LG smart‑TV owners are reporting that a recent webOS firmware update pushed Microsoft’s Copilot onto their home screens as a persistent tile — and in many cases the Copilot tile cannot be uninstalled through the TV’s normal app-management UI, only hidden or disabled, leaving owners with limited workarounds and rising privacy and ownership concerns.
Dim living room with a hand holding a remote, pointing at an LG OLED TV showing Copilot.Background / Overview​
LG and Microsoft publicly positioned Copilot as a major feature for 2025 smart TVs, promising conversational search, contextual show recaps, and easier content discovery delivered through webOS and the AI‑focused "AI Remote" concept. Those partnerships and trade‑show demos set the expectation that Copilot would arrive on living‑room screens, but the method of distribution — a background firmware‑over‑the‑air (FOTA) push that added a Copilot tile directly to owners’ home screens — has created an unexpected backlash.
Multiple community reports indicate that, after applying a routine webOS update, owners found a Copilot icon pinned to their TV’s app ribbon or AI section. When attempting to remove it via the TV’s Edit/App Manager workflow, many owners did not see the usual uninstall (trash‑can) affordance; the UI offered only hide or disable. In several documented cases a factory reset restored the Copilot tile, strongly suggesting the component was delivered as a system‑level package or baked into the firmware image rather than as a removable user app.
This article summarizes the observable facts from the field, verifies technical claims where possible, analyzes the privacy and consumer‑rights implications, offers practical mitigations for affected owners, and critiques the product and update practices that turned a plausible convenience feature into a flashpoint.
What happened — the observable facts​
How the Copilot tile appeared​
  • Owners reported receiving a routine webOS FOTA update.
  • After the update and reboot, a Copilot tile appeared in the home ribbon or AI section.
  • Launching the tile typically opens a web‑based Copilot interface inside the TV’s browser shell and accepts voice input through the remote’s mic button in many reported cases.
Removal attempts and behavior​
  • When users opened the TV’s app management or Edit App List flows, the uninstall option was absent for Copilot; only hide or disable were shown.
  • Several owners performed factory resets; the Copilot tile reappeared after reset in multiple reports, indicating firmware‑baked or privileged system packaging.
Scale and public reaction​
  • The issue surfaced rapidly across Reddit, enthusiast forums, and tech outlets, with high‑visibility threads amassing thousands of interactions. Owners described their frustration in stark terms — “forced AI,” “bloatware,” and a loss of control over devices they paid for.
Technical anatomy — why Copilot can feel “unremovable”​
Understanding why a tile can’t be deleted from a smart TV requires a brief look at two common firmware and packaging patterns used by OEMs.
1. Privileged system package​
Manufacturers can install a component outside the normal user app sandbox and mark it as a system app. The app manager typically limits actions for such packages to avoid breaking platform functionality — hide or disable might be permitted, whereas uninstall is blocked. This is standard for DRM, low‑level agents, or tightly integrated services. Reports from affected owners match this behavior: Copilot appearing as a system/preinstalled app with restricted management actions.
2. Firmware‑baked component​
A FOTA update can include a firmware image that contains preinstalled packages. A factory reset often re‑applies that firmware image, restoring baked‑in components. Users who perform factory resets only to see Copilot return strongly suggest this mechanism was used in some instances.
Native app vs. web wrapper​
Available evidence points to many Copilot launches acting as a web wrapper — an embedded browser view that points to Microsoft’s Copilot web interface — rather than a deeply native webOS app. That packaging is lighter to deploy but can still be treated as a privileged home‑screen object, giving it permanent placement with limited removal options.
Privacy, telemetry, and security implications​
The presence of a conversational assistant on a living‑room device raises a distinct set of privacy questions beyond generic preinstalled bloatware.
Expanded telemetry surface​
LG’s webOS already includes features such as Automatic Content Recognition (ACR) — branded as Live Plus — which harvests viewing metadata for personalization and advertising. An assistant that benefits from on‑screen context or accepts voice input logically expands the range of signals available for personalization, recommendations, or ad targeting. Without clear vendor disclosures, owners reasonably worry about new or broader telemetry flows.
Microphone and ambient audio concerns​
Copilot on TV can be summoned via a remote mic button; the fundamental concern is whether background or ambient audio capture has changed, or whether conversational data are retained differently after installation. Community reports highlight that LG provides toggles to disable certain AI features, but those switches do not remove the Copilot tile and may not address all telemetry pathways. These audio‑capture claims require vendor confirmation or independent forensic analysis to verify. Until LG or Microsoft publishes technical notes, telemetry and audio‑capture assertions remain unverified.
Data retention and cross‑provider access​
Key questions remain unanswered in public reporting: how long conversational logs are retained, where they’re stored, whether personalizing Copilot requires a Microsoft account, and which corporate entities (LG, Microsoft, ad partners) can access the data. These are material privacy issues; community reporting has flagged them but cannot definitively answer them without vendor transparency.
Attack surface and supply‑chain changes​
Any privileged, persistent service added to device firmware increases the attack surface and becomes a potential target for supply‑chain or privilege‑escalation exploits. The more a vendor bakes third‑party services into firmware, the more complicated security patching and isolation become — a risk for both consumers and enterprise deployments using TVs in public spaces.
Consumer‑facing impact: ownership, trust, and UX​
For many buyers, a TV is a durable consumer product: once purchased, users expect core software to be under their control. The Copilot episode erodes that expectation in three overlapping ways.
  • Loss of device autonomy: Forced, non‑removable software diminishes the psychological and practical sense of ownership.
  • Opaque updates: Firmware updates are expected to patch security issues and improve stability; surprise feature additions that can’t be easily removed undermine trust.
  • UI pollution and persistence: A persistent home‑screen tile consumes valuable real estate and attention, and hiding is an imperfect solution for users who value a minimal interface.
This combination explains the unusually intense community reaction: it’s not merely irritation at bloatware, it’s a perceived shift in the vendor–consumer contract over what constitutes acceptable post‑purchase changes.
What LG and Microsoft likely considered — the corporate rationale​
Several business drivers could explain why LG pushed Copilot in this manner:
  • Feature differentiation: An assistant on a TV is a headline‑friendly differentiator in a market with converging hardware specs.
  • Partnership value: A deep integration with Microsoft amplifies Copilot’s footprint and potentially includes commercial or co‑marketing arrangements.
  • Ecosystem control and monetization: Preinstalling a branded assistant increases the chance of routing users through vendor and partner monetization funnels, from promoted content to personalized ads.
These incentives are commercially rational, but the way they were executed collided with consumer expectations around consent and control.
Practical steps for affected owners — immediate mitigations​
For owners who found Copilot on their LG TV and want to regain control or mitigate privacy exposure, these steps — ordered from simplest to most advanced — reflect the community’s tested options.
  • Hide the Copilot tile using the Edit/App List flow to declutter the home screen. This does not remove the software but reduces visual presence.
  • In Settings, disable AI features such as Live Plus / ACR, voice personalization, and ad personalization toggles to reduce telemetry surface. These toggles may not remove Copilot but can limit data sharing.
  • Perform a factory reset if you suspect corrupted behavior — note many users reported Copilot reappearing after reset, so this may not be a permanent fix. Backup preferences beforehand.
  • Disconnect the TV from the network (turn off Wi‑Fi or unplug Ethernet) to prevent Copilot from loading and to stop outbound telemetry while you investigate. This is a blunt instrument that disables most smart features.
  • Use router‑level blocking or DNS filtering to block known Copilot endpoints. This requires network skill and up‑to‑date endpoint knowledge; it is effective if you can identify the addresses Copilot uses.
  • Use an external streaming device (Apple TV, Fire TV, Chromecast, etc. as the primary UI and ignore the native webOS layer to sidestep continued updates and baked‑in services.
  • Contact LG support and file a formal complaint; persist in seeking a supported removal or rollback, and document case numbers. Collective pressure often motivates vendor action.
Each option has trade‑offs. Hiding is reversible and low cost; disconnecting the TV is effective but removes smart functionality; router blocking is powerful but technical. Many owners view external streamers as the cleanest long‑term consumer control option.
Legal, regulatory, and consumer‑rights considerations​
The incident raises questions about consumer protection and the legal expectations for purchased hardware.
  • Consumer‑protection view: Permanently altering a device post‑sale by installing non‑removable third‑party services may run afoul of consumer expectations or local laws about product modifications and disclosure.
  • Privacy regulation: In jurisdictions with strong privacy laws, undisclosed expansion of telemetry or behavioral profiling via preinstalled services could attract regulatory attention unless clear opt‑outs and transparent data‑sharing notices are provided.
  • Warranty and returns: Consumers who perceive the device as materially changed by enforced software may explore return or warranty remedies; returning recent purchases within the vendor’s return window can be an effective short‑term remedy.
At present, community reporting has concentrated on observable UI behavior and practical mitigations; formal regulatory complaints or class actions would require documentation of data flows and vendor responses, or coordinated consumer complaints to authorities.
Evaluating strengths and potential risks​
Notable strengths of Copilot on TV​
  • Convenience and discovery: A well‑implemented assistant can meaningfully improve content discovery and cross‑service search on large screens.
  • Accessibility: Voice interactions and summary features can help viewers with visual or mobility limitations.
  • Ecosystem value: For Microsoft and LG, extending Copilot to TVs broadens service reach and creates new cross‑device synergies.
Significant risks and weaknesses​
  • Erosion of trust: Forcing a non‑removable assistant via firmware updates damages the vendor–consumer trust relationship.
  • Privacy uncertainty: Absent detailed vendor disclosures, the presence of a conversational AI raises unresolved questions about audio capture, telemetry retention, and cross‑provider access to data. These are serious for living‑room devices.
  • User control deficits: Hiding a tile is not removal. The inability to uninstall a third‑party service on purchased hardware is a fundamental UX and rights problem.
  • Security surface: Privileged, baked‑in services complicate isolation and patching and can introduce new attack vectors.
Recommendations — what LG, Microsoft, and consumers should do next​
For LG (product & update teams)​
  • Publish clear technical documentation explaining how Copilot is packaged, what data flows it initiates, and which controls disable telemetry. Public transparency is the fastest way to rebuild trust.
  • Ship a supported removal or rollback path for owners who want Copilot off their devices, or explicitly mark the component as removable in a forthcoming update. Providing a documented uninstall option would resolve the core ownership complaint.
  • Default to privacy‑minimal settings on first boot and require explicit opt‑in for account‑backed personalization or data sharing.
For Microsoft​
  • Clarify Copilot’s data lifecycle when used on TVs: retention windows, whether data is tied to Microsoft accounts, and how contextual on‑screen signals are handled. Transparent privacy documentation reduces fear and speculation.
For consumers​
  • Document and escalate: Log interactions with support, save screenshots, and share case numbers. Collective reports accelerate vendor responses.
  • Use network segmentation: Place smart TVs on a guest VLAN with limited outbound access to reduce cross‑device leakage.
  • Vote with purchases: If persistent lack of control is unacceptable, prioritize TVs and streaming devices that let you opt out of preinstalled services or rely on external streamers to preserve user control.
Broader implications for the smart‑TV ecosystem​
This episode is emblematic of a larger industry tension: hardware commoditization pushes vendors to differentiate via services and AI features, but embedding third‑party services deeply into platform firmware risks alienating customers when those services are perceived as forced. The balance between feature innovation and consumer control will shape whether “AI TV” becomes a welcomed convenience or an ongoing battleground over bloatware and privacy.
If OEMs want broad acceptance of assistants on living‑room screens, they must pair technical innovations with clear consent models, easy removal paths, and privacy‑first defaults. Failing that, expect more consumers to rely on external streamers or to demand stronger regulatory limits on post‑sale software changes.
Deploying Copilot to TVs is a logically consistent step in the era of cross‑device AI, and the feature could deliver useful search, discovery, and accessibility benefits. The controversy is not simply about the assistant’s capabilities — it’s about how it arrived. A firmware push that places Copilot on the home screen as a system‑level tile with no straightforward uninstall path broke an implicit promise of consumer control and provoked a predictable backlash.
The practical reality for affected owners is blunt: hide the tile, disable AI toggles, use network controls, or switch to an external streamer. The durable fix requires vendor action — transparent technical disclosures, privacy‑minimal defaults, and a supported removal or rollback mechanism. Until LG and Microsoft address those steps publicly, Copilot’s arrival on webOS will remain a cautionary case in how not to deliver AI to purchased hardware.
Source: Mashable LG forces Copilot onto smart TVs, and there's no way to delete it
Source: Mashable SEA LG forces Copilot onto smart TVs, and there's no way to delete it
LG owners woke up this week to find Microsoft’s Copilot sitting on their television home screens after a routine webOS firmware update — and in many cases the new AI tile cannot be fully removed through the TV’s normal app-management menus. The surprise push also enabled LG’s Live Plus automatic content‑recognition setting by default on affected sets, amplifying privacy and data‑sharing concerns.
Man stands with folded arms, watching a glowing TV UI showing Copilot and app icons in a dim living room.Background / Overview​
LG and Microsoft publicly signalled plans to bring Copilot — Microsoft’s conversational AI assistant — to living‑room screens during the 2025 product cycle, framing it as a convenience for content discovery, contextual questions, and an “AI Remote” experience on webOS. Those announcements made Copilot on TVs an expected feature for 2025 models, but the current controversy is about how the feature arrived on many customers’ sets: pushed silently via an over‑the‑air (FOTA) update and appearing as a persistent tile that many users report cannot be deleted. The pattern surfaced publicly after a high‑visibility Reddit post showing the Copilot tile on an LG home screen attracted tens of thousands of upvotes and thousands of comments. Community documentation and screenshots quickly aggregated into large threads that trace the same observable behavior across multiple models and firmware builds: Copilot appears after an update, it launches a web‑based Copilot interface in the TV’s browser shell in many cases, and when users open the Edit/App Manager screens the usual uninstall affordance is absent — at best the tile can be hidden. This combination — a partner AI shipped onto already‑sold hardware without an obvious opt‑in and installed in a way that appears system‑level — has generated a sharp consumer backlash about device ownership, opaque update mechanics, and the expansion of telemetry surfaces on devices that sit in private spaces like living rooms.
What owners are actually seeing​
The visible sequence (repeatable reports)​
  • The TV receives a standard webOS firmware update (some users report it applied automatically).
  • After the reboot, a Copilot tile or shortcut appears on the home ribbon or AI/assistant section.
  • Opening the Copilot tile launches a Copilot experience — in many cases a web‑based interface hosted by Microsoft — and the remote’s mic can invoke voice input.
  • In Settings → Edit apps or the App Manager, Copilot frequently shows no delete/trash icon; the UI offers only hide or disable.
  • Several users who performed a factory reset reported the Copilot tile reappeared, indicating the component may be baked into the firmware image or installed as a privileged system package.
Those are the observable, repeatable behaviors documented by owners and aggregated across forums and tech outlets. Independent vendor confirmation of the exact packaging method — whether Copilot is a system package or a firmware‑baked component in specific builds — remains outstanding. Treat vendor‑level engineering assertions as unconfirmed until LG or Microsoft publish technical notes or LG’s firmware is inspected.
Live Plus: an opt‑in that appears to be opt‑out by default​
Alongside Copilot, affected owners report the Live Plus setting — LG’s name for Automatic Content Recognition (ACR) and related ad‑personalization features — is enabled after the update on some sets. Live Plus analyzes on‑screen content to provide recommendations and target advertising; it is controllable in menus but many users were surprised to find it turned on by default after the update. Turning Live Plus off reduces on‑screen ACR signals but does not remove the Copilot tile.
Why this matters: ownership, privacy, and trust​
Loss of device autonomy​
Consumers reasonably expect optional services and third‑party apps to be removable from hardware they own. When an OEM treats a partner app as a privileged system component — or bakes it into the firmware image — the device begins to feel like a vendor‑managed platform rather than private property. That erosion of perceived ownership is the emotional core of the backlash: users did not ask for this feature and many feel there’s no straightforward way to reverse it.
Smart TVs already collect metadata: app usage, device identifiers, and — where enabled — ACR signals that describe what’s playing on screen. Adding a cloud‑linked conversational assistant increases the potential surface for data flows (voice queries, chat transcripts, contextual cues). Even when an assistant runs as a web wrapper, interactions route to remote services that may be logged, associated with accounts, and used for personalization or product improvement. The combination of a persistent Copilot tile plus a default‑on Live Plus setting raises legitimate questions about what is collected, how long it is retained, and with whom it is shared.
Opaque update mechanics​
Firmware updates are expected to deliver security patches and stability fixes. When the same distribution channel is used to inject partner services — without clear, device‑level changelogs or explicit on‑screen consent — users experience a breakdown of trust. A transparent rollout would have offered opt‑in prompts, clear release notes, and an uninstall pathway; the lack of those elements is what stokes outrage.
Technical anatomy: why an app can seem "undeletable"​
Two packaging patterns explain the common behavior reported by owners:
  • Install as a privileged system package: the OEM deploys the component outside the normal user app sandbox and marks it as a system app. Consumer UI typically exposes only hide or disable for such packages; uninstall is not permitted because removing system packages can break platform services. Many TV makers cite legitimate reasons for privileged installs (DRM, platform agents), but the result is user immutability.
  • Firmware‑baked component: the Copilot tile may be included in the firmware image that the FOTA update writes to the TV. A factory reset re‑applies the installed image, restoring baked‑in components. Removing such code usually requires vendor rollback or low‑level reflashing tools consumers do not have. Reports that Copilot returned after resets align with this model.
In practice, field reports and screenshots suggest the Copilot entry often behaves like a web wrapper (a shortcut launching Copilot’s web UI) rather than a deeply native integration, but it’s still being treated by the OS as a system‑level element in many firmware builds. That hybrid — a light deployment model with heavy platform placement — is what made the change both quick for the vendor and irksome for owners.
Privacy and security implications — what’s proven and what isn’t​
  • Proven (community‑verified): Copilot tiles appeared on many LG TVs after a webOS update, users cannot remove the tile via standard UI on affected devices, and Live Plus/ACR was visible and enabled by default for some owners. These facts are corroborated across multiple community threads and mainstream outlets.
  • Plausible but unverified: claims that the update introduced previously undisclosed telemetry classes (for example, continuous ambient audio capture being streamed to Microsoft) remain community concerns and require forensic network captures or an official LG/Microsoft disclosure to confirm. At time of reporting there is no publicly available independent forensic evidence confirming expanded ambient audio exfiltration tied specifically to this update. Flag these claims as requiring caution until validated.
  • Provable mitigations: toggling Live Plus off and disabling voice‑recognition features reduces the amount of contextual and voice data available to cloud services. Hiding the Copilot tile removes daily visual attention but does not uninstall the component. The most effective, albeit blunt, mitigation is to disconnect the TV from the internet or run streaming through an external device (Apple TV, Roku, Fire TV, Nvidia Shield) and use the LG display as a “dumb” monitor.
Practical, step‑by‑step mitigation for concerned owners​
Below are practical steps ranked from least to most disruptive. These are tested community workarounds; they trade convenience for increased control.
  • Hide the Copilot tile in webOS:
  • Press the Home key, enter Edit/App mode (pencil or Edit icon), select the Copilot tile, and choose Hide. This removes the tile from the visible home ribbon but does not uninstall the component.
  • Turn off Live Plus / ACR:
  • Settings → All Settings → General → System → Additional Settings → Live Plus (labeling may vary by model). Disabling Live Plus reduces automatic on‑screen content recognition and ad personalization signals.
  • Disable voice features if unused:
  • In Settings → Privacy or Voice Recognition, disable voice capture or voice assistant features to reduce microphone‑based telemetry.
  • Avoid signing in to a Microsoft account:
  • Do not link your Microsoft account to the TV. Account linkage is a primary mechanism for associating cloud interactions with a user identity.
  • Use network controls:
  • Use router‑level blocking (Pi‑hole or firewall rules) to block known telemetry domains; this is technical and can break legitimate services if misconfigured. Consider a separate guest network for the TV.
  • Use an external streamer or keep the TV offline:
  • The most reliable way to avoid the OEM smart layer and its persistent services is to run streaming through an external device and use the TV purely as a display. This sacrifices integrated UX and convenience but restores full control over software on the network‑connected endpoint.
  • If required, contact LG support:
  • Open a support case and request clarification about the update, how to uninstall Copilot, and whether LG will provide a firmware rollback or a user‑side removal tool. Keep records of model, firmware version, and screenshots.
Business rationale and the ad dimension​
Integrating an assistant into TVs is commercially rational for both OEMs and platform partners:
  • It improves content discovery and can surface paid placements more effectively.
  • AI features are marketed as differentiators in a commoditizing display market.
  • A persistent assistant can feed personalization systems that increase ad inventory value and first‑party data leverage.
LG’s webOS already includes monetization models (home‑screen promotions, screensaver ads, personalized recommendations) and a business unit focused on advertising solutions; adding Copilot and default‑on ACR can be seen through that commercial lens. Those incentives are understandable from a corporate perspective, but they collide with consumer expectations about control over post‑purchase software and privacy defaults.
Regulatory and consumer‑rights perspective​
Smart TVs sit at an intersection of consumer electronics, advertising, and data privacy law. Regulators have increasingly scrutinized how connected devices collect and monetize personal data. Key angles to watch:
  • Consent mechanics: default‑on settings for data collection (ACR/Live Plus) may draw regulatory attention where rules require affirmative, informed consent.
  • Transparency: firmware updates that change user experiences or add persistent services without clear release notes can be seen as poor consumer practice; regulators and consumer protection agencies may expect clearer communications.
  • Data portability and deletion: users may press for explicit mechanisms to delete personal data collected via the assistant or to ensure that uninstalling a service removes associated data.
As of this reporting, formal regulatory action has not been announced. Owners who feel their expectations were materially altered after purchase can pursue support channels, raise complaints with consumer protection bodies, or document their experiences publicly to increase pressure for a vendor response.
What LG and Microsoft have (and haven’t) said​
At the time coverage ramped up, mainstream outlets and community threads converged on the same observable facts but found no immediate, detailed public statement from LG or Microsoft reversing the behaviour or explaining the packaging rationale. Several tech outlets noted LG’s published webOS documentation already states that some preinstalled or system apps cannot be deleted via the UI — a policy that aligns with the observed lack of an uninstall affordance for Copilot on affected devices. However, a clear vendor explanation of why the component was provisioned as a system artifact in recent firmware builds, and whether any new telemetry flows were introduced with Copilot, remained absent in the public record at the time of reporting. This absence is a core reason community frustration intensified. If and when either company publishes a detailed technical bulletin, that note will be the single best source to resolve the remaining engineering and telemetry questions. Until then, community testing and network forensic analysis are the only paths to conclusive answers about data flows. Flag such claims that go beyond observable UI behavior as unverified until evidence is produced.
Editorial analysis: what LG did well, and where it failed​
Notable strengths of the approach​
  • Rapid feature delivery: LG moved quickly to add AI features users had been told would arrive in 2025; a web‑based Copilot shortcut is a low‑friction way to extend functionality across many models.
  • Strategic ecosystem alignment: partnering with Microsoft to bring Copilot to televisions extends both companies’ platform reach and offers plausible, real user value for those who choose to use the assistant.
Critical failures and risks​
  • Poor consent and communication: shipping a persistent partner service via firmware updates without clear, user‑facing release notes or an explicit opt‑in undermines trust.
  • Inadequate uninstall/rollback mechanisms: treating Copilot as a system artifact with no supported removal path on consumer devices damages the perception of ownership.
  • Privacy optics: enabling Live Plus by default in tandem with a non‑removable assistant looks like a coordinated expansion of telemetry surface without clear consent mechanics; even if technically lawful, the optics are terrible and erode brand trust.
The lesson for OEMs is clear: the promise of AI is real, but delivering it in a way that feels forced, opaque, or monetized without consent will provoke rapid pushback and could invite regulatory scrutiny.
What to watch next​
  • Official vendor statements or firmware updates that add an uninstall option, an explicit opt‑out during the update flow, or detailed release notes explaining the packaging decision.
  • Independent forensic reports that analyze network traffic, microphone usage, or telemetry endpoints tied to Copilot on webOS to confirm or refute claims of expanded data capture.
  • Regulatory or consumer‑protection inquiries if the issue becomes widespread enough to attract formal complaints.
Final takeaways for LG owners​
  • The Copilot tile’s arrival is real for many LG owners and — as currently observed — frequently cannot be uninstalled via standard menus; owners can hide it and can disable Live Plus, but the component remains present in many reported cases.
  • If privacy and control are paramount, the most straightforward options are: disable Live Plus, avoid signing in to accounts on the TV, hide the tile, use an external streamer for daily viewing, or keep the TV offline. Each option trades convenience for privacy.
  • Owners seeking a durable fix should document model and firmware version, contact LG support, and insist on clarity: why was Copilot delivered as a system element, what telemetry it uses, and whether an uninstall or rollback will be provided. Collective, documented inquiries increase the pressure for a vendor remedy.
The Copilot episode is a reminder that the shift toward AI‑enhanced devices must be accompanied by equally robust choices for users. Convenience without consent tends to be temporary: manufacturers may gain short‑term engagement, but they risk long‑term consumer trust and regulatory attention when they push system‑level features onto devices after sale.
An AI assistant on the TV can be genuinely useful — a quick way to find content, ask contextual questions, or get summaries while watching. The problem with this rollout isn’t the technology itself; it’s the delivery: a firmware push that installs a system‑level partner tile without clear opt‑in or an uninstall path, combined with default‑on content‑recognition settings, undermines the trust that underpins consumer electronics. For now, owners have practical mitigations that restore some control, and the community‑driven outcry has already forced the journalism and support ecosystems to focus on transparency and vendor accountability. The technical and regulatory aftermath will determine whether this episode becomes a short‑term bump in the road or a lasting precedent for how AI arrives on devices consumers already own.
Source: TweakTown Microsoft's Copilot AI is automatically installed on LG TVs and can't be removed
