IRQL_NOT_LESS_OR_EQUAL
usasma
Fantastic Member
#21
Don't worry about it for now. It may become an issue if the BSOD's continue - but I suspect that the MSI Afterburner is the true cause. I only suspect the wireless driver because it is older.
#22
Still getting blue screens. I've included the latest 2 dmp files (IRQL_NOT_LESS_OR_EQUAL and BAD_POOL_CALLER). I ran the SeaTools for DOS long test, no errors. Memtest 86+ on each of my 2 sticks individually in both slots for 4 passes, no errors. Furmark Burn-in test on default settings 1024x576 for 20 mins, it rose to around 80 then hovered around 80 - 85. View attachment W7F_paralysedbeaver5.zip
usasma
Fantastic Member
#23
This one blames video. Please follow these instructions to update the video driver only: ATI video cards - DRIVER ONLY installation procedure
Once that's done - if the BSOD's recur, please run Driver Verifier according to these instructions: Driver Verifier Settings
bcmwl664.sys Tue Jul 7 20:45:04 2009 (4A53EC10)
Broadcom 802.11g Network Adapter - Dell Wireless 1390 WLAN Mini-Card
http://www.carrona.org/drivers/driver.php?id=bcmwl664.sys
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Sat Mar  2 11:07:52.516 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030213-18205-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].18044.amd64fre.win7sp1_gdr.130104-1431
System Uptime:[B]0 days 0:13:44.687[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiProcessExpiredTimerList+110 )[/B]
BugCheck [B]A, {0, 2, 1, fffff80002e81830}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000000A"]IRQL_NOT_LESS_OR_EQUAL (a)[/URL]
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
Arg4: fffff80002e81830, address which referenced memory
BUGCHECK_STR:  0xA
PROCESS_NAME:  SABnzbd.exe
FAILURE_BUCKET_ID: [B]X64_0xA_nt!KiProcessExpiredTimerList+110[/B]
  BIOS Version                  V17.7
  BIOS Release Date             09/09/2010
  Manufacturer                  MSI
  Product Name                  MS-7599
**************************Fri Mar  1 12:29:39.575 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030113-18844-01.dmp]
System Uptime:[B]0 days 0:20:09.120[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!DXGFASTMUTEX::`scalar deleting destructor'+b6 )[/B]
BugCheck [B]C2, {7, 109b, 40e95e0, fffffa8006e831f0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x000000C2"]BAD_POOL_CALLER (c2)[/URL]
Arguments:
Arg1: 0000000000000007, Attempt to free pool which was already freed
Arg2: 000000000000109b, (reserved)
Arg3: 00000000040e95e0, Memory contents of the pool block
Arg4: fffffa8006e831f0, Address of the block of pool being deallocated
BUGCHECK_STR:  0xc2_7
PROCESS_NAME:  chrome.exe
FAILURE_BUCKET_ID: [B]X64_0xc2_7_dxgmms1!DXGFASTMUTEX::_scalar_deleting_destructor_+b6[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]bcmwl664.sys                Tue Jul  7 20:45:04 2009 (4A53EC10)[/B][/COLOR]
AtiPcie64.sys               Wed Mar 10 09:33:45 2010 (4B97ADC9)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
nusb3hub.sys                Thu Feb 10 00:52:32 2011 (4D537D20)
nusb3xhc.sys                Thu Feb 10 00:52:33 2011 (4D537D21)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
AtihdW76.sys                Fri May 11 04:25:40 2012 (4FACCD04)
Rt64win7.sys                Tue Jun 12 10:00:29 2012 (4FD74B7D)
mbam.sys                    Mon Aug 20 12:49:41 2012 (50326AA5)
MpFilter.sys                Wed Oct 31 18:43:06 2012 (5091A97A)
RTKVHD64.sys                Tue Dec  4 08:28:37 2012 (50BDFA85)
atikmpag.sys                Wed Dec 19 14:32:55 2012 (50D21667)
atikmdag.sys                Wed Dec 19 15:38:55 2012 (50D225DF)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=AtiPcie64.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=nusb3hub.sys
http://www.carrona.org/drivers/driver.php?id=nusb3xhc.sys
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=AtihdW76.sys
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
http://www.carrona.org/drivers/driver.php?id=mbam.sys
http://www.carrona.org/drivers/driver.php?id=MpFilter.sys
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
http://www.carrona.org/drivers/driver.php?id=atikmpag.sys
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
#24
I think I've finally removed all traces of the CCC, as there was a setting in there that was to do with overscan, and filled the picture to the edge of my monitor through HDMI. Now, that's gone, there is a one inch black border around it all that I can't seem to get rid of.
usasma
Fantastic Member
#25
I'd suggest temporarily leaving the black border alone. Once we see if that fixes the problems, then we can work on fixing the black border thing.
In most cases I suggest waiting a week to see if the BSOD's have stopped before thinking that it's "fixed".
Then I suggest waiting another week before deciding that it's "fixed".
usasma
Fantastic Member
#27
Yes, that would be the best thing at this point.
I'm starting to wonder about hardware issues/compatibility issues at this point (but these most recent errors tend to point to software/drivers).
Start by running these free hardware diagnostics: Hardware Diagnostics
Analysis:
[font=lucida console]**************************Mon Mar  4 12:26:15.795 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030413-19718-01.dmp]
System Uptime:[B]0 days 0:01:57.341[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiDeliverApc+126 )[/B]
BugCheck [B]3B, {c0000005, fffff80002e6d5b6, fffff88002726050, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003B]SYSTEM_SERVICE_EXCEPTION (3b)[/url]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002e6d5b6, Address of the instruction which caused the bugcheck
Arg3: fffff88002726050, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME:  steam.exe
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!KiDeliverApc+126[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Mon Mar  4 12:23:38.224 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030413-20046-01.dmp]
System Uptime:[B]0 days 0:23:17.395[/B]
Probably caused by :[B]win32k.sys ( win32k!memset+70cf )[/B]
BugCheck [B]3B, {c0000005, fffff960000fcadf, fffff88008af71c0, 0}[/B]
Arguments:
Arg2: fffff960000fcadf, Address of the instruction which caused the bugcheck
Arg3: fffff88008af71c0, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]X64_0x3B_win32k!memset+70cf[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
[/font]
3rd Party Drivers:
atikmpag.sys                Tue Feb 26 12:58:05 2013 (512CF7AD)
atikmdag.sys                Tue Feb 26 14:11:23 2013 (512D08DB)
[/font]
#28
I just finished running the Prime95 test. I did the blend test with 4 torture test threads. The CPU started at around 40 and finished 1 test in a minute but was pushing 85 degrees so I stopped it.
usasma
Fantastic Member
#29
Time to look at the cooling solution for your CPU. Use anti-static precautions before touching anything inside the case!
Check to make sure that:
- there's thermal compound between the cooler and the CPU
- that the cooler is clear of dust/dirt/hairballs
- that the fan is working
- that there is plenty of room for cooler air to get at the CPU cooler
#30
Think you might be right. My brother has the same CPU and MB as me, but an aftermarket CPU cooler. I got him to run the same test. Started at around 30 and the hovered at 50, going no higher.
#31
I have reseated the cpu with a fresh application of thermal paste. When I took the cpu cooler off, there was hardly any left on the cpu and a lot on the heatsink. Cleaned it off the two of them, and reapplied it. A blob in the center.
Since I'm running low on space for attachments here, I uploaded today's crashes to an offsite hoster. Here.
usasma
Fantastic Member
#32
I'm assuming that the potential hardware problems were fixed by the application of thermal paste. Did you perform another stress test with Prime95?
Since I assumed that the hardware problems were fixed by the thermal paste - yet you're still having BSOD's.
And the BSOD's are of a type that usually responds well to the user of Driver Verifier - Please run Driver Verifier according to these instructions again: Driver Verifier Settings If possible, let Driver Verifier crash the system at least 3 times.
Possible results:
- No BSOD - probably a hardware problem, but Windows drivers are also a possible cause..
- BSOD's that blame one thing (a 3rd party driver) - most likely the cause
- BSOD's that blame one thing (not a 3rd party driver) - - probably a hardware problem, but Windows drivers are also a possible cause.
- BSOD's that blame several things- probably a hardware problem.
Analysis:
[font=lucida console]**************************Tue Mar  5 15:41:17.654 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030513-24336-01.dmp]
System Uptime:[B]0 days 1:14:09.200[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ExpScanGeneralLookasideList+a0 )[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff80002ec12bb, fffff88003316908, fffff88003316160}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x1000007E]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/url]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80002ec12bb, The address that the exception occurred at
Arg3: fffff88003316908, Exception Record Address
Arg4: fffff88003316160, Context Record Address
PROCESS_NAME:  System
BUGCHECK_STR:  0x7E
FAILURE_BUCKET_ID: [B]X64_0x7E_nt!ExpScanGeneralLookasideList+a0[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Tue Mar  5 14:26:33.963 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030513-18080-01.dmp]
System Uptime:[B]0 days 1:53:34.134[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiDeliverApc+187 )[/B]
BugCheck [B]A, {1280, 2, 1, fffff80002ec1617}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000000A]IRQL_NOT_LESS_OR_EQUAL (a)[/url]
Arguments:
Arg1: 0000000000001280, memory referenced
Arg4: fffff80002ec1617, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_nt!KiDeliverApc+187[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Tue Mar  5 02:22:48.941 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030513-29983-01.dmp]
System Uptime:[B]0 days 6:19:37.486[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!IoCancelIrp+5a )[/B]
BugCheck [B]A, {2c, 2, 0, fffff80002e2869a}[/B]
Arguments:
Arg1: 000000000000002c, memory referenced
Arg3: 0000000000000000, bitfield :
Arg4: fffff80002e2869a, address which referenced memory
BUGCHECK_STR:  0xA
PROCESS_NAME:  SearchIndexer.
FAILURE_BUCKET_ID: [B]X64_0xA_nt!IoCancelIrp+5a[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Mon Mar  4 20:02:37.432 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030513-32588-01.dmp]
System Uptime:[B]0 days 0:03:59.977[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiDeliverApc+129 )[/B]
BugCheck [B]A, {7000000008, 2, 1, fffff80002ec15b9}[/B]
Arguments:
Arg1: 0000007000000008, memory referenced
Arg4: fffff80002ec15b9, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_nt!KiDeliverApc+129[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Mon Mar  4 19:27:45.458 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030513-22417-01.dmp]
System Uptime:[B]0 days 0:03:25.003[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!CcFlushCache+15d )[/B]
BugCheck [B]A, {18, 2, 0, fffff80002eb941d}[/B]
Arguments:
Arg1: 0000000000000018, memory referenced
Arg4: fffff80002eb941d, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_nt!CcFlushCache+15d[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Mon Mar  4 19:23:43.820 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030513-18158-01.dmp]
System Uptime:[B]0 days 0:18:19.366[/B]
*** WARNING: Unable to verify timestamp for atikmdag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys
Probably caused by :[B]atikmdag.sys ( atikmdag+36c0e )[/B]
BugCheck [B]A, {1b5200000008, 6, 1, fffff80002eb6ee6}[/B]
Arguments:
Arg1: 00001b5200000008, memory referenced
Arg2: 0000000000000006, IRQL
Arg4: fffff80002eb6ee6, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_atikmdag+36c0e[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Mon Mar  4 19:04:49.892 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030513-17799-01.dmp]
System Uptime:[B]0 days 1:51:26.437[/B]
Probably caused by :[B]USBPORT.SYS ( USBPORT!USBPORT_Core_iCompleteDoneTransfer+86f )[/B]
BugCheck [B]A, {fffff68030803400, 2, 1, fffff80002e95109}[/B]
Arguments:
Arg1: fffff68030803400, memory referenced
Arg4: fffff80002e95109, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_USBPORT!USBPORT_Core_iCompleteDoneTransfer+86f[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
[/font]
3rd Party Drivers:
[COLOR=RED][B]nusb3hub.sys                Thu Feb 10 00:52:32 2011 (4D537D20)[/B][/COLOR]
[COLOR=RED][B]nusb3xhc.sys                Thu Feb 10 00:52:33 2011 (4D537D21)[/B][/COLOR]
cpuz136_x64.sys             Sat Oct 27 13:24:41 2012 (508C18D9)
[/font]
http://www.carrona.org/drivers/driver.php?id=cpuz136_x64.sys
It's been 3 days since the last BSOD, so I haven't run driver verifier yet. If I do blue screen again though, I will run it.
usasma
Fantastic Member
#35
Glad to hear it! Give it another week and it's probably fixed!
