I need help
So I erased my whole drive windows and all, by mistake. Now I don't have a windows disk, and I have no idea what to do. Assistance please?
Josephur
Windows Forum Admin
Well one option would be to use the Windows 10 Download tool to make a bootable USB which should accept your Windows 7 (non enterprise) serial number to allow you to do a fresh install of Windows 10.
bochane
Honorable Member
Most PCs and laptops have a recovery partition. If it is still there, changes are good if you only formatted the C drive, you may be able to start a recovery to factory setting by using some control-key during start up. Look in the (on-line) manual.
But the option of Josephur is the better one
