- Thread Author
- #1
Hi
Have i7 with Hardisks.
Disk 1 has Windows 7 installed successfully. The other 3 disks are data disks.
2 of the 3 data disks are fine but 1 has somehow messed up.
The problem is the data disk which is/was 200gb seems to have converted itself to a RAW disk in data manager and in the desktop array it says corrupt needs formatting.
I have done nothing that I am aware of except prior to activating W7 I backed up to another spare disk, external...only thing that has changed.
Rebooted the machine, recovered the backup W7 installation and activated but none of this seemed to or should have affected the disk that is now RAW data in computer disk management.
The other point is the drive is showing as 94gb RAW data. I have activated it in in computer management with the hope of activating allow access to the data, but I have not formatted it.
Can anyone help please as I need to get the data back?
Can anyone help explain why the drive formerly NTFS has mysteriously converted to RAW format?
Anyone had any experience or ideas what needs ot be done and to avoid this in the future.
Really appreciate any help.
Many many thanks in advance
M
M
