How do I bypass oobe with dism?
If DISM captures a system image, can't I simply bypass oobe all together?
Thanks so much
Joe
Not in the way you’re thinking, no.
Why DISM “capture” doesn’t really bypass OOBE​
  • DISM /Capture-Image just captures whatever is currently on disk into a WIM. If you capture a Windows installation after you’ve already completed OOBE, then when you re-apply that image you’ll basically be restoring a system that’s already past OOBE.
  • But that’s not a clean/normal “installation” anymore — it’s effectively cloning a machine state (including machine-specific IDs, drivers, cached provisioning, sometimes user profiles, etc.. That approach is fine for a lab VM you control, but it’s a bad idea for deploying to multiple machines unless you properly generalize it.
This is why deployment...
This is why deployment best-practice is: customize in Audit Mode → Sysprep /generalize → capture → deploy → automate OOBE with unattend (you don’t “skip” OOBE so much as make it silent/automatic).
Two common scenarios (pick yours)​
A) You just want a reusable Hyper‑V VM (fastest, simplest)​
If your goal is “I want Windows set up once and never click through OOBE again” for your own Hyper‑V testing, then don’t fight OOBE with DISM—just:
  • Install Windows once, complete OOBE, configure it how you like
  • Then use Hyper‑V checkpoints and/or export the VM and re-import/copy the VHDX for new test VMs
That avoids the whole “capturing/install.wim” path entirely.
B) You want a “deployable” Windows image (repeatable installs)​
Then the supported path is:
  • Boot Windows into Audit Mode (Ctrl+Shift+F3 at OOBE)
  • Customize (apps, settings, updates)
  • Run Sysprep with /generalize (so it’s safe to deploy)
  • Capture the image (DISM capture to WIM)
  • Use autounattend.xml so OOBE runs but is automated (skip/hide pages, create user, set region, etc.
    People do exactly this kind of workflow when building a “custom ISO” by capturing a new install.wim from a VM’s customized state and then rebuilding media around it.
Important warning (so you don’t waste time)​
If you don’t run Sysprep /generalize and you just capture a “finished” Windows, you may appear to have “bypassed OOBE”… but you’ve actually created a clone-image with deployment problems (SID duplication, weird activation behavior, driver mismatch across hardware, etc.. Even WindowsForum guidance around “system images” calls out hardware difference and generalization concerns.
Quick question so I can give the exact steps​
Are you trying to:
  • Speed up repeated Hyper‑V test VMs (same host, same virtual hardware), or
  • Build installation media / an image you can deploy to multiple different machines/VMs?
    If you tell me which one, I’ll reply with the clean step-by-step and the exact commands (Sysprep + DISM capture/apply + where to place autounattend.xml).
