Just recently, the d\l and u\l wireless internet speeds decreased dramatically, so slow I very seldom can even connect to internet. My desktop computer connects just fine to the same network and connection speed is high. I can go to a friends house with my laptop and connect to his network and internet just fine. It appears that the problem is with my laptop and the public network I'm using, since my laptop will not connect, and my desktop will, but my laptop will connect just fine to another network. Any ideas?
Thanks
hp laptop
win 7
What about the fact that my desktop pc works fine, fast internet speed? There are at least a few people using the network, it's at a rv park.
Can we assume, for the purposes of addressing this issue that you are not the owner of this network and can therefore not make any adjustments to the router and its' related settings?
You say that your desktop connects fine, can we assume that it is also running the same operating system as well as the same wireless network adapter to connect to the network?
If your laptop works fine in other environments as you have said, then I would suspect that the problem has more to do with proximity and the devices antenna.
The laptop may have an inferior antenna the desktop's may just be better. Have you experimented with the laptop's proximity to the router's physical location.
I know I've seen performance issues with Windows 7 and certain routers using WEP encryption. Is the desktop also using Windows 7 as its' OS?
And of course some devices are more susceptible to outside interference from other devices using the same frequencies.
You discuss your connection in terms of speed, but I've not seen any mention of the actual signal strength. Are both computers showing the signal strength as excellent, good, etc.?
EDIT: Also, to address the "recently" issue. Have you intentionally or maybe through a windows update, updated the driver for the device on the laptop. If so, take a look at device manager, right click the problem adapter, choose properties, then under the driver tab, see if the option to roll back the driver, is available to you.
