Today’s changes to GitHub Copilot’s individual plans mark one of the most consequential pricing and access resets the product has made since its consumer rollout. GitHub is pausing new sign-ups for Copilot Pro, Pro+, and Student plans, tightening usage limits, and removing Opus model access from Pro while keeping Opus 4.7 in Pro+ for now. The company says the move is about protecting service reliability for existing customers as agentic workflows and long-running sessions drive heavier compute demand than the original plan structure was designed to absorb. For developers who have come to rely on Copilot as an always-there assistant, the change is less a simple pricing tweak than a signal that the economics of AI coding tools are becoming more restrictive—and more explicitly capacity-managed.
GitHub Copilot began as a code-completion product, but it has steadily evolved into something much bigger: a multi-model, agent-aware coding platform with chat, planning, and workflow automation features. That evolution matters because the pricing model for a lightweight autocomplete assistant is very different from the cost profile of an AI system that can hold long sessions, coordinate subagents, and generate large volumes of tokens in parallel. GitHub’s own explanation points directly at that shift, saying agentic workflows and parallelized sessions are now consuming far more resources than the original plan structure was built to support. (github.blog)
In earlier phases of Copilot, the main value proposition was straightforward. Pay a subscription, get code suggestions, and use the product across a set of environments and model tiers. Over time, GitHub layered in premium requests, multiple model families, plan differentiation, and higher-end offerings such as Pro+, which was positioned as the better fit for users who needed access to the strongest models and higher monthly limits. The current changes suggest that GitHub now sees that tiering as under strain, especially among individual users adopting more advanced workflows than the company expected when it set the original guardrails. (github.blog)
The timing is also important. Just days before this announcement, GitHub had already moved to enforce new limits and retire Opus 4.6 Fast from Pro+, citing high concurrency and intense usage patterns. That tells a broader story: the company is not reacting to a single product issue, but to a sustained capacity problem across Copilot’s individual ecosystem. In other words, the April 20 announcement looks less like a standalone policy change and more like the latest step in a sequence of operational tightening. (github.blog)
GitHub has also been changing how Copilot is positioned commercially. Earlier in 2026, the company introduced updates for students, adjustments to data usage policies, and broader emphasis on usage controls and transparency. Those moves point to a platform that is no longer being sold simply as a consumer convenience, but as a metered AI service with distinct reliability and sustainability constraints. That distinction is now at the center of the Copilot conversation. (github.blog)
GitHub is also tightening usage limits for individual plans and making the separation between plans more explicit. The company says Pro+ offers more than 5X the limits of Pro, and it is encouraging Pro users who need more headroom to upgrade. At the same time, the company is surfacing usage information directly in VS Code and Copilot CLI, so users can see when they are approaching a limit before they hit it. That is a meaningful user-experience change because it moves Copilot from invisible metering toward visible guardrails. (github.blog)
The company frames all of this as a reliability intervention rather than a pure monetization play. That distinction is important, because it gives GitHub a defensible rationale: if a small number of resource-heavy users can degrade service for everyone, then stronger limits can be presented as a fairness measure. Still, from a customer perspective, it is hard to avoid the feeling that the product is becoming more gated just as its most powerful features become more attractive. That tension is the heart of the announcement. (github.blog)
That is not an implausible claim. AI coding agents are expensive in ways that vanilla autocomplete tools are not. They produce more tokens, hold context longer, invoke tools more frequently, and often run in bursts that are highly concentrated in time. When many users do this simultaneously, infrastructure pressure rises fast, and a service provider has to decide whether to raise prices, add capacity, clamp usage, or some combination of all three. GitHub appears to be choosing the clamp-first approach while it figures out a more durable answer. (github.blog)
The company’s description of the issue is also revealing in its language about predictability. GitHub says these changes are necessary to provide existing customers with a predictable experience. That suggests the company sees reliability as the product feature at risk, not just raw capacity. In subscription software, predictability is a feature in itself: users want to know whether a tool will still be available, responsive, and consistent when a deadline or production issue hits. That predictability premium is now being protected at the expense of openness. (github.blog)
This is also where GitHub’s distinction between premium requests and usage limits becomes central. Premium requests govern model access and request counts, while usage limits are token-based guardrails that can still trigger even when premium requests remain. That split is subtle but important, because it means a subscriber may feel they have “paid for access” and still find themselves blocked. In practical terms, that can be more frustrating than a simple monthly cap. (github.blog)
The presence of usage warnings in VS Code and Copilot CLI is a good sign operationally, but it is also a tacit admission that surprise limits have been a problem. GitHub is telling users it wants to reduce abrupt interruptions, which is helpful, but it cannot fully eliminate the underlying frustration of being rate-limited in the middle of real work. Warnings are useful; fewer limits would be better. (github.blog)
This may not surprise enterprise software buyers, but it will land differently with individual developers who adopted Copilot under a relatively generous early-access mentality. They may have assumed that subscriptions would scale primarily by feature set, not by hard usage ceilings and model rationing. The newer Copilot is making clear that compute-heavy AI assistance is not a flat-rate commodity. (github.blog)
For consumer users more broadly, the biggest message is that GitHub is prioritizing service continuity over open-ended growth. That can preserve quality for current members, but it also makes the paid individual market feel less like a promotion channel and more like a managed club. If the experience becomes too constrained, some users will start looking elsewhere. (github.blog)
That matters because model availability is often the decisive factor in AI tool adoption. Many developers are willing to tolerate rough edges if the system can save time on difficult tasks, but they are less forgiving when the best model is just out of reach. GitHub seems to know this, which is why it is linking higher limits and Opus access so tightly to Pro+. (github.blog)
There is also a brand issue at play. When users hear that a flagship model is being removed from one plan and downgraded from another, they may interpret it as retreat, even if GitHub presents it as rebalancing. In AI products, perception often matters as much as actual feature parity, because trust is built on expectations of continuity. Once users believe a model can disappear, they start planning for that possibility. (github.blog)
The move also reinforces an emerging pattern in AI software: premium capability increasingly comes packaged with premium metering. The model that users want is not just expensive to train, but expensive to serve at scale, and those costs are being pushed closer to the surface. GitHub is not alone in this, but its decision is especially visible because Copilot sits so close to daily development work. (github.blog)
For rivals, the opportunity is not just to offer lower prices but to offer clearer value. Users burned by surprise limits are likely to reward products that communicate capacity more plainly, even if those products are not cheaper. In AI assistance, trust in usage policy is becoming a differentiator alongside model quality. (github.blog)
This could accelerate a split in the market between light-use consumer plans and capacity-rich professional plans. If that happens, the developer tools market may begin to look more like cloud computing than software licensing, with metering, throttling, and tiered resource guarantees as standard features. That would be a major shift in how individual developers think about AI subscriptions. (github.blog)
That said, convenience only goes so far when capacity feels unreliable. If users repeatedly hit limits during real work, they may begin testing alternatives simply to reduce risk. The more important GitHub’s role becomes in the software stack, the less tolerant users will be of abrupt access changes. (github.blog)
Consumers, by contrast, are now facing a much more explicit ceiling on value. They do not get the same predictability guarantees that enterprise customers can negotiate, so every adjustment in the individual tiers feels more personal and more sudden. In practical terms, the consumer market is where GitHub can test limits, but it is also where backlash is likely to be loudest. (github.blog)
There is a subtle but meaningful message here: individual Copilot users are being treated as a shared pool whose usage must be controlled, while enterprise customers are implicitly treated as a more stable and valuable class. That is a common software pattern, but it becomes especially visible when the same AI capabilities are available in one segment and curtailed in another. The divide is now part of the product identity. (github.blog)
The long-term danger is that consumers may start to view Copilot as less generous than competing assistants, even if the actual model quality remains strong. Perception matters because individual developers often choose tools based on perceived friction, not just benchmark performance. If a tool feels like it is constantly counting tokens over your shoulder, adoption can soften quickly. (github.blog)
GitHub’s own guidance points toward a few simple habits: choose smaller-multiplier models for simpler tasks, reduce parallel workflows, and use plan mode where it improves efficiency. Those suggestions are not glamorous, but they reflect the new reality that usage efficiency is now part of developer discipline. In other words, AI-assisted coding is becoming an optimization problem as much as a productivity booster. (github.blog)
A second step is to separate exploratory work from heavy production-style sessions. Use Copilot for quick scaffolding, targeted refactors, and localized assistance where possible, rather than putting everything into one sprawling agent run. That kind of discipline may feel slightly less magical, but it is more sustainable under the new rules. (github.blog)
A lot will depend on execution. If the warnings are accurate, the limits sensible, and the quality improvement noticeable, users may eventually accept the trade-off. If the experience remains inconsistent or the restrictions keep expanding, GitHub may find that it has solved one reliability problem while creating a trust problem. In subscription software, those are often the same problem in different clothes. (github.blog)
Source: The GitHub Blog Changes to GitHub Copilot plans for individuals - GitHub Changelog
Background
GitHub Copilot began as a code-completion product, but it has steadily evolved into something much bigger: a multi-model, agent-aware coding platform with chat, planning, and workflow automation features. That evolution matters because the pricing model for a lightweight autocomplete assistant is very different from the cost profile of an AI system that can hold long sessions, coordinate subagents, and generate large volumes of tokens in parallel. GitHub’s own explanation points directly at that shift, saying agentic workflows and parallelized sessions are now consuming far more resources than the original plan structure was built to support. (github.blog)In earlier phases of Copilot, the main value proposition was straightforward. Pay a subscription, get code suggestions, and use the product across a set of environments and model tiers. Over time, GitHub layered in premium requests, multiple model families, plan differentiation, and higher-end offerings such as Pro+, which was positioned as the better fit for users who needed access to the strongest models and higher monthly limits. The current changes suggest that GitHub now sees that tiering as under strain, especially among individual users adopting more advanced workflows than the company expected when it set the original guardrails. (github.blog)
What Changed
The headline change is the pause on new sign-ups for Copilot Pro, Pro+, and Student plans. That means GitHub is effectively closing the door to fresh individual subscriptions on the paid tiers while preserving access for current paying users. It is a classic capacity-management move: slow the inflow, keep serving the installed base, and reduce the risk that demand growth outpaces available service quality. (github.blog)GitHub is also tightening usage limits for individual plans and making the separation between plans more explicit. The company says Pro+ offers more than 5X the limits of Pro, and it is encouraging Pro users who need more headroom to upgrade. At the same time, the company is surfacing usage information directly in VS Code and Copilot CLI, so users can see when they are approaching a limit before they hit it. That is a meaningful user-experience change because it moves Copilot from invisible metering toward visible guardrails. (github.blog)
The model availability shift
GitHub is also changing which models individual subscribers can access. Opus models are no longer available on Copilot Pro, and Opus 4.7 remains available only on Pro+. GitHub says Opus 4.5 and 4.6 will also be removed from Pro+ as previously announced, which narrows the premium model menu further. The practical effect is clear: advanced model access is becoming more tightly linked to the highest-paying individual plan. (github.blog)The company frames all of this as a reliability intervention rather than a pure monetization play. That distinction is important, because it gives GitHub a defensible rationale: if a small number of resource-heavy users can degrade service for everyone, then stronger limits can be presented as a fairness measure. Still, from a customer perspective, it is hard to avoid the feeling that the product is becoming more gated just as its most powerful features become more attractive. That tension is the heart of the announcement. (github.blog)
Refund and cancellation terms
GitHub is trying to soften the blow with a limited refund window. If a user decides the changes do not work for them, they can cancel a Pro or Pro+ subscription and avoid charges for April usage, provided they contact support between April 20 and May 20 for a refund. That is a notable concession, and it signals that GitHub expects real dissatisfaction, not just mild confusion, from some subset of users. (github.blog)Why GitHub Says It Had to Act
GitHub’s central argument is that Copilot’s current workload profile is no longer compatible with the old plan economics. The company says long-running, parallelized sessions now consume far more resources than the original structure was designed to support, and that more customers are hitting usage limits intended to preserve reliability. In GitHub’s view, doing nothing would worsen service quality for everyone. (github.blog)That is not an implausible claim. AI coding agents are expensive in ways that vanilla autocomplete tools are not. They produce more tokens, hold context longer, invoke tools more frequently, and often run in bursts that are highly concentrated in time. When many users do this simultaneously, infrastructure pressure rises fast, and a service provider has to decide whether to raise prices, add capacity, clamp usage, or some combination of all three. GitHub appears to be choosing the clamp-first approach while it figures out a more durable answer. (github.blog)
The economics of agentic coding
Agentic coding changes the cost curve because it turns a session into a miniature workload pipeline. A user is not just asking for a suggestion; they may be asking Copilot to research, plan, edit, retry, and coordinate across multiple steps. That can be useful, but it also makes usage less predictable and more expensive per task. GitHub is essentially acknowledging that its pricing model is now being stress-tested by the very capabilities users wanted most. (github.blog)The company’s description of the issue is also revealing in its language about predictability. GitHub says these changes are necessary to provide existing customers with a predictable experience. That suggests the company sees reliability as the product feature at risk, not just raw capacity. In subscription software, predictability is a feature in itself: users want to know whether a tool will still be available, responsive, and consistent when a deadline or production issue hits. That predictability premium is now being protected at the expense of openness. (github.blog)
Limits are now part of the product design
The announcement makes clear that Copilot usage limits are no longer a hidden backend detail. GitHub is now exposing limit warnings in the editor and CLI, reinforcing that capacity management is a first-class design element. That shift matters because it changes expectations: users are being taught to think in terms of consumption windows, token costs, and model multipliers rather than assuming broad, uniform access. (github.blog)This is also where GitHub’s distinction between premium requests and usage limits becomes central. Premium requests govern model access and request counts, while usage limits are token-based guardrails that can still trigger even when premium requests remain. That split is subtle but important, because it means a subscriber may feel they have “paid for access” and still find themselves blocked. In practical terms, that can be more frustrating than a simple monthly cap. (github.blog)
What It Means for Existing Subscribers
For current paid users, the immediate impact depends on how intensively they use Copilot. Many casual subscribers may barely notice the changes, especially if they mostly use smaller models or light completion workflows. Heavy users, by contrast, may encounter warnings sooner, be pushed toward Auto mode, or find that the plan they once considered comfortably sufficient no longer covers their normal workload. (github.blog)The presence of usage warnings in VS Code and Copilot CLI is a good sign operationally, but it is also a tacit admission that surprise limits have been a problem. GitHub is telling users it wants to reduce abrupt interruptions, which is helpful, but it cannot fully eliminate the underlying frustration of being rate-limited in the middle of real work. Warnings are useful; fewer limits would be better. (github.blog)
Pro versus Pro+
The practical differentiation between Pro and Pro+ is now sharper than ever. GitHub is effectively saying that Pro is for lighter use cases, while Pro+ is the home for users who want sustained access to higher-value models and higher throughput. That means the product is moving closer to a classic tiered SaaS model where premium performance is reserved for the top tier. (github.blog)This may not surprise enterprise software buyers, but it will land differently with individual developers who adopted Copilot under a relatively generous early-access mentality. They may have assumed that subscriptions would scale primarily by feature set, not by hard usage ceilings and model rationing. The newer Copilot is making clear that compute-heavy AI assistance is not a flat-rate commodity. (github.blog)
Consumer and student impact
The pause on Student sign-ups is particularly sensitive because students often form their habits around whatever tools they can access during training. GitHub has said in earlier announcements that it wants to build a sustainable Copilot experience tailored for students, so the current pause looks like a temporary protection measure rather than a permanent retreat. Even so, it risks slowing adoption among the next generation of developers. (github.blog)For consumer users more broadly, the biggest message is that GitHub is prioritizing service continuity over open-ended growth. That can preserve quality for current members, but it also makes the paid individual market feel less like a promotion channel and more like a managed club. If the experience becomes too constrained, some users will start looking elsewhere. (github.blog)
Why Opus Matters
The removal of Opus from Pro is more than a model swap. Opus has represented the premium end of Copilot’s multi-model lineup, so restricting it changes how users perceive the value of the individual plans. When the strongest models are reserved for the highest tier, the product begins to resemble a performance ladder rather than a flexible toolkit. (github.blog)That matters because model availability is often the decisive factor in AI tool adoption. Many developers are willing to tolerate rough edges if the system can save time on difficult tasks, but they are less forgiving when the best model is just out of reach. GitHub seems to know this, which is why it is linking higher limits and Opus access so tightly to Pro+. (github.blog)
Model choice as a pricing lever
Copilot’s model strategy is now functioning as a pricing lever. The more capable the model, the more likely it is to sit behind a higher tier or a stricter usage gate. That is not unique to GitHub, but it is becoming increasingly visible here because the product is built directly into the developer workflow, where interruption is immediately felt. (github.blog)There is also a brand issue at play. When users hear that a flagship model is being removed from one plan and downgraded from another, they may interpret it as retreat, even if GitHub presents it as rebalancing. In AI products, perception often matters as much as actual feature parity, because trust is built on expectations of continuity. Once users believe a model can disappear, they start planning for that possibility. (github.blog)
The Pro+ bet
GitHub is clearly betting that some users will pay more rather than leave. Pro+ is the pressure valve: if Pro feels too restrictive, the next step is a higher-tier subscription with more than five times the limits. That may work for developers who use Copilot professionally and can justify the cost, but it is less certain for hobbyists or freelancers who see Copilot as a convenience rather than a budget line item. (github.blog)The move also reinforces an emerging pattern in AI software: premium capability increasingly comes packaged with premium metering. The model that users want is not just expensive to train, but expensive to serve at scale, and those costs are being pushed closer to the surface. GitHub is not alone in this, but its decision is especially visible because Copilot sits so close to daily development work. (github.blog)
Competitive Implications
GitHub’s changes create both an opening and a warning for competitors. On one hand, tighter Copilot limits could push some individual developers to explore alternatives that appear less constrained or more transparent about usage. On the other hand, if rivals face similar infrastructure pressures, they may eventually adopt comparable limits and price segmentation. Either way, the idea that AI coding tools are limitless is fading quickly. (github.blog)For rivals, the opportunity is not just to offer lower prices but to offer clearer value. Users burned by surprise limits are likely to reward products that communicate capacity more plainly, even if those products are not cheaper. In AI assistance, trust in usage policy is becoming a differentiator alongside model quality. (github.blog)
The market is moving toward managed scarcity
One of the biggest strategic signals here is the normalization of managed scarcity. GitHub is telling users, in effect, that the service must be rationed to protect quality. That language may be uncomfortable, but it is also likely to spread as AI platforms mature and the economics of heavy usage become impossible to ignore. (github.blog)This could accelerate a split in the market between light-use consumer plans and capacity-rich professional plans. If that happens, the developer tools market may begin to look more like cloud computing than software licensing, with metering, throttling, and tiered resource guarantees as standard features. That would be a major shift in how individual developers think about AI subscriptions. (github.blog)
GitHub’s strategic advantage remains strong
Even with these changes, GitHub retains a formidable advantage: deep integration into the developer workflow. Copilot is already inside editors, terminals, and project context, which means switching costs are high. A dissatisfied user may complain loudly, but actually moving off the platform is harder than it sounds. (github.blog)That said, convenience only goes so far when capacity feels unreliable. If users repeatedly hit limits during real work, they may begin testing alternatives simply to reduce risk. The more important GitHub’s role becomes in the software stack, the less tolerant users will be of abrupt access changes. (github.blog)
Enterprise vs Consumer Impact
For enterprises, the impact is mostly indirect but still relevant. Copilot Business and Enterprise users are not affected by the data-policy update GitHub announced in March, and the current individual-plan changes are aimed specifically at consumer-style subscriptions. That separation reinforces GitHub’s broader segmentation strategy: individual plans are becoming stricter, while business plans remain the more stable channel for serious organizational adoption. (github.blog)Consumers, by contrast, are now facing a much more explicit ceiling on value. They do not get the same predictability guarantees that enterprise customers can negotiate, so every adjustment in the individual tiers feels more personal and more sudden. In practical terms, the consumer market is where GitHub can test limits, but it is also where backlash is likely to be loudest. (github.blog)
The enterprise signal
The enterprise takeaway is that GitHub wants the most demanding workloads to migrate into contract-based environments where pricing and capacity can be managed more tightly. That makes sense from a business perspective because enterprise agreements are better suited to predictable revenue and support commitments. It also gives GitHub room to keep individual plans from being overrun by power users. (github.blog)There is a subtle but meaningful message here: individual Copilot users are being treated as a shared pool whose usage must be controlled, while enterprise customers are implicitly treated as a more stable and valuable class. That is a common software pattern, but it becomes especially visible when the same AI capabilities are available in one segment and curtailed in another. The divide is now part of the product identity. (github.blog)
The consumer signal
For consumers, the message is more transactional. You can still use Copilot Free, and you can still upgrade within the individual ecosystem if you are already in it, but the runway for new paid adoption has been narrowed. That is likely to slow momentum at the top of the funnel while GitHub reassesses capacity and monetization. (github.blog)The long-term danger is that consumers may start to view Copilot as less generous than competing assistants, even if the actual model quality remains strong. Perception matters because individual developers often choose tools based on perceived friction, not just benchmark performance. If a tool feels like it is constantly counting tokens over your shoulder, adoption can soften quickly. (github.blog)
How Developers Should Adapt
The most practical response is to treat Copilot usage like any other metered resource. If you are on Pro, you should assume that higher-volume agentic sessions can consume your allowance faster than you expect, especially when working across parallel tasks. The best defense is to make model selection and workflow design part of your planning, not something you leave to chance. (github.blog)GitHub’s own guidance points toward a few simple habits: choose smaller-multiplier models for simpler tasks, reduce parallel workflows, and use plan mode where it improves efficiency. Those suggestions are not glamorous, but they reflect the new reality that usage efficiency is now part of developer discipline. In other words, AI-assisted coding is becoming an optimization problem as much as a productivity booster. (github.blog)
Practical steps for individual users
If you are trying to avoid unpleasant surprises, the most important first step is visibility. Watch the new usage indicators in VS Code and Copilot CLI, and pay attention to how quickly specific workflows consume your limit. That visibility should help you decide when a lightweight model is sufficient and when you genuinely need the higher-end tier. (github.blog)A second step is to separate exploratory work from heavy production-style sessions. Use Copilot for quick scaffolding, targeted refactors, and localized assistance where possible, rather than putting everything into one sprawling agent run. That kind of discipline may feel slightly less magical, but it is more sustainable under the new rules. (github.blog)
A simple workflow checklist
- Check your current plan before starting a large task.
- Use the smallest adequate model for routine work.
- Avoid stacking many parallel agent sessions at once.
- Monitor usage warnings in the editor and CLI.
- Switch to Auto mode when you hit a weekly ceiling and premium requests remain.
- Upgrade to Pro+ only if your actual workload justifies the higher cap. (github.blog)
Strengths and Opportunities
GitHub’s decision is restrictive, but it also reveals a coherent strategy: protect quality, make limits visible, and reserve the heaviest-capacity experience for users who genuinely need it. That may frustrate some individual customers, yet it could improve overall trust if GitHub executes well and communicates clearly.- Better reliability for existing users if the capacity controls do what GitHub says they will.
- Clearer guardrails in VS Code and Copilot CLI reduce surprise interruptions.
- Sharper tiering makes the difference between Pro and Pro+ easier to understand.
- Improved capacity management may stabilize the service during peak demand.
- Stronger monetization could fund continued model and infrastructure investment.
- More predictable support may help GitHub avoid broader service degradation.
- A cleaner product story around premium access, if GitHub explains the trade-offs well.
Risks and Concerns
The biggest risk is obvious: users may feel punished for adopting the more advanced features GitHub spent so much effort promoting. If the company overcorrects, it could erode goodwill, especially among independent developers, students, and power users who feel caught between product innovation and plan restriction.- Subscription fatigue could drive users to compare Copilot more aggressively with rivals.
- Perceived bait-and-switch risk may rise if users think the paid experience changed too quickly.
- Student adoption may slow if access remains constrained for too long.
- Model fragmentation could confuse users about what they are actually paying for.
- Limit anxiety may reduce the sense of Copilot being a seamless assistant.
- Backlash on social channels may amplify if users hit limits in critical workflows.
- Refund requests and cancellations may spike if the new limits feel too tight.
Looking Ahead
The next phase will be about whether GitHub can turn this from a defensive maneuver into a stable operating model. The company has effectively admitted that AI coding at scale is expensive and that the old assumptions no longer hold. What users will be watching now is whether the new limits feel like a temporary correction or the start of a more permanent tightening cycle. (github.blog)A lot will depend on execution. If the warnings are accurate, the limits sensible, and the quality improvement noticeable, users may eventually accept the trade-off. If the experience remains inconsistent or the restrictions keep expanding, GitHub may find that it has solved one reliability problem while creating a trust problem. In subscription software, those are often the same problem in different clothes. (github.blog)
- Watch whether GitHub restores paid sign-ups after capacity stabilizes.
- Monitor how long Opus 4.7 remains exclusive to Pro+.
- Track whether Pro+ becomes the default recommendation for active individual users.
- See whether usage limit transparency reduces complaints in practice.
- Look for follow-up adjustments to weekly and session caps.
- Pay attention to whether competitors respond with simpler or more generous plans.
