how to disable usb power in standby?
Discussion in 'Windows 7 Hardware' started by unknown00, Sep 21, 2009.
  1. unknown00
    unknown00 New Member
    Sep 20, 2009
    24
    0
    so i usually have an external plugged in and i usually put my laptop (a hp dv5t) to sleep mode at night, but the external harddrive still stays on.
    how do i disable usb power in standby mode? i already went into advance power options and couldn't find anything. also, in power settings, USB selective suspend is enabled
  2. ref
    ref Banned
    Jun 1, 2009
    54
    1
    go to device manager right click Usb hub you want to disable>select properties>select the tab with power management and check the box that says allow computer to switch of this device to save power!!
  3. unknown00
    Sep 20, 2009
    24
    0
    in device manager i have 18 different usb devices...how do i know what is what?
    [​IMG]
    #3 unknown00, Sep 21, 2009
  4. ref
    ref Banned
    Jun 1, 2009
    54
    1
    guess it's the 8 intel hubs but to know witch one is connected to your HD is a hassle google for a software that maps them for you!
  5. unknown00
    Sep 20, 2009
    24
    0
    any software you can recommend? also, i only have 4 usb slots...
  6. unknown00
    Sep 20, 2009
    24
    0
    bump ttt anyone?
  7. unknown00
    Sep 20, 2009
    24
    0
    bump ttt anyone?
Share This Page
Loading...
