Insufficient Resources
Flupsie
Well-Known Member
Usually after I have run a macro on Excel and truy to open up another workbook , I get a message "Insufficient resources" I use Windows 7 and Office 2010 and have 4GB of RAM.
It would be appreciated if someone could help me resolve this issue
patcooke
Microsoft MVP
Microsoft MVP
Because of the reasons outlined here:
Excel Memory Limits - Decision Models
Excel will always, sooner or later, hit its limit.
You may find some of the in-depth knowledge here helpful in optimising your spreadsheet (it is specifically aimed at Excell 2007 but will also apply to other versions in most cases):
Improving Performance in Excel 2007
Saltgrass
You don't have problems opening workbooks if you do not run the Macro? What type of Macro is it and where did it come from?
Flupsie
Well-Known Member
I think that i may have resolved the problem. Within my macro I usually have application.screenupdating = false which uses a lot of resources
I have taken out this line of code on some of my workbooks and so far it seems to mnot be causing the problem with 'insufficient resources
Flupsie
Well-Known Member
Hi Pat
I eventually resolved the problem a week ago. I engaged the services of an IT professional. At the start button he ran msconfig and disabled non-essential programs at start up, such as Skype, Nero etc that use a lot of resources. He also loaded a memory optimiser. I can now run macro and open several workbooks without encountering any problems. I have tested this for a week now
patcooke
Microsoft MVP
Microsoft MVP
Well done - freeing up all the resources you have will make much more available and reduce the likelihood that you will hit the limit again. Msconfig is the standard method for managing startup apps but another MS product, autoruns, free from the link below is a much more powerful and comprehensive manager which you might find useful for monitoring startups:
Autoruns for Windows
Flupsie
Well-Known Member
#7
Thanks for the reply and the link for autoruns. I will definately make use of this
#8
You mentioned Nero. If, you are running Windows 7, there is no need for Nero or any burning software since 7 does everything natively & there is no longer need for adding burning software. 7 will, even burn ISOs by itself & direct burn to both CDs & DVDs.
Just saying...
Drew
Flupsie
Well-Known Member
#9
Hi Drew
Thanks for the reply. I have uninstalled Nero as it is no longer required
#10
You're welcome & very cool :thumbs_up::thumbs_up:
Drew
