Windows 7 How to set an environment variable PERMANENT from cmdline?
pstein
If I open a CmdPrompt and type
set myvar=foobar
then this environment variable is set only for the time the CmdPrompt exists and is only visible INSIDE the CmdPrompt.
How do I set such an environemnt variable from CmdPrompt (!) but permanently (forever) for
- a certain user
- whole system/computer?
Again: I don't want t use Windows GUI to set the var. Everything should take place from cmdline.
Entering a var value to Registry would be acceptable as well.
How does it work?
Peter
Josephur
Windows Forum Admin
setx works great, however when I have used it before it seemed the variable did not take effect in the current command prompt space, upon launching a new command prompt however the variable was there and contained the value.
e.g. "setx test foobar", then type set and you may not see the variable there as a system variable. However if you run a new command prompt, and type set you will see that TEST=foobar.
Josephur
Windows Forum Admin
You may also want to look at SETLOCAL and ENDLOCAL commands within a batch script. They do not do exactly what you want, but they do allow a subscript to be called within the current one, that can set a variable for the current command space, therefore that variable lives until the originating .bat or .cmd file is closed.
This may allow you to pass variables between sub scripts, and not store them permanently. If you absolutely need permanent variable then setx seems to be the way to go, however you would have to launch a new cmd.exe afterwards to see the variable.
