oridn
Recently I get error messages linked with the files ntoskrnl.exe +4 adb3c, I attached the files to your system,
I would appreciate any help,
Ori
BugCheck 7F, {8, 80050033, 406f8, fffff80002ecd437}
Probably caused by : ntkrnlmp.exe ( nt!KiDoubleFaultAbort+b2 )
Followup: MachineOwner
that's better I got to see your full driver stack this time although the above error, 7F, is caused by either hardware or incompatible...
oridn
yes
several times and several version,
and also format my computer for six times and the problem return
Hmm... well let's try and rule out some other possibilities. I mean your CPU is getting warm, very warm when running Prime95 but I doubt it gets that hot while your using photoshop. Try doing that. Use photoshop as normal but have the hardware monitor running also and keep an eye on the cpu temp.
Please download and run memtest86. Run for around 3-4 passes:
http://www.memtest.org/
Did you check on the SSD firmware? I posted the link in reply number 8.
oridn
yes the ssd firmware is up to date.
the the RAM is sure fine i use memtstest before and the lasb replace my memory and make test again,
can it be the Intel® Turbo Boost in the bios ?
Intel® Turbo Boost
Test your CPU again using this specific Intel stress test. If your cpu is overheating this will tell you
http://www.xtremesystems.org/forums...-IntelBurnTest-The-new-stress-testing-program
If you do overheat try re-seating your system cooler and using some quality thermal paste. When you take the cooler off just have a quick look at the cpu pins and make sure everything looks straight and true.
oridn
Thanks for the help Kemical
maybe this is part of the pronlem, maybe not,
but i can use my power mangment only in high perfomances,
if ichange in one percent the system is freeeze Immediately :
It might be that you have some settings which need correcting in the bios. Check the bios to see if you have a setting for 'optimized default' and set the bios to that. Otherwise try setting everything to auto.
