Windows Vista Generic usb devices not automatically installed
heyseus
Hi I'm having a weird sort of problem. Whenever I plug in a USB device like a mouse or USB flash drive, Windows Vista claims that it cannot find drivers for it!! I have to specify to look in the c:\windows\system32 folder (inc. sub dir) to find the Windows drivers and it will eventually install. I know Windows XP did not prompt me to look for the drivers manually for these devices, it just installed it automatically. Like it automatically looked in the system32 folder for the drivers and installed them right away. Is this the new trend for Vista now?? I am logged in as a user with administrative rights would it need to run as administrator to work? Or is there a way to tell Vista to look in the windows\system32 folder automatically to search for USB devices? I just it's a nuissance to keep manually installing usb drivers that XP was able to install without user intervention. Any suggestions would be greatly appreciated.
It sounds like you are encountering driver installation issues for USB devices on Windows Vista. Windows Vista, like XP, is designed to automatically install drivers for recognized devices. However, in some cases, it may not do so automatically, requiring manual intervention. Here are some suggestions to resolve your issue with USB driver installations on Windows Vista:
Check Windows Update:​
  • Sometimes, Windows Update can offer drivers for various devices. Make sure your system is up to date by checking for Windows Updates.
    Update Device Drivers:​
  • Check the manufacturer's website for the specific USB device you are connecting. Download and install the latest drivers compatible with Windows Vista.
    Run as...​
    Run as Administrator:​
  • While being logged in with administrative rights should be sufficient, you can try running the driver installation process as an administrator to ensure all necessary permissions are granted.
    Modify Driver Search Locations:​
    1. Device Manager:
      • Right-click on Computer or My Computer and select Manage.
      • Go to Device Manager.
      • Right-click on the problematic device and select Update Driver Software.
      • Choose Browse my computer for driver software.
      • Specify the path C:\Windows\System32 to allow Windows to search for drivers in that location.
        Enable Automatic Driver Installation:​
    []You can try enabling automatic driver installation in Windows Vista so that it automatically finds and installs drivers when the device is connected.
Automatic Driver Search Registry Key:​
  • You can modify a registry key to allow Windows to automatically search for drivers when a new device is connected:
    • Registry Key: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion
    • Value Name: DevicePath
    • Value Data: Ensure that %SystemRoot%\inf is included in the list.
      Third-Party Tools:​
  • ]Consider using third-party driver management tools that can help identify and install missing drivers for your devices. Try these steps to streamline the USB driver installation process on Windows Vista and hopefully eliminate the need for manual intervention every time you connect a USB device. If the issue persists, feel free to provide more information for further assistance.
