Windows 7 Handle is invalid when printing
jasonchen699
I have a HP M1530 printer working fine on Windows 7. I get the error the handle is invalid after I update .Net framework to V4.0. I tried to install latest printer driver, still no luck. Any ideas? Thanks.
Even in a production environment, you should be able to do a 5 minute test of uninstalling, testing, and reinstalling. You really want to confirm what the problem is before you spend a lot of time exploring solutions in the wrong direction.
If you are sure the problem is with the printer driver, try contacting HP tech support. You would not be the only person with this incompatibility and they might have a fix.
Fixer1234
There were .Net framework incompatibilities with Windows XP for certain versions. This is the first I've heard with Windows 7. Try rolling back to the previous version (or just uninstall V4.0). If that fixes it, you will probably want to hide updates pushing V4.0 so you don't inadvertently recreate the problem.
jasonchen699
But I do need .Net framework V4. Is there a way to fix it without rolling back to previous version?
Fixer1234
Roll it back just as a test to see if that is actually the issue. Then you will know how to proceed.
jasonchen699
It is production environment, I can't roll it back. Let's assume the issue is due to .Net framework incompatibilities with win7 or printer driver. How to make it work. However .Net 4.0 works well on other Win7 computers. So I think maybe .Net 4.0 has incompatibility issue with printer driver(HP M1530)? but I already installed latest printer driver and no luck.
Fixer1234
