Keeping track of your laptop’s battery level is crucial for uninterrupted productivity—especially for Windows 11 users who work on-the-go and can’t always predict when a power outlet will be within reach. While Windows 11 offers a built-in low battery warning system, users often find themselves wishing for more customization or additional, more noticeable alerts. Whether you're a road warrior, a gamer, or just want peace of mind against sudden shutdowns, understanding and customizing low battery alerts on Windows 11 can be a gamechanger.
Laptop displaying a warning message about a low battery stand on the screen.Understanding Windows 11’s Standard Low Battery Notifications​
By default, Windows 11 comes with a basic low battery alert mechanism that provides visual notifications when your battery reaches a critical threshold. These notifications generally appear as a subtle sliding message near the system tray. While helpful, this built-in alert has several notable limitations:
  • Lack of Customization: The default low battery alert can only be set to predefined percentages, and the notification style (system tray popup) can't be altered natively.
  • Limited Notification Styles: No out-of-the-box support for more prominent notifications, recurring reminders, or personalized alert messages.
  • Per-Power Plan Settings: Battery alert configurations are tied to individual power plans, so switching plans can unintentionally reset your preferences.
For users who want to truly optimize their workflow, these constraints may be significant. Fortunately, Windows offers avenues for deeper customization—either through the system’s advanced settings or through clever use of automation tools like Task Scheduler and PowerShell scripts.
Configuring Built-In Battery Alerts: The Control Panel Method​
The quickest way to ensure you’re notified as your battery level drops is to tweak the existing low battery alert within Windows 11's power settings. Here’s how to do it:
  • Open Control Panel: Press Windows+S, type “Control Panel,” and launch the app.
  • Navigate to Power Options: Select “Hardware and Sound,” then choose “Power Options.”
  • Edit Your Active Power Plan: Next to your current plan, click “Change Plan Settings.”
  • Go to Advanced Settings: Click “Change Advanced Power Settings.”
  • Configure the Battery Section: Scroll to the bottom and expand the “Battery” section. Expand “Low Battery Level” and set your desired percentage for both “On Battery” and “Plugged In.”
  • Enable Notifications: Under “Low Battery Notification,” make sure both “On Battery” and “Plugged In” are set to “On.”
  • Apply and Save: Click “Apply,” then “OK” to implement your changes.
Key Details and Limitations​
  • The system tray notification is easy to miss, particularly in the midst of a busy desktop, gaming session, or if Focus Assist is enabled.
  • These settings are per power plan. If you routinely switch between Balanced, Power Saver, or High Performance plans, you’ll need to repeat these steps for each one.
  • There’s no ability to customize the sound or visual prominence of the alert—something many advanced users lament.
Creating a Custom Low Battery Toast Notification with Task Scheduler​
For users who crave a more prominent, customizable, or recurring alert, Task Scheduler combined with a purpose-built PowerShell script provides a robust workaround. Here’s a step-by-step rundown validated against community and Microsoft documentation:
Writing a PowerShell Script for Toast Notifications​
Open Notepad and paste the following PowerShell code, customizing the “30” in the script to your preferred battery percentage:
$Battery = Get-WmiObject -Class Win32_Battery
$Level = $Battery.EstimatedChargeRemaining
if ($Level -lt 30) {
    [Windows.UI.Notifications.ToastNotificationManager, Windows.UI.Notifications, ContentType = WindowsRuntime]
    $template = [Windows.UI.Notifications.ToastNotificationManager]::GetTemplateContent([Windows.UI.Notifications.ToastTemplateType]::ToastText01)
    $toast = $template.GetElementsByTagName("text")[0]
    $toast.AppendChild($template.CreateTextNode("Battery below 30%! Please plug in your charger."))
    $notifier = [Windows.UI.Notifications.ToastNotificationManager]::CreateToastNotifier("Battery Alert")
    $notifier.Show([Windows.UI.Notifications.ToastNotification]::new($template))
  • Save As: Choose “All Files” as the type, and name the file BatteryAlert.ps1.
  • Choose a Permanent Location: Avoid moving this file later; Task Scheduler will need its path unchanged.
Scheduling Recurring Alerts with Task Scheduler​
  • Launch Task Scheduler: Press Windows+S, search for “Task Scheduler,” and open it.
  • Create a New Task: Click “Create Task” on the right pane.
  • Name and Security: Enter a descriptive name (e.g., “Low Battery Level Alert”) and select “Run whether user is logged on or not.”
  • Trigger Setup: Go to the “Triggers” tab, click “New,” select “On a Schedule,” and enable “Repeat Task Every” with a 5-minute interval.
  • Action Setup: In the “Actions” tab, click “New,” select ‘Start a Program,’ and enter powershell.exe in the “Program/Script” box. In the “Add arguments” field, use:
    -ExecutionPolicy Bypass -File "C:\Path\To\Your\BatteryAlert.ps1"
  • Save and Authenticate: Complete setup by clicking “OK” and entering your account password as prompted.
Important: If you move or rename the script, update its path in Task Scheduler, or the alert will fail to appear.
How This Method Works​
  • The scheduled task will run your PowerShell script at the desired interval (every 5 minutes by default), checking the battery level.
  • If it dips below your preset percentage, a Windows 11 toast notification will pop up—much more noticeable than the standard system tray alert.
  • You can easily modify the script message, level, or recurrence to suit your workflow.
Disabling or Deleting the Alert​
If at any point you wish to pause or stop the notifications:
  • Pause: Right-click the task in Task Scheduler and select “Disable.”
  • Remove: Right-click and select “Delete.”
Advanced Alternatives and Third-Party Options​
For power users, developers, or those seeking further customization, multiple third-party tools and scripts exist that provide granular control over battery alerts, blending notification styles, voice alerts, emails, or even OS-level actions (like auto-hibernate). However, these introduce potential security and compatibility risks.
  • BatteryBar Pro, BatteryCare, and Smarter Battery: These popular apps can offer more insightful battery stats, health data, and customizable notifications. Always verify software integrity and scan for malware before installation.
  • Custom Scripts: Tech-savvy users might integrate battery alerts with broader automation, such as sending warning emails, triggering shutdown, or logging data for analysis. When invoking scripts, ensure proper permissions and audit code for safe operation.
Security and Reliability Considerations​
Whenever using PowerShell scripts or third-party programs, follow these best practices:
  • Source Verification: Only run scripts and apps from trusted sources. Malicious scripts can access sensitive data or disrupt your system.
  • Controlled Permissions: Avoid running scripts with unnecessary elevated privileges.
  • Testing: Thoroughly test your script and scheduled task to confirm reliable operation without false positives or unexpected behavior.
Analyzing the Pros and Cons of Custom Battery Alerts​
Notable Strengths​
  • Tailored Experience: The manual PowerShell+Task Scheduler approach delivers a far more prominent, persistent, and customizable notification than Windows’ default tools.
  • Automation: Recurring triggers mean you can “set and forget” your alert system, reducing the risk of accidental shutdown.
  • Granularity: Control the exact battery percentage, repeat rate, and alert message content—valuable for complex workflows or accessibility needs.
Possible Drawbacks and Risks​
  • Setup Complexity: The method requires comfort with scripting and Windows’ administrative interfaces. Less technical users may find the process daunting.
  • Potential for Missed Alerts: Misconfiguration or moving the script file can break the notification system without clear feedback.
  • Resource Use: Running a script every few minutes does cause minor resource overhead, though negligible on modern hardware.
  • Security Implications: Insecure scripts or downloaded tools can compromise system integrity if not vetted.
  • Notification Fatigue: Overly-frequent reminders may become annoying or ignored—striking a balance is crucial.
Best Practices for Managing Battery Life on Windows 11​
Custom alerts are just one piece of the puzzle when it comes to battery management. Consider these broader strategies for extending your laptop’s runtime:
  • Use Power Saver Mode: This built-in profile automatically reduces background activity and limits resource-intensive features.
  • Lower Display Brightness: Dimming your screen is one of the quickest ways to preserve battery life.
  • Close Unused Apps and Processes: Fewer programs mean less processor, RAM, and disk usage.
  • Enable Battery Saver Settings: Windows 11 offers various tweaks under Settings > System > Power & Battery.
  • Monitor Battery Health: Periodically check battery wear levels using powercfg /batteryreport or third-party tools; replace batteries that show severe degradation.
SEO Tips: Enhance Visibility with the Right Phrasing​
When sharing guides or troubleshooting advice on this subject, using targeted, descriptive phrases consistently throughout your content can help other Windows 11 users find the guidance they need. For example:
  • “Set custom low battery alert on Windows 11”
  • “How to get pop-up battery warnings in Windows 11”
  • “Automate battery notifications with PowerShell and Task Scheduler”
  • “More visible low battery warnings Windows laptop”
  • “Windows 11 battery management tools and tips”
The Bottom Line​
Customizing low battery alerts on Windows 11 is not only possible—it’s a practical step for anyone who depends on their device for work, study, or entertainment. While Microsoft’s default notifications cover the basics, power users benefit enormously from unlocking advanced alerting via Task Scheduler, PowerShell, or reputable third-party apps. By understanding both the strengths and limitations of each approach, and following best practices for script usage and battery care, you can ensure your Windows 11 laptop supports you reliably—without surprise power interruptions.
Being proactive about battery alerts is key, but it’s just as important to remain vigilant about security with custom scripts and to calibrate your alerting frequency to avoid unnecessary distractions. With a thoughtful setup, you can strike the right balance and keep productivity rolling, wherever your day—and your laptop—takes you.
Source: How-To Geek How to Set Custom Low Battery Alerts on Windows 11
