Windows 7 help with win 7 rc
anchortim
I downloaded the windows 7 rc a day after it came out and installed it and activated it. now yesterday when i turned on my pc it said my copy wasnt active or genuine. i tried entering the key agian and tried a different key and nothing works. is ther a fix to this what do i do?
TwinA
Activate it again then? And if that is not possible, you should contact M$.
Radenight
You may have to reinstall.. ;)
Did you recently install any updates through Windows Updates?..
Top Bottom
