vindicadi198
- Joined
- Nov 19, 2008
- Messages
- 4
- Thread Author
- #1
vindicadi198
- Joined
- Nov 19, 2008
- Messages
- 4
- Thread Author
- #3
Matt
- Joined
- May 7, 2007
- Messages
- 861
Just Another Statistic
- Joined
- Jan 1, 2009
- Messages
- 8
crazy_cjenkins
- Joined
- Jan 11, 2009
- Messages
- 68
I tried to do the same with build 6801 back in October and It won't allow you to install it on a portable device unless it's sata no matter what computer you have. There is a way because microsoft did it at the PDC, but it can't be done through the installer. I haven't tried build 7000 yet (still downloading) but if I had to guess it probably won't either unless they have changed the Installer. If your computer is less than 3 or 4 years old It will boot from usb. you can check by going int the bios under "Boot Device Priority" and check to see if "USB" or "Removable Device" is listed there.
Similar threads
- Solved
- Replies
- 0
- Views
- 40
- Replies
- 0
- Views
- 78
- Replies
- 0
- Views
- 157
- Article
- Replies
- 0
- Views
- 66
- Article
- Replies
- 0
- Views
- 78
