- Thread Author
- #1
I've recently been experiencing a reboot of my windows 10 PC with the above error message in events viewer. A few websites I've looked at have mentioned its related to out of date drivers so I've gone through all the obvious ones and they're all up to date. Does anyone know how I can fix this as I find my PC is rebooting with this error at least once a week over the last month or so?
Thanks in advance
I've copied below info from the event log
- System
- Provider
Microsoft-Windows-Kernel-Power
{331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 41
Version 6
Level 1
Task 63
Opcode 0
Keywords 0x8000400000000002
- TimeCreated
2018-04-11T20:07:21.667060200Z
EventRecordID 3748
Correlation
- Execution
4
8
Channel System
Computer SOPQVF1
- Security
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress 0
PowerButtonTimestamp 0
BootAppStatus 0
Checkpoint 0
ConnectedStandbyInProgress false
SystemSleepTransitionsToOn 6
CsEntryScenarioInstanceId 0
BugcheckInfoFromEFI true
CheckpointStatus 0
I've noticed after the PC has reset the following occurs a number of times...
Processor 0 in group 0 exposes the following power management capabilities:
Idle state type: ACPI Idle (C) States (2 state(s))
Performance state type: ACPI Performance (P) / Throttle (T) States
Nominal Frequency (MHz): 3500
Maximum performance percentage: 100
Minimum performance percentage: 40
Minimum throttle percentage: 40
- System
- Provider
Microsoft-Windows-Kernel-Processor-Power
{0F67E49F-FE51-4E9F-B490-6F2948CC6027}
EventID 55
Version 0
Level 4
Task 47
Opcode 0
Keywords 0x8000000000000000
- TimeCreated
2018-04-11T20:07:22.050563300Z
EventRecordID 3750
Correlation
- Execution
4
372
Channel System
Computer
- Security
- EventData
Group 0
Number 0
IdleStateCount 2
IdleImplementation 1
NominalFrequency 3500
MaximumPerformancePercent 100
MinimumPerformancePercent 40
MinimumThrottlePercent 40
PerformanceImplementation 1
Thanks in advance
- System
- Provider
EventID 41
Version 6
Level 1
Task 63
Opcode 0
- TimeCreated
EventRecordID 3748
Correlation
- Execution
4
8
Channel System
Computer SOPQVF1
- Security
- EventData
BugcheckCode 0
SleepInProgress 0
BootAppStatus 0
Checkpoint 0
CheckpointStatus 0
- System
- Provider
EventID 55
Version 0
Level 4
Task 47
Opcode 0
- TimeCreated
EventRecordID 3750
Correlation
- Execution
4
372
Channel System
Computer
- Security
- EventData
Group 0
Number 0
IdleStateCount 2
