Windows 7 Intel SM Bus controller
ardoyne
Can't find drivers for Intel SM Bus controller on ASUS P5Q Pro
Manually is:
Download the drivers in a folder, then go to:
Control Panel->System->Device Manager
Find the SM Bus problem, normally in Other Devices, select the SM BUs, then click right mouse and select "Update Driver Software"->"Browse my computer for driver software" and then select the folder with the drivers....
I have same motherboard and im using drivers from asus cd (vista x64).
I downoladed the x64 drivers and I have a P5Q-E, the utility says I can't install because the operating systems is not compatible... Any ideas?
Mmmm, I manually inatalled the drivers, now works ok.
Jose
I manually downloaded the Vista 32 bit zip file, had Win7 unzip it and then installed it from the unzipped files. Now installed correctly.
same prob
Jose
i can't run the setup because it says my os is not supported. how did u manually install drivers? like add new hardware styles?
I would also like to know how one "manually installs drivers". I ran into the same "OS not supported" dialog box but wasn't able to get any further.
Manually is:
I have managed to install all the all Asus drivers by running the setup (or AsusSetup) in compatability mode for Vista.
The only problem I have encountered is that Ican;t get the front panal headphones to work. The do worki in Vista though.
