abrogard
- Joined
- Mar 5, 2015
I've never understood how the Serials thing works.
And I've had all kinds of hassles with it over the years with different O/S's and upgrades and second hand machines and broken machine needing repair and reinstalls and whatever...
Is there a clear outline of it somewhere?
Say I have a machine at home and I install Windows on it. Then I take that serial over to another machine at home and I try to make another installation and use that serial again it won't work, will it? I don't think it will.
Now if that first machine crashes - say system disk crash for instance, or mobo failure - then I have to rebuild that machine and install Windows. Now this time it will accept the serial, won't it? Or won't it?
I think it will. I think I've done it in the past. I've done nearly everything over time without ever thinking about it.
But how does MS know when I try to put on a second machine that it is already on one machine (that might be switched off, might not have been used for days, weeks) - and then knows in the other case that it is not on any other machine?
I am obviously wildly confused about the whole thing.
So how can I get a clear knowledge?
