Windows 7 how to remove acrotray (and other start up services)
Hi everyone,
I like to keep my comp to boot up as clean as possible. I have a problem whenever I remove acrotray or itunes serviecs in Start up. I already remove it from MSCONFIG.
The problem is the next time I log in, it will generate a second acrotray startup. This second item will be checked and it is loaded as well.
Is there a way I can remove it from loading during start up once and for all? I suspect i might have to edit registry key. Just not sure where to go about doing that.
As I mentioned before, this second loading also happen to iTune as well.
Thanks!
Cliff
You also need to go to Task Manager>>> Processes tab>>> highlight "Acrotray.exe" and click "End Process" button on the bottom right corner of the Task Manager window. Restart your PC.
A generally good and simple tool is Revo Uninstaller. It gives the possibility to control autoruns.
