Windows 10 How do I get rid of this Power shutdown confirmation dialog?
FireMarshalBill69
An image from 'How do I get rid of this Power shutdown confirmation dialog?'. Windows 10 shutdown prompt displayed over a dog background image with a cursor on 'OK'.
Are you running an older Windows 10?? Type winver in the run command and post it here. I haven't seen that shutdown in a long time. Are you shutting down with this Link Removed script?
Lance1
Honorable Member
