San10
Hey,
I would like to know if I can upgrade my computer from 32 bit to 64 bit.
Sorry my system is in french :
Thank you and have a nice day!
You could clean install windows 10 x64 no problem. Download the media creation tool and use it to select x64 10 and create a usb install media.
nmsuk
You could clean install a 64 bit version. I wouldn't bother though as you only have 4gb of RAM and you have a relatively low experience score.
San10
Thanks for the reply,
Yeah, my PC is pretty old, I just thought I needed to upgrade is sins a lot of the new programs don't support 32 bits anymore.
I don't have that much knowledge to decide by myself, do you think I can do it or should I just give up as you said.
Oh, and do you think I can install windows 10 if I upgrade my PC to 64 bits? because I tried to upgrade my PC in this current version (32 bit) and it said that it doesn't support it, I hope that make sense... ha-ha
Thank you
nmsuk
San10
Hey, thanks for the reply
I am downloading windows 10 into my usb right now, I am pretty sure it remove all of the files and programs, but can you confirm that for me ?
And do you think that my PC is able to install windows 10 ? because I have tried it before using the "upgrade this PC now" option in the media creation tool and it didn't work
Thank you.
San10
Thanks for cofirming that,
And about my second question, do you think that my PC is able to install windows 10 ? because I have tried it before using the "upgrade this PC now" option in the media creation tool and it didn't work.
Thank you
San10
Okay, I will install it.
Thanks for the help and have a nice day !
