Assume I setup a task in Task Scheduler.
It appears in Task Scheduler as active task with the status "Ready".
Now I want to edit this task e.g. the name of the task.
How can I achive this?
If I mark e.g. the task in task list or double click on it then I still can not edit the entry field "Name" in tab "General".
When I disable the task then the status switches to "disabled" but the name is still NOT editable.
So how can I edit name or triggers or conditions for an existing task otherwise?
