Windows 7 Infrequent BSOD's - suspect browser-related issue, not sure
sothix
It's hard to reproduce.
It seems I get a BSOD randomly when doing something in a browser. I switch between Chrome and Firefox mainly. At first I suspected Flash, and even recently updated it to the latest 10.2 (for Firefox, since Chrome automatically updated itself). But today I got a BSOD and was not on a Flash enabled site.
Some mini dump files attached in a ZIP file -- any help or tips appreciated! When looking at the logs myself, the last line in these dumps yield:
Probably caused by : ntoskrnl.exe ( nt+748b6 )
Frequency - I can go several days in between BSOD's. Running Windows 7 64bit Ultimate with all Windows Updates applied.
I have a lot of crap installed, and am not adverse to just re-installing from scratch but would like to know what the culprit is so I can avoid installing that piece.
The shorter workaround can be update Realtek LAN and uninstall (instead of update) Shrew Soft IM, LogMeIn, and RemotelyAnywhere.
Your latest crash was caused by Shrew Soft IM.
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\021111-21886-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by...
021111-21886-01.dmp
BugCheck A, {0, 2, 0, fffff80002c808b6}
Unable to load image \SystemRoot\system32\DRIVERS\vfilter.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for vfilter.sys
*** ERROR: Module load completed but symbols could not be loaded for vfilter.sys
Probably caused by : vfilter.sys ( vfilter+29a6 )
Update or uninstall:
Shrew Soft IM,
vfilter.sys Wed Nov 18 19:06:23 2009
LogMeIn,
lmimirr.sys 10/04/2007
RemotelyAnywhere,
RaInfo.sys 04/01/2008
VMWare,
vmnetbridge.sys 10/08/2009
Update Realtek LAN,
Rt64win7.sys 26/02/2009
Crash Dumps:
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02c0c000 PsLoadedModuleList = 0xfffff800`02e49e50
Debug session time: Fri Feb 11 09:43:52.159 2011 (UTC - 5:00)
System Uptime: 0 days 0:21:34.964
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
1: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff80002c808b6, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002eb40e0
 0000000000000000
CURRENT_IRQL:  2
FAULTING_IP:
nt!KeSetEvent+226
fffff800`02c808b6 488b09          mov     rcx,qword ptr [rcx]
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xA
PROCESS_NAME:  svchost.exe
TRAP_FRAME:  fffff88006369c10 -- (.trap 0xfffff88006369c10)
rax=fffffa800581e658 rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000000001 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002c808b6 rsp=fffff88006369da0 rbp=0000000000000002
 r8=0000000000000000  r9=0000000000000000 r10=0000000000000000
r11=0000000000000002 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz ac pe cy
nt!KeSetEvent+0x226:
fffff800`02c808b6 488b09          mov     rcx,qword ptr [rcx] ds:0002:00000000`00000000=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002c7bca9 to fffff80002c7c740
STACK_TEXT:
fffff880`06369ac8 fffff800`02c7bca9 : 00000000`0000000a 00000000`00000000 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`06369ad0 fffff800`02c7a920 : 00000000`00000000 fffffa80`0581e650 00000000`d6d70035 fffffa80`06055000 : nt!KiBugCheckDispatch+0x69
fffff880`06369c10 fffff800`02c808b6 : fffff880`06369e10 fffff880`02d31b0e 00000000`00000052 fffff880`06369e90 : nt!KiPageFault+0x260
fffff880`06369da0 fffff880`02d319a6 : fffffa80`00000000 00000000`00000000 00000000`00000000 fffffa80`0581e640 : nt!KeSetEvent+0x226
fffff880`06369e10 fffffa80`00000000 : 00000000`00000000 00000000`00000000 fffffa80`0581e640 00000000`00000000 : vfilter+0x29a6
fffff880`06369e18 00000000`00000000 : 00000000`00000000 fffffa80`0581e640 00000000`00000000 fffff880`02d3142b : 0xfffffa80`00000000
STACK_COMMAND:  kb
FOLLOWUP_IP:
vfilter+29a6
fffff880`02d319a6 ??              ???
SYMBOL_STACK_INDEX:  4
SYMBOL_NAME:  vfilter+29a6
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: vfilter
IMAGE_NAME:  vfilter.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4b048bff
FAILURE_BUCKET_ID:  X64_0xA_vfilter+29a6
Drivers:
fffff880`10b72000 fffff880`10bb0000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f35000 fffff880`00f8c000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02c26000 fffff880`02cb0000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`10bc2000 fffff880`10bd8000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00ff4000 fffff880`00fff000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`03edd000 fffff880`03ee5000   AppleCharger AppleCharger.sys Mon Apr 26 23:54:05 2010 (4BD65FDD)
fffff880`069ed000 fffff880`069f8000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00e78000 fffff880`00e81000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00daf000 fffff880`00dd9000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff960`008a0000 fffff960`00901000   ATMFD    ATMFD.DLL    Fri Jan 07 00:49:20 2011 (4D26A960)
fffff880`019e1000 fffff880`019e8000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03ecc000 fffff880`03edd000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`05ad1000 fffff880`05aef000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006f0000 fffff960`00717000   cdd      cdd.dll      unavailable (00000000)
fffff880`019ae000 fffff880`019d8000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01948000 fffff880`01978000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d27000 fffff880`00d85000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01178000 fffff880`011eb000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`040ba000 fffff880`040ca000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`05fc0000 fffff880`05fc9000   cpuz133_x64 cpuz133_x64.sys Tue May 11 05:58:57 2010 (4BE92A61)
fffff880`05348000 fffff880`05356000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03e2b000 fffff880`03eae000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03eae000 fffff880`03ecc000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02c00000 fffff880`02c0f000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01932000 fffff880`01948000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05320000 fffff880`05342000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`05362000 fffff880`0536b000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`05356000 fffff880`05362000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0536b000 fffff880`0537e000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`053f3000 fffff880`053ff000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`040cc000 fffff880`041c0000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`04000000 fffff880`04046000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`03a01000 fffff880`03ad8000   eamonm   eamonm.sys   Wed Jul 14 04:13:43 2010 (4C3D71B7)
fffff880`01800000 fffff880`01825000   ehdrv    ehdrv.sys    Wed Jul 14 04:14:21 2010 (4C3D71DD)
fffff880`03af9000 fffff880`03b26000   epfw     epfw.sys     Wed Jul 14 04:10:34 2010 (4C3D70FA)
fffff880`10bb7000 fffff880`10bc2000   Epfwndis Epfwndis.sys Wed Jul 14 04:10:31 2010 (4C3D70F7)
fffff880`05fc9000 fffff880`05fda000   epfwwfp  epfwwfp.sys  Wed Jul 14 04:10:34 2010 (4C3D70FA)
fffff880`01106000 fffff880`0111a000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010ba000 fffff880`01106000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`018f8000 fffff880`01932000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01595000 fffff880`015df000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`041f0000 fffff880`041fd000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`031e9000 fffff800`03232000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`05ba5000 fffff880`05bb1000   hcmon    hcmon.sys    Tue Sep 21 03:56:08 2010 (4C986518)
fffff880`041c0000 fffff880`041e4000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`05287000 fffff880`052e3000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`0538c000 fffff880`053a5000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`053a5000 fffff880`053ad080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0537e000 fffff880`0538c000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`05a09000 fffff880`05ad1000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`015f7000 fffff880`01600000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`03f0b000 fffff880`03f21000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0fe9c000 fffff880`0feab000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`053da000 fffff880`053e8000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00b9a000 fffff800`00ba4000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`03f30000 fffff880`03f73000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`0156a000 fffff880`01595000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`05342000 fffff880`05347200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`03b36000 fffff880`03b4b000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`10bb0000 fffff880`10bb7000   lmimirr  lmimirr.sys  Tue Apr 10 18:32:45 2007 (461C108D)
fffff880`05fe1000 fffff880`05ff4000   LMIRfsDriver LMIRfsDriver.sys Mon Jul 14 12:26:56 2008 (487B7E50)
fffff880`0520e000 fffff880`05231000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00ccf000 fffff880`00d13000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`05200000 fffff880`0520e000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`03f21000 fffff880`03f30000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`053b0000 fffff880`053bd000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00d95000 fffff880`00daf000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`05aef000 fffff880`05b07000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`05b07000 fffff880`05b34000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`05b34000 fffff880`05b82000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`05b82000 fffff880`05ba5000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`01883000 fffff880`0188e000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f95000 fffff880`00f9f000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0111a000 fffff880`01178000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02df1000 fffff880`02dfc000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01400000 fffff880`01412000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01418000 fffff880`0150a000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0fe00000 fffff880`0fe0c000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`068e9000 fffff880`068fc000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`0fe0c000 fffff880`0fe3b000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`03e00000 fffff880`03e15000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02d39000 fffff880`02d48000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02cb0000 fffff880`02cf5000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0150a000 fffff880`0156a000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`0188e000 fffff880`0189f000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02de5000 fffff880`02df1000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c0c000 fffff800`031e9000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`01251000 fffff880`013f4000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`019d8000 fffff880`019e1000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`10b3e000 fffff880`10b3f180   nvBridge nvBridge.kmd Fri Jul 09 17:07:54 2010 (4C378FAA)
fffff880`0feac000 fffff880`10b3de00   nvlddmkm nvlddmkm.sys Fri Jul 09 17:15:58 2010 (4C37918E)
fffff880`06896000 fffff880`068e9000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02d09000 fffff880`02d2f000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00fdf000 fffff880`00ff4000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f9f000 fffff880`00fd2000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e71000 fffff880`00e78000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00d85000 fffff880`00d95000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`05e00000 fffff880`05ea6000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`052e3000 fffff880`05320000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00d13000 fffff880`00d27000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`05fda000 fffff880`05fe1000   RaInfo   RaInfo.sys   Fri Jan 04 13:57:14 2008 (477E818A)
fffff880`10bd8000 fffff880`10bfc000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0fe3b000 fffff880`0fe56000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`0fe56000 fffff880`0fe77000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`0fe77000 fffff880`0fe91000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02d94000 fffff880`02de5000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`0fe91000 fffff880`0fe9c000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01868000 fffff880`01871000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`068fc000 fffff880`0692a000   rdpdr    rdpdr.sys    Mon Jul 13 20:18:02 2009 (4A5BCEBA)
fffff880`01871000 fffff880`0187a000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0187a000 fffff880`01883000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`06944000 fffff880`0697c000   RDPWD    RDPWD.SYS    Mon Jul 13 20:16:47 2009 (4A5BCE6F)
fffff880`0104c000 fffff880`01086000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`03b4b000 fffff880`03b63000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`10b40000 fffff880`10b72000   Rt64win7 Rt64win7.sys Thu Feb 26 04:04:13 2009 (49A65B0D)
fffff880`05ea6000 fffff880`05eb1000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`041e4000 fffff880`041f0000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02d48000 fffff880`02d65000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`015ef000 fffff880`015f7000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`06800000 fffff880`06896000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`03b63000 fffff880`03bca000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`05eb1000 fffff880`05ede000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`040ca000 fffff880`040cb480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`05bc9000 fffff880`05bdb000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`018bd000 fffff880`018ca000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`0692a000 fffff880`06935000   tdtcp    tdtcp.sys    Mon Jul 13 20:16:32 2009 (4A5BCE60)
fffff880`0189f000 fffff880`018bd000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02d80000 fffff880`02d94000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`004c0000 fffff960`004ca000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`06935000 fffff880`06944000   tssecsrv tssecsrv.sys Mon Jul 13 20:16:41 2009 (4A5BCE69)
fffff880`03ee5000 fffff880`03f0b000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`03f73000 fffff880`03f85000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`053bd000 fffff880`053da000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`053ae000 fffff880`053aff00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`040a9000 fffff880`040ba000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`03f97000 fffff880`03ff1000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04053000 fffff880`040a9000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`04046000 fffff880`04053000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00fd2000 fffff880`00fdf000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02d2f000 fffff880`02d39000   vfilter  vfilter.sys  Wed Nov 18 19:06:23 2009 (4B048BFF)
fffff880`01825000 fffff880`01833000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01833000 fffff880`01858000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`05bb1000 fffff880`05bc9000   vmci     vmci.sys     Tue Sep 21 03:24:22 2010 (4C985DA6)
fffff880`053e8000 fffff880`053f3000   VMkbd    VMkbd.sys    Tue Sep 21 04:46:23 2010 (4C9870DF)
fffff880`03f8d000 fffff880`03f97000   VMNET    VMNET.SYS    Mon Aug 10 08:04:50 2009 (4A800CE2)
fffff880`03f85000 fffff880`03f8d000   vmnetadapter vmnetadapter.sys Mon Aug 10 08:04:53 2009 (4A800CE5)
fffff880`03b26000 fffff880`03b36000   vmnetbridge vmnetbridge.sys Mon Aug 10 08:05:58 2009 (4A800D26)
fffff880`05ede000 fffff880`05ee8000   vmnetuserif vmnetuserif.sys Tue Sep 21 04:10:42 2010 (4C986882)
fffff880`015df000 fffff880`015ef000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`05eea000 fffff880`05fc0000   vmx86    vmx86.sys    Tue Sep 21 05:33:47 2010 (4C987BFB)
fffff880`00e00000 fffff880`00e15000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e15000 fffff880`00e71000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01000000 fffff880`0104c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`05ff4000 fffff880`06000000   vstor2_ws60 vstor2-ws60.sys Thu Aug 19 16:28:39 2010 (4C6D93F7)
fffff880`02d65000 fffff880`02d80000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01858000 fffff880`01868000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e82000 fffff880`00f26000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f26000 fffff880`00f35000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d00000 fffff880`02d09000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000f0000 fffff960`00400000   win32k   win32k.sys   Tue Jan 04 22:59:44 2011 (4D23ECB0)
fffff880`00f8c000 fffff880`00f95000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`02cf5000 fffff880`02d00000   ws2ifsl  ws2ifsl.sys  Mon Jul 13 20:10:33 2009 (4A5BCCF9)
fffff880`03ad8000 fffff880`03af9000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`0697c000 fffff880`069ed000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01978000 fffff880`01986000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01986000 fffff880`01992000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01992000 fffff880`0199b000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`0199b000 fffff880`019ae000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
