Frontier AI Infrastructure Goes Open: Power, Cooling, Networking
Microsoft’s newest push at the OCP Global Summit marks a deliberate pivot from proprietary scale to open, standardized frontier-scale AI infrastructure—a campaign built around power stabilization, liquid cooling at rack and facility scale, unified networking for scale-up fabrics, hardened silicon roots of trust, and fleet-level operational resiliency that aims to make hyperscale AI datacenters more interoperable, secure, and sustainable.
A blue-toned data center corridor with open standards server racks and a telemetry station.Background​
Over the last twelve months Microsoft says it has expanded cloud capacity by more than 2 gigawatts and rolled out what it describes as the world’s most powerful AI datacenter, capable of delivering roughly 10× the performance of the world’s fastest supercomputer today—a claim Microsoft has repeated in official blog and investor communications and that has been widely reported in the trade press. That expansion is both cause and effect of a broader industry moment: AI training jobs have scaled from dozens to tens of thousands of GPUs, producing new engineering constraints across power delivery, cooling, networking, security, and lifecycle operations. Microsoft’s public OCP contributions and research outputs are an explicit attempt to convert in-house, hyperscaler-only advances into open specifications that the wider ecosystem can adopt.
Overview: Why “frontier-scale” changes infrastructure design​
The architectural thesis​
Frontier-scale AI—training or inference at the limits of compute—changes the systems equation. Where cloud-scale design historically optimized for multi-tenant variability and moderate rack densities, frontier-scale systems optimize for extreme, predictable throughput across many thousands of tightly coupled accelerators. That drives an emphasis on:
  • Power density and predictability rather than just aggregate kilowatt-hours.
  • Thermal transport at rack and on-chip levels rather than incremental fan upgrades.
  • Low-latency, lossless interconnects that preserve gradient synchronization performance.
  • Hardware-rooted security and fleet management to maintain trust at scale.
  • Standards-first engineering to avoid bespoke vendor silos that block interoperability.
Microsoft’s public roadmap to OCP maps to each of these needs, proposing open contributions and workgroups to speed adoption.
Power: solid-state transformers and power stabilization​
The challenge: variable, intense load patterns​
Large synchronous training jobs create cyclical and high-amplitude power swings: compute-heavy iterations draw orders of magnitude more instantaneous power than communication phases. Those swings can lead to:
  • Grid strain and interaction with utility harmonics.
  • Overprovisioning of facility infrastructure and inefficient capacity planning.
  • Increased failure risk for PDUs, distribution transformers, and server power electronics.
Microsoft, OpenAI, and NVIDIA collaborated on a cross-company paper that documents these dynamics with production telemetry and proposes a multi-layered mitigation approach spanning firmware, rack hardware, predictive telemetry, and facility controls. The research claims that coordinated full-stack measures can reduce power overshoot by about 40% in tested conditions.
Solid-state transformers and Mt. Diablo​
Following last year’s Mt. Diablo disaggregated power architecture co-developed with Meta and Google, Microsoft is advancing solid-state transformers (SSTs) as a way to simplify conversion stages and provide fine-grained protection and conversion features that are compatible with future rack voltage topologies. SSTs offer:
  • Faster control and isolation than legacy distribution transformers.
  • Programmable protection and dynamic reconfiguration.
  • Potential compatibility with higher-rack-voltage strategies to reduce I^2R distribution losses.
SSTs are not a silver bullet—they bring new component supply chains, control firmware complexity, and failure-mode profiles that operators must manage. Microsoft is launching a formal power stabilization workgroup at OCP to share learnings and standardize approaches for training-cluster power management.
What to watch: verification and grid impact​
The academic and engineering community should treat the 40% overshoot reduction as an exciting but bounded result: it is based on the paper’s experiments and Microsoft’s simulator work. Independent replication across different utility topologies and hardware stacks will be essential before operators can rely on those numbers for planning. The paper and Microsoft’s commitments are a strong step toward community engineering, but they are not yet a universal, field-validated specification.
Cooling: HXU liquid cooling, facility water loops, and on-chip innovations​
Liquid cooling to the rescue of dense racks​
High-density GPU racks push air cooling to its limits. Microsoft’s OCP contribution centers on a next-generation Heat Exchanger Unit (HXU) that enables rack-level liquid cooling to be deployed within existing air-cooled datacenter footprints without modifying buildings. Microsoft asserts the HXU delivers 2× the performance of current models while maintaining >99.9% cooling service availability for AI workloads—claims that position HXU as a practical scaling lever for operators that can’t build new immersion or full liquid facilities. Key attributes Microsoft highlights:
  • Modular design for fast roll-out.
  • Closed-loop water flows from server to chiller at facility scale.
  • Compatibility with retrofit deployments to accelerate AI capacity growth.
On-chip and two-phase cooling research​
Beyond rack-level HXUs, Microsoft signals interest in microfluidics and on-chip cooling techniques—where coolant transfers heat directly at the silicon level. This is consistent with academic research showing substantial heat removal capability from microchannels and two-phase designs, which can support very high heat fluxes needed by future AI accelerators. Such approaches require co-design of package, board, and facility plumbing, and create new test and manufacturing demands.
Risks and operational notes​
Liquid cooling and HXU retrofit strategies reduce immediate capital churn for datacenter owners, but they raise new operational considerations:
  • Plumbing reliability and leak containment.
  • Water chemistry and long-term materials compatibility.
  • Maintenance lifecycles for HXUs and spare-part logistics at scale.
The claims around 99.9% availability are technically precise but must be validated in real-world fleet operations over multiple seasons and failure modes.
Networking: ESUN, UALink, and the push for Ethernet scale-up​
The scale-up problem​
For frontier-scale training, thousands of GPUs must operate like a single, coherent system. That requires networking that is:
  • Low-latency enough to preserve synchronous training efficiency.
  • High-bandwidth and capable of multi-hop lossless behavior.
  • Interoperable across vendors to prevent a single-supplier lock-in.
Microsoft is participating in OCP workstreams—most prominently Ethernet for Scale-Up Networking (ESUN)—to adapt Ethernet for the scale-up domain and to align with Ultra Accelerator Link (UALink) and other industry consortia. ESUN’s charter focuses on L2/L3 framing, lossless multi-hop behavior, and interoperability testing.
Why Ethernet (again)?​
The rationale for adapting Ethernet for scale-up connectivity is pragmatic: Ethernet has a massive commodity ecosystem, economies of scale for optics and switch silicon, and broad vendor support. ESUN seeks to tighten Ethernet behavior into the low-jitter, deterministic performance envelope required for scale-up fabrics without forcing proprietary bypasses.
Practical considerations​
  • Adoption will require silicon vendors, switch OSes, NIC vendors, and operators to implement and test new framing and flow-control semantics.
  • Multi-vendor interoperability testing and certification will be central to avoid partial ecosystems that interoperate poorly under load.
  • The ESUN workstream’s early membership spans cloud operators and major vendors—a positive sign for early alignment.
Security and trust: Caliptra, Adams Bridge, and L.O.C.K.​
Re-centering hardware roots of trust​
Microsoft’s open-source Caliptra project is evolving into a broader Caliptra 2.1 subsystem that provides a hardware root-of-trust for datacenter SoCs. The Caliptra project is now an ecosystem-level specification under CHIPS Alliance/OCP and aims to provide a transparent, auditable root-of-trust for firmware signing, attestation, secure boot, and key management.
Post-quantum readiness: Adams Bridge 2.0​
To future-proof cryptographic primitives, Microsoft has integrated Adams Bridge, a hardware accelerator for NIST-selected post-quantum algorithms (e.g., Dilithium, Kyber), into the Caliptra subsystem. Adams Bridge accelerates post-quantum key operations and has been open-sourced to accelerate industry adoption. Microsoft’s public messaging indicates Adams Bridge RTL and Caliptra integrations have been staged for community review.
Key management: OCP L.O.C.K.​
L.O.C.K. (Layered Open-source Cryptographic Key Management) is an OCP contribution that specifies a layered key management block for storage media to secure media encryption keys in hardware. L.O.C.K. builds on Caliptra’s foundation and is being advanced by multiple vendors, including Google, Samsung, and Kioxia, as a standardized approach for secure provisioning, decommissioning, and multi-party authorization for drive keys.
Analysis: strengths and caution​
Microsoft’s approach—open-source hardware roots of trust plus integrated PQC acceleration and key-management blocks—addresses systemic issues in cloud trust. However:
  • Open-sourcing RTL and specs reduces black-box risk but still requires broad silicon and OEM adoption to be effective.
  • Post-quantum accelerators help future-proof cryptography, but standardized transition paths, FIPS/NIST validation timelines, and long-term key-rotation strategies remain operationally complex.
Overall, Caliptra + Adams Bridge + L.O.C.K. represent meaningful progress toward hardware-backed trust anchored in open specifications.
Sustainability: lifecycle accounting, waste heat reuse, and product-category rules​
From watts to embodied carbon​
Microsoft is leaning into standardized carbon accounting via OCP’s Sustainability workgroup. The company is one of several hyperscalers funding a Product Category Rule initiative to harmonize carbon footprint measurement for datacenter equipment, and it joined a cross-industry effort to establish an Embodied Carbon Disclosure Base Specification for equipment-level reporting. Those moves aim to reduce duplication, align supplier-buyer reporting, and create a comparable framework for embodied carbon across hardware lifecycles.
Waste heat reuse (WHR)​
Microsoft is actively publishing reference designs and developing economic modeling tools for waste heat reuse, with collaborators including NetZero Innovation Hub and NREL. The goal is to create region-specific models that quantify the cost and revenue dynamics of reusing datacenter waste heat for district heating or industrial processes—an important lever in regions where heat reuse regulation is tightening.
LCA methodology at fleet scale​
The company also states it has developed an open Life Cycle Assessment (LCA) methodology to evaluate fleet-level hardware impacts—an important step when device manufacturing, shipping, and end-of-life dominate the carbon profile for compute-heavy infrastructures.
Critical perspective​
Standardization of carbon measurement is urgent and welcome, but practical adoption will hinge on supplier participation, validated measurement methods, and third-party auditability. Product Category Rules and embodied carbon specifications help, but they are only a first step toward enforceable procurement requirements that will change supply chain behavior over time.
Fleet operational resiliency: unified firmware and manageability interfaces​
The problem at hyperscale​
Managing millions of heterogeneous nodes (CPUs, GPUs, DPUs, NICs, SSDs) requires consistent lifecycle tools for provisioning, firmware updates, RAS diagnostics, and debugging. Disparate interfaces create migration friction, long maintenance windows, and reliability blind spots.
Microsoft’s OCP contributions​
In collaboration with AMD, Arm, Google, Intel, Meta, and NVIDIA, Microsoft is contributing specifications and reference implementations that standardize:
  • Firmware management and secure update flows.
  • Manageability interfaces and telemetry models.
  • Diagnostics and RAS practices tailored to large AI fleets.
These contributions are designed to reduce operational variance across hardware generations and provide tooling that aligns OEM and hyperscaler expectations.
Why this matters​
Standardized fleet management reduces mean time to repair, simplifies cross-vendor maintenance, and makes it feasible to run larger, more diverse fleets without exponential operational overhead. The challenge will be in achieving vendor buy‑in and backward compatibility across existing deployed fleets.
Critical analysis: strengths, ecosystem opportunities, and risks​
Strengths​
  • Open standards approach lowers the bar for adoption and encourages multi-vendor ecosystems, reducing single-supplier risk for hyperscalers and enterprises. Microsoft’s OCP contributions (power, HXU, Caliptra, L.O.C.K., ESUN) align with this philosophy.
  • Full-stack thinking (from silicon to facility) acknowledges that training-scale AI performance is a cross-layer problem; the Power Stabilization paper exemplifies this systems-level approach.
  • Sustainability and lifecycle focus signal a shift from short-term capacity buildouts to longer-term environmental accountability—especially important as regulatory scrutiny of datacenter emissions and waste heat reuse increases.
Risks and unanswered questions​
  • Marketing vs. metric clarity: Statements like “10× the performance of the world’s fastest supercomputer” are useful for headline impact but hinge entirely on workload type, precision format (FP4, FP16, BFLOAT, FP32), and which supercomputer is used as the baseline. Independent benchmarking and transparent metrics (e.g., training time on a public model with explicit throughput/precision) are necessary to validate such claims. Trade coverage and Microsoft’s own materials document the claim, but the exact comparison metric requires careful scrutiny.
  • Grid and community impact: Massive new facilities and concentrated power draws risk creating local grid constraints. While Microsoft’s power stabilization work and closed-loop facility designs aim to mitigate this, the interplay with utility planning, permitting, and local acceptance remains a material deployment risk—particularly in regions with constrained capacity.
  • Operational complexity: Retrofits (HXU) and platform transitions (SSTs, new voltage rails) introduce operational complexity and spare-part requirements. Field reliability across many datacenters will reveal the true cost-benefit balance.
  • Standardization fragmentation: Multiple competing workstreams (ESUN, UALink, SUE-T, proprietary vendor interconnects) could fragment adoption. ESUN’s success depends on coordinated, multi-vendor test suites and a strong interoperability echo from silicon and switch vendors.
  • Security adoption lag: While Caliptra and Adams Bridge are important, widespread adoption requires silicon OEMs and OEM server manufacturers to integrate and ship devices with these roots-of-trust. The time-to-adoption and validation pathways (FIPS/NIST-like certifications) will determine how quickly fleets can rely on these primitives.
Practical takeaways for datacenter operators and architects​
  • Prioritize power-profile telemetry: begin capturing fine-grained power-phase telemetry from large GPU jobs to feed predictive control models and plan for overshoot mitigation.
  • Evaluate HXU and closed-loop liquid cooling for retrofit paths where new facilities are infeasible; run pilot deployments to validate availability claims under production workloads.
  • Follow ESUN and participate in interoperability labs if scale-up fabrics are part of your roadmap; early engagement reduces future lock-in risk.
  • Build a roadmap for hardware-rooted security adoption, including supplier engagements to understand timelines for Caliptra/Adams Bridge support.
  • Insist on transparent carbon and LCA reporting in procurement contracts; product-category rules and embodied-carbon specifications are maturing and will become procurement differentiators.
Microsoft’s OCP-era playbook for frontier AI is a comprehensive attempt to move critical hyperscaler innovations into public standards: from power stabilization and solid-state transformers, to HXU liquid cooling, ESUN for Ethernet scale-up networking, and open hardware roots of trust like Caliptra and Adams Bridge. These efforts are notable because they combine research, product engineering, and standards advocacy—an approach that, if it achieves broad vendor adoption, could materially reduce friction for organizations that need to run frontier-scale AI.
At the same time, many of the most consequential claims—large power-overshoot mitigation percentages, 10× performance comparisons, and >99.9% availability for retrofit HXUs—should be treated as provisional until validated in diverse, real-world fleet operations. The engineering community should welcome Microsoft’s openness while pressing for independent testing, reproducible benchmarks, and rigorous lifecycle accounting.
If these contributions hold up under multi-vendor validation and real-world operations, the net result will be an ecosystem better equipped to deliver high-performance, secure, and more sustainable AI infrastructure at global scale—and a clear migration path away from bespoke, closed stacks toward interoperable, standards-driven frontier computing.
Source: Microsoft Azure Accelerating open-source infrastructure development for frontier AI at scale | Microsoft Azure Blog
