- Thread Author
- #1
Hello All.
I am posting this after a lot of search for the solution on the internet but all in vain.
I am trying to run command prompt in windows 7 professional, but it is not appearing in front of me.
1. I tried to run it from Start --> Accessories --> Command Prompt
2. I tried to run by typing cmd on the start menu and then finding the .exe file
3. I tried to run using Run command by typing cmd in Run dialog box
4. I tried to run it from C:/Windows/system32 folder
5. I also tried to run it using right click and then selecting Run as Administrator
But whatever I tried to do I cannot see the command prompt window.
Also, when I run the task manager, I can only see the cmd.exe running in the 'processes tab' and that too one new process for each time I have clicked on the cmd.exe.
But it does not show cmd.exe in the 'applications tab' where it should be showing.
Please help me. This problem is bugging me for a long time now. And now I need to run for very urgent project of mine.
