Help Needed - Error Code 0xc0000142
shrutigrover
Hi All
I am reaching out to seek assistance regarding a critical issue I am facing with my Intel vPro Processor Laptop. I recently encountered the following error: "Error code 0xc0000142: Application not found - The application executable is missing or corrupt. Reinstall the program or check."
I have tried various troubleshooting steps, including reinstalling the affected program, but the issue persists. Given that I have an Link Removed I am wondering if there might be any specific considerations or solutions related to this hardware.
If any of you have experienced a similar problem or have insights into resolving this error, I would greatly appreciate your guidance. Additionally, if there are any Intel vPro experts in the community, your expertise would be invaluable.
Thank you in advance
Hello,
I'm sorry to hear that you are experiencing this error on your Intel vPro Processor Laptop. The error code 0xc0000142 usually indicates a problem with the application executable file, which could be missing or corrupt. Reinstalling the program is the first step many users take to fix this issue, but it doesn't always work as expected.
Since you mentioned having an Intel vPro Processor, it is important to note that this error is not specific to that hardware. It is more likely related to the software or the operating system.
Here are a few general troubleshooting steps you can try to resolve the error code 0xc0000142:
  1. Run a virus scan: It is possible that malware or a virus could be causing this issue. Make sure you have an...
Hello,
  1. Run a virus scan: It is possible that malware or a virus could be causing this issue. Make sure you have an up-to-date antivirus program and run a full scan on your system.
  2. Perform a clean boot: Sometimes, third-party applications or services can interfere with the proper functioning of other programs. By performing a clean boot, you can disable non-essential startup items and services to determine if any of them are causing the error. Here's how to do it: a. Press Windows + R on your keyboard to open the Run dialog box. b. Type "msconfig" and click OK. c. In the System Configuration window, go to the Services tab, check the box that says "Hide all Microsoft services," and click Disable all. d. Next, go to the Startup tab and click Open Task Manager. e. In the Task Manager window, disable all startup items by right-clicking on them and selecting Disable. f. Close the Task Manager and go back to the System Configuration window. Click OK and restart your computer.
  3. Update or reinstall affected software: If the error only occurs with a specific program, try updating it to the latest version or reinstalling it completely. Make sure you download the installation files from the official website to ensure they are not compromised.
  4. Check for Windows updates: It is important to have the latest updates and patches installed on your system. Windows updates often include bug fixes and improvements that can resolve issues like this one.
  5. Perform a system file check: Windows has a built-in tool called System File Checker that can scan and repair corrupted system files. Here's how to use it: a. Press Windows + X and select Command Prompt (Admin) or Windows PowerShell (Admin). b. In the command prompt, type "sfc /scannow" (without quotes) and press Enter. c. Wait for the process to complete and follow any on-screen instructions.
    If none of the above solutions work, you may need to consider more advanced troubleshooting steps, such as restoring your system to a previous restore point or performing a clean Windows installation. However, before doing that, it is always recommended to back up your important files.
    If you are unsure about any of the steps or need further assistance, I would recommend reaching out to the official support channels of your laptop manufacturer or the software developer of the affected program. They may have more specific solutions or can provide guidance based on your hardware and software configuration.
    I hope this information helps you resolve the error code 0xc0000142. Good luck, and please let me know if you have any further questions.
ussnorway
Windows Forum Team
what OS is installed? the code normally means you are running a W10 code on a W11 device or even that it needs a certain build to allow their spyware
Error code 0xc0000142 usually points to an Application Error, meaning that a specific program or process could not start correctly. While your mention of running Windows 10 code on a Windows 11 device or compatibility issues is valid in some scenarios, the code has various causes. Let’s break it down:
Common Causes​
  1. Compatibility Issues:
    • Old software may not be compatible with Windows 11 and can throw this error. This often happens with software written for Windows 10 or earlier versions.
  2. Corrupted System Files:
    • Critical system files may be damaged, causing this error. This can stem from improper shutdowns, malware, or incomplete updates.
  3. Outdated or Missing Builds:
    • Software or drivers might require specific Windows builds or updates to function properly.
  4. DLL Loading Errors:
    • This specific error often occurs when critical Dynamic Link Libraries (DLLs) fail to load because of corruption or dependency issues.
  5. Security Blockers (Spyware/Antivirus):
    • Applications flagged by antivirus (or configured incompatibly with certain Windows security features) can cause this issue.
Fixes and Recommendations​
1. Verify the OS Version
  • Ensure you're running the proper version of the application for Windows 11. Check its documentation for compatibility requirements.
    How to Check OS Build:
  • Press Win + R, type winver, and hit Enter. Look at the build version to confirm it meets the app’s requirements.
2. Run Applications in Compatibility Mode
  • If the error occurs with older software:
    1. Right-click the application/executable file.
    2. Select Properties > Go to the Compatibility tab.
    3. Check Run this program in compatibility mode for: and select an older OS, such as Windows 10 or 8.
    4. Optional: Run the app as an administrator from the same tab.
3. Update Windows
  • Lack of up-to-date Windows components may cause these errors.
    • Press Win + I > Go to Windows Update > Click Check for Updates.
4. Reinstall the Software
  • Uninstall the app, download a fresh/updated installer, and reinstall. Ensure no corruption occurred during the initial installation.
5. Run SFC and DISM Tools
  • Corrupted system files are common culprits.
    Run System File Checker:
    1. Open Command Prompt as Administrator.
    2. Type: sfc /scannow and press Enter.
      • Let it complete. If any issues are repaired but the problem persists, use the Deployment Imaging and Servicing Management (DISM) tool:
        1. In Command Prompt type:
           DISM /Online /Cleanup-Image /RestoreHealth
        2. Hit Enter and wait for completion.
6. Disable Antivirus/Windows Security (Temporarily)
  • Some antivirus tools block or restrict applications that rely heavily on DLLs. Temporarily disable antivirus software and test if the issue clears up. Don't forget to enable protection again afterward!
7. Spyware Connection
  • If you suspect software might be flagged as spyware, ensure it comes from a legitimate source. Dubious software is risky and could cause deeper system issues. Run a malware scan using tools like Windows Defender or Malwarebytes for peace of mind.
8. Recreate the Missing Files (DLL Fix):​
  • If the error is throwing DLL-related issues (check the error message for hints):
    1. Re-register DLL files via the command:
       regsvr32 filename.dll
    2. Alternatively, redownload corrupted or missing DLLs from legitimate sources (like the Microsoft site).
9. Rollback or Fresh Install
  • If upgrading to Windows 11 triggered persistent issues, consider rolling back to Windows 10 with the Go Back feature in Windows Settings.
  • Otherwise, a fresh install of Windows 11 might eliminate deeper OS-level corruption.
Final Thoughts​
If the error persists after trying the fixes above, it would be helpful to have more details about the application or process throwing the error. Also, note any associated DLLs, as that can narrow down the problem further.
Let me know if you'd like to troubleshoot deeper—you've got this! 😊
