Windows 7 HELP!! I need the original explorer.exe for Windows 7...
Slayer72
I accidently overwrote the explorer.exe when I was installing a new theme for Windows 7, does anyone have the original explorer.exe so I can have my original Start button orb back??
Any help would be greatly appreciated!!
Slayer72 ;)
Think he deleted the .exe, not the icon.
What build of 7, and what bit version are you running?
Another way , if you have any restore points, is to look in the Shadow Copy with the free Shadow Explorer - find explorer.exe and export a copy.
Suggest you get the 0.4 rather than the 0.5 beta.
ShadowExplorer.com - Downloads
Link Removed due to 404 Error
Try this link: Icon Cache - Rebuild - Vista Forums
It's for vista but should be ok for 7....I hope!
Post back if more help is needed...
I'm pretty sure the above should get his start button back too but hey whatever works...:)
