Windows 7 Laptop not visible as Home Group member after stand-by
Mean Grean
I have a desktop PC with Windows 7 Home Premium 32 and an Asus Eee 1005HA netbook running Window 7 Starter. Desktop is connected via cable to Linksys W54G, netbook has wireless connection. I created a Home Group on the desktop PC and made the netbook member of it. So far so good, both computers can see eachother, file sharing and transfer between them works fine. But when I re-open my netbook after it having been closed for a short while (and in sleep/stand-by/hibernate mode), my netbook is not visible in the Home Group on my desktop pc anymore. I can still see and access it in the "Network" section but it does not appear as a member of the Home Group until a full restart.
Does anyone know this problem and has a solution for it? Thanks.
It sounds like you're experiencing an issue with your HomeGroup network setup where the netbook disappears from the HomeGroup on your desktop PC after it comes out of sleep, standby, or hibernate mode. This can be frustrating, but there are a few troubleshooting steps you can try to resolve this issue:
Troubleshooting Steps:​
  1. Check Network Discovery and Sharing Settings:
    • Ensure that Network Discovery, File and Printer Sharing, and Public Folder Sharing are turned on for both computers. You can find these settings in the Network and Sharing Center.
    []Adjust Power Settings:
    • Check the power settings on your netbook to make sure that the network adapter is not turned off to save power. Adjust...
    • Check the power settings on your netbook to make sure that the network adapter is not turned off to save power. Adjust the power settings to keep the network adapter active during sleep or standby mode.
    ]Restart Network Services:
    • Restart the "Function Discovery Provider Host" and "Function Discovery Resource Publication" services on both computers. This can help refresh the network and HomeGroup connections.
    []Reset HomeGroup:
    • Try leaving the HomeGroup on both computers and then re-creating the HomeGroup from scratch. This can sometimes resolve issues with HomeGroup connectivity.
    ]Update Network Drivers:
    • Ensure that the network drivers on both computers are up to date. Outdated network drivers can sometimes cause connectivity issues.
    []Disable Sleep/Hibernate Mode:
    • As a temporary solution, you can try disabling sleep/hibernate mode on the netbook to see if the issue persists when the computer is always on.
    ]HomeGroup Troubleshooter:
    • Run the built-in HomeGroup troubleshooter on both computers to identify and fix any issues related to HomeGroup connectivity.
      Additional Tips:​
      • Make sure both computers are on the same workgroup.
      • Restarting the "Peer Networking Grouping" and "HomeGroup Provider" services on both computers can also help with HomeGroup connectivity.
      Try these steps to see if they help in maintaining the visibility of your netbook in the HomeGroup on your desktop PC. If the issue persists, feel free to provide more details for further assistance.
