Windows 8 I have an issue
Jakob Riley Gilman
Today I was using Ventrilo and I was trying to reduce the background noise it was picking up. But, on accident i deleted something and now I cant use my integrated laptop microphone. I'm not sure exactly sure what I deleted but I need a way to get it back. The thing I deleted was located by right-clicking on the speaker in the lower right hand corner then going into recording devices and under recording I right clicked and then pressed disable on accident on a device and now it is gone. If you have any way of fixing this other than sending it in please help me. :hopelessness:
Trouble
Noob Whisperer
Hello Jakob and welcome to the forum.
See if this works for you. In the same location, just right click anywhere in the blank / white area and select "show disabled devices. Then right click and re-enable it.
That should be it and you should be good to go.
Regards
Randy
