Windows 10 I Can't Connect To Some Wifi Access Points
TreeHugger829
I have a bunch of xfinitywifi connections around me, but I can't connect to the top 2 on the list in my image. I can connect, but when I do, a yellow exclamation point icon is displayed over my wifi icon and it says no internet, and I can't actually load any web pages. I can however connect to the third xfinity wifi connection in my image, but it has a much weaker signal than the top two, so I'd prefer to connect to one of them. Does anyone know what the problem is? Does the fact that they're on different channels have anything to do with it? Can I only connect to things on channel 11 and not 6 or 1?
You can connect to access points on any channel. Keep in mind these "Xfinity" access points require that you login or pay to access them which is why they don't just allow access, you need to pay or authenticate if you are an Xfinity customer through the web portal that should load when you connect to them.
Neemobeer
Windows Forum Team
