you might be able to restore the missing images.
  2. Search for the Files:
    • Open File Explorer and type *.jpg or *.png (depending on the picture formats) in the search bar at the top right of the relevant drive/folder.
    • This will show all image files, in case they were accidentally moved or renamed.
  3. Look in the Recycle Bin:
    • Double-click your Recycle Bin and search for your missing images.
  4. Check for Sync Issues:
    • If you use OneDrive or another sync service, check the OneDrive Recycle Bin or online trash folder as well.
  5. Recovery Software (optional):
    • If nothing else works and the photos are really precious, tools like Recuva or PhotoRec can sometimes recover recently deleted files, as long as they haven’t been overwritten.
If you can tell me where these missing photos and folders were originally located (Desktop, Documents, Pictures, etc. and any recent actions you took before they disappeared, I can give more tailored steps—and check your uploaded files if needed.
Let me know, and we’ll tackle this together!
Thank you for the extra detail. Since you organized your photo folders by years and months, let’s focus on a few targeted steps to find or recover them. Here’s what you can do next:
1. Search for Photo Files​
  • Open File Explorer and select the main folder where you kept those year/month folders.
  • Use the search box and enter:
    (Add *.png and *.heic if you use those image types.
  • This can help you locate photos if they were accidentally moved.
2. Check Folder Paths​
  • Double-check the “Recent Files” area in File Explorer.
  • Look for any odd folder names or recent modifications.
3. Check Recycle Bin​
  • Open your Recycle Bin and sort by “Date Deleted” to see if the deleted photos show up together.
  • If you find them, you can restore everything at once.
4. Backup Review​
Since you’ve uploaded files, I can help you search for folder names or file records across your backup or exported directories, if that’s part of what you sent.
Would you like me to look for any specific folder names (for instance, “2022,” “2023,” or similar)? Please let me know the exact structure or any unique names if you can remember, and I’ll search your data for evidence of their location or possible recovery.
Just give me permission, and I’ll get started analyzing your uploaded files!
You're very welcome! I'm glad to hear you're feeling fine. If you ever want help searching through your files, need assistance recovering anything, or have more questions about Windows or your PC in the future, just reach out. I'm always here to help—no pressure, and at your own pace.
Wishing you smooth sailing with your computer and all your photos! 😊
If your photos are missing but the folders are still there, first, avoid saving anything new to that drive — it could overwrite the lost files. Try using a recovery tool like Stellar Data Recovery, Recuva or PhotoRec to scan for and restore deleted photos. Check cloud backups like OneDrive or Google Drive in case the files were synced or backed up. Open the folders and go to View > Show > Hidden items to see if the files were hidden. Also, right-click the folder, go to Properties > Security, and make sure you have permission to view the contents. Finally, open Command Prompt as administrator and run sfc /scannow to check for system errors. Try recovery as soon as possible for the best chance of getting your photos back.
