Daryl Wong
Hello,
I've encountered numerous crashes while gaming, watching videos and just plain web-surfing. Tried updating all my hardware drivers, uninstalling Avast Internet Security and the problem still persists and I hope someone in this forum could help me with this problem. I have more than 30 crash dump files but I'll only upload a few because it seems to be the same cause. If you need further information regarding my system please ask me.
[PC Specs]
Windows 7 Pro 64 bit
AMD A8-3850 APU with Radeon Graphics 2.90 Ghz
8.00 GB RAM
Secondary display driver AMD Radeon HD 6670 1GB
1TB Samsung HD103SJ hard drive and 1TB WDC WD10EARS-00MVWB0 hard drive
Thank you in advance for helping me solve this issue, dump file is attached below.
Please provide this information for a more complete analysis: Link Removed
AMD OverDrive (AODDriver2.sys) is either a stand-alone application, or a component of the AMD VISION Engine Control Center. This driver is known to cause BSOD's on some Win7 systems.
Please un-install all AMD/ATI video stuff from Control Panel...Programs...Un-install a program
Then, download (but DO NOT install) a fresh copy of the ATI drivers from Link Removed - Invalid URL (in the upper right corner of the page)
Use this procedure to install the DRIVER ONLY: Link Removed
If the device (AODDriver or AODDriver4.01) remains a problem, open Device Manager, select the "View" item.
Then select "Show hidden devices" and scroll down to...
Then select "Show hidden devices" and scroll down to the Non-Plug and Play Drivers section.
Locate the AODDriver entry, right click on it and select "Uninstall". Reboot for changes to take affect.
Sometimes the driver remains and continues to cause BSOD's. If this is the case for you, post back and we'll give further instructions for safely removing it.
If overclocking, please stop. Remove the overclock and return the system to stock/standard values while we're troubleshooting. Once the system is stable again, feel free to resume the overclocking.
Please uninstall AppleCharger (Gigabyte On/Off) as it is known to cause BSOD's on some Win7 systems. Once the system is stabilized, feel free to install a fresh copy and see if it works w/o BSOD's.
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Win7 systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] Link Removed [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): Link Removed
Alternate link: Disc-Tools.com
Manual procedure here: Link Removed - Invalid URL
If you have a wireless USB XBox controller, please uninstall it's software and remove the device from the system. They are known to cause BSOD's on some Win7 systems - and there are no driver updates available.
If these steps don't fix the problem with BSOD's, then please start with these free hardware diagnostics: Link Removed - Invalid URL
Analysis:
[font=lucida console]**************************Sat Sep 15 14:40:37.311 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091612-21715-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]1 days 9:23:45.950[/B]
BugCheck Code: [B]BugCheck 124, {0, fffffa8008228028, b2004000, a7000175}[/B]
Probably caused by :[B]AuthenticAMD[/B]
BugCheck Info: [B]WHEA_UNCORRECTABLE_ERROR (124)[/B]
BUGCHECK_STR:  0x124_AuthenticAMD
PROCESS_NAME: [B]chrome.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x124_AuthenticAMD__UNKNOWN[/B]
  BIOS Version                  F4
  BIOS Release Date             09/21/2011
  Manufacturer                  Gigabyte Technology Co., Ltd.
  Product Name                  GA-A55M-DS2
**************************Fri Sep 14 05:17:00.253 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091412-19812-01.dmp]
System Uptime:[B]0 days 0:00:08.892[/B]
BugCheck Code: [B]BugCheck 124, {0, fffffa80081fe038, 0, 0}[/B]
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0x124_AuthenticAMD__UNKNOWN_PRV[/B]
**************************Mon Sep 10 03:06:51.192 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091012-18938-01.dmp]
System Uptime:[B]0 days 4:43:17.831[/B]
BugCheck Code: [B]BugCheck 124, {0, fffffa8008135028, b236c000, 175}[/B]
PROCESS_NAME: [B]audiodg.exe[/B]
  BIOS Version                  F4
**************************Fri Sep  7 00:51:45.107 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090712-22214-01.dmp]
System Uptime:[B]0 days 0:08:27.746[/B]
BugCheck Code: [B]BugCheck 124, {0, fffffa8008245028, b6344000, 175}[/B]
PROCESS_NAME: [B]AvastSvc.exe[/B]
  BIOS Version                  F4
[/font]
3rd Party Drivers:
GEARAspiWDM.sys             Mon May 18 08:17:04 2009 (4A1151C0)
aswNdis.sys                 Sat Jan  9 16:22:03 2010 (4B48F37B)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
amdide64.sys                Tue Mar 30 10:48:25 2010 (4BB20F39)
usbfilter.sys               Wed Dec 15 05:34:49 2010 (4D0899C9)
RimSerial_AMD64.sys         Wed Jul  6 19:20:01 2011 (4E14EDA1)
L1C62x64.sys                Wed Aug  3 02:21:09 2011 (4E38E8D5)
[COLOR=RED][B]AppleCharger.sys            Tue Nov  1 22:46:00 2011 (4EB0AEE8)[/B][/COLOR]
viahduaa.sys                Fri Nov  4 05:52:46 2011 (4EB3B5EE)
[COLOR=RED][B]dtsoftbus01.sys             Fri Jan 13 08:45:46 2012 (4F10358A)[/B][/COLOR]
[COLOR=RED][B]AODDriver2.sys              Tue Mar  6 04:55:00 2012 (4F55DEF4)[/B][/COLOR]
aswFsBlk.SYS                Tue Mar  6 19:01:31 2012 (4F56A55B)
aswMonFlt.sys               Tue Mar  6 19:01:51 2012 (4F56A56F)
aswTdi.SYS                  Tue Mar  6 19:01:56 2012 (4F56A574)
aswrdr2.sys                 Tue Mar  6 19:02:19 2012 (4F56A58B)
aswKbd.SYS                  Tue Mar  6 19:02:44 2012 (4F56A5A4)
aswNdis2.sys                Tue Mar  6 19:03:28 2012 (4F56A5D0)
aswSP.SYS                   Tue Mar  6 19:04:03 2012 (4F56A5F3)
aswSnx.SYS                  Tue Mar  6 19:04:05 2012 (4F56A5F5)
aswFW.SYS                   Tue Mar  6 19:04:29 2012 (4F56A60D)
AtihdW76.sys                Fri May 11 04:25:40 2012 (4FACCD04)
atikmpag.sys                Fri Jul 27 21:14:47 2012 (50133D07)
atikmdag.sys                Fri Jul 27 21:48:09 2012 (501344D9)
[/font]
Thanks for the reply John, your efforts are very much appreciated.
Okay, I'm having problems using the SF diagnostics tool that you've advised me to use. The only option that works is 'System Information' and the rest all had errors in running them. The error message was there is an unhandled exception and the files etc. couldn't be found. These errors were shown when I clicked on drivers list, MSinfo 32, HOSTS, Minidump and etc. (Tried the "Take Ownership" method to no avail, many of my system files such as 'AppData' and 'Minidump' can't be fully owned using that method but it works on some other files though.) So I went ahead and uninstalled all AMD files and the DAEMON tools as instructed and now I'm going to reboot and see what happens. No BSOD's in the past hour or so when I was streaming a video which crashed 3 times consecutively in the past hour before.
Try this method for the MSINFO32 report:
MSINFO32:
Please go to Start and type in "msinfo32.exe" (without the quotes) and press Enter
Save the report as an .nfo file, then zip up the .nfo file and upload/attach the .zip file with your next post.
Also, save a copy as a .txt file and include it also (it's much more difficult to read, but we have greater success in getting the info from it).
If you're having difficulties with the format, please open an elevated (Run as administrator) Command Prompt and type "msinfo32 /nfo C:\Users\Public\Desktop\TEST.NFO" (without the quotes) and press Enter. Then navigate to the C:\Users\Public\Desktop directory to retrieve the TEST.NFO file. If you have difficulties with making this work, please post back.
Currently my system is running pretty smoothly after re-installation of AMD drivers but I will post back if anything or nothing happens. Attached both the files you've asked for below.
Thanks a bunch!:D
[Update]
Just encountered a BSOD after watching a video in full screen on a website and great, it's not solved..:zoned:
Please zip up and upload the most recent memory dumps (if in doubt, just zip them all up and I'll sort them). They're located in C:\Windows\Minidump
You have this problem device:
Not Available PCI\VEN_1022&DEV_780B&SUBSYS_43851458&REV_13\3&18D45AA6&0&A0 The drivers for this device are not installed.
The MSINFO32 report shows that you have the ATI Hydravision and the ATI Vision Engine Control Center stuff installed - which shouldn't have happened if you'd followed my suggestion about the driver installation. Did you follow my suggestion from my first post (about the DRIVER ONLY installation)?
Gigabyte EasySaver and EasyTune6 (ET6) are known to cause BSOD's on some Win7 systems. Please un-install them immediately.
What device is that exactly? I've uninstalled the drivers and installed it back using the AMD Catalyst program. I'm going to redo the install again as I made a mistake with the driver only installation process. There's a problem uninstalling EasyTune6, nothing came up as I tried to uninstalling via control panel. Will try again later.
I've done a drivers only installation and I've attached my new MSINFO32 files. I still have trouble uninstalling the Gigabyte stuff and the EasyTune and I think the application is not working properly anyways. What do you suggest I do? One more question, without the AMD Catalyst Manager, how am I going to enable dual-graphics? Any clues?
The device is either an SMBus controller or an ATI PCIe (3GIO) Filter Driver (I suspect it's the latter).
I've reviewed the memory dumps and there's still traces of the programs that I asked you to remove. I suspect that these memory dumps are from before you got around to removing them - so I suggest we wait and see if there's any more. If there are, zip them up and upload them with your next post.
In short, we're still at the stage where we're ruling out 3rd party drivers. If we rule out the third party drivers and the system still BSOD's, then we'll have to start hardware diagnostics.
As for the dual-graphics, I'm afraid that I'm not well versed in that. I'd have to suggest that you discuss it in the Graphics forums here AFTER we've stopped the BSOD's: Link Removed due to 404 Error
Okay, I had a crash last night after all the fresh install of the AMD drivers and this time the BSOD has stated that the program "fltmanager.exe" is the cause of it. So now it seems its a heating issue? I've attached a dump file of that particular BSOD. Thanks for all the advice that you've given me, so what am I supposed to do now? I removed DAEMON and corrected the STPD driver, uninstalled AOD drivers. The only one I couldn't get rid of is EasyTune 6, how can remove it cleanly without an uninstaller?
EasyTune6 isn't present in the dump files - but Daemon Tools and it's sptd.sys driver is.
Please:
Analysis:
[FONT=lucida console]**************************Sun Sep 16 16:46:32.247 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091712-25100-01.dmp]
System Uptime:[B]0 days 2:15:06.886[/B]
BugCheck Code: [B]BugCheck 3B, {c0000005, fffff88000c0411a, fffff8800cf22f30, 0}[/B]
Probably caused by :[B]fltmgr.sys ( fltmgr!FltpPerformPostCallbacks+1fa )[/B]
BugCheck Info: [B]SYSTEM_SERVICE_EXCEPTION (3b)[/B]
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]X64_0x3B_fltmgr!FltpPerformPostCallbacks+1fa[/B]
  BIOS Version                  F4
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]dtsoftbus01.sys             Fri Jan 13 08:45:46 2012 (4F10358A) - DAEMON TOOLS[/B][/COLOR]
AtihdW76.sys                Thu Feb 23 07:30:12 2012 (4F463154)
[COLOR=RED][B]sptd.sys                    Sat Aug 18 17:05:38 2012 (503003A2)[/B][/COLOR][/FONT][FONT=lucida console][COLOR=RED][B] - DAEMON TOOLS[/B][/COLOR][/FONT][FONT=lucida console][COLOR=RED][/COLOR]
[/FONT]
Oh, I reckoned that you asked me to re-install DAEMON not permanently removing it. I've uninstalled both DAEMON and the STPD file that comes with it. So what next?
We wait....
If the BSOD's don't come back - it's fixed.
If they do come back, then we look at the memory dumps to see if any other 3rd party drivers show up.
If they do, you remove/update them and we wait some more.
If they don't, then it's fixed.
If we haven't fixed it by then, there will come a time when there's no more 3rd party drivers to blame.
That's when we start with the hardware diagnostics. You can get a head start by running the free tests here: Link Removed - Invalid URL These tests will catch the most easily diagnosed problems, but won't necessarily catch all problems - so there's another procedure after that (but hold off until we know if the 3rd party drivers are to blame): Link Removed
Somewhere in all of this is also a period where we reinstall Windows to rule it out as a possible cause - so be prepared for that (but don't do it until we've discussed it and have tried other Windows fixing tools).
Okay, just had a crash after I streamed a video online. Now it only happens when I stream videos from particular websites. Fingers crossed that I do not need to re-install windows..
AMD OverDrive is back - please remove it permanently:
Locate the AODDriver entry, right click on it and select "Un-install". Reboot for changes to take affect.
Please update this older driver. Links are included to assist in looking up the source of the driver. If unable to find an update, please remove (un-install) the program responsible for that driver. DO NOT manually delete/rename the driver as it may make the system unbootable! :
MTiCtwl.sys Tue Nov 4 02:40:50 2008 (490FFC82)
MagicTunePremium or PortTalk Driver by Samsung Electronics, Inc or Beyond Logic
Analysis:
[FONT=lucida console]**************************Wed Sep 19 04:28:27.529 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091912-22292-01.dmp]
System Uptime:[B]0 days 0:38:38.183[/B]
BugCheck Code: [B]BugCheck 124, {0, fffffa8008419028, b2004000, a7000175}[/B]
  BIOS Version                  F4
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]MTiCtwl.sys                 Tue Nov  4 02:40:50 2008 (490FFC82)[/B][/COLOR]
[/FONT]
