* Bugcheck Analysis *
BugCheck 124, {0, fffffa80101f6028, be000000, 800400}
Probably caused by : GenuineIntel
Followup: MachineOwner
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BugCheck 101, {19, 0, fffff880009b3180, 4}
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
When was the last time the machine was cleaned out of any dust build up?Mostly it crashes when im gaming.
Yes, just use as normal and if a bsod occurs please post the dump file. Sometimes this can be a process of elimination and the more dump files we get to look at the better.Do i just use the computer normally for 24 hours or isit actually running something in the back ground?
Ok, well just keep using as normal and if it blue screens again please post the dump file.Its cleaned out rather regularly as previously i was worried it was due to dust. Even the themal paste has been changed like 3 times in half a year now
ReferenceIntelBurnTest: Another popular option for testing CPUs. IntelBurnTest uses the same stress-testing engine that Intel uses internally for quality control before shipping out CPUs. The program also claims to perform the necessary tests in 8 minutes, as opposed to 3+ hours with Prime95.
For a slightly more obscure option, there’s also Super PI, a single-threaded benchmark that calculates the number pi up to a specified number of digits (with a maximum of 32 million). It’s not the ideal stress test for multi-core CPUs, but it can still give you a good idea of how your PC will handle single-threaded tasks. It’s also not a bad frame of reference for PC gaming performance.
GPU testing
FurMark: An extremely popular graphics stress test. This program should push your graphics card harder than even the most demanding game on the market. If your GPU has problems, you should know within about 15 minutes.
