Windows 11 Locked out of PC when trying to "repair‑install (in‑place upgrade)"
Mint Condish
Member
Hello, first time poster here and losing my mind. I know we all have things to do, but I'm on a job-killing deadline and can't get my HP laptop to complete a "repair‑install (in‑place upgrade)". The details:
I couldn't install that pesky security update KB5077181. I read this thread...
...and followed the instructions, BUT I'm afraid I did not take step 4, "BitLocker Safety". So after the first (and so far, only) reboot, I got the BitLocker recovery key blue screen. Thankfully, I have the key. I've had to enter it a million times. I then must "choose keyboard layout" - I'm not entirely sure which one is correct for me, but nevermind for now; I can type. Then the "choose an option" screen appears:
- Continue (to Windows Rollback)
- Use a device
- Use another operating system
- Troubleshoot
- Turn off your PC
I have clicked on everything, I think. Nothing allows me to continue the upgrade. I have NO idea if I can do something effective using the command prompt and I cannot trust the hundreds of different YouTube "tips". Look, at this point, going back to where I was before I attempted the upgrade would be perfect, frankly.
I wish I could give you a ton of hardware and software details. All I remember is this: my Windows 11 was Home Single Language 25H2 build 7171. As I said, my laptop is an HP; I can't remember the model, I bought it brand new last year.
It was stupid of me to try a procedure I don't fully understand when I need the work stored in my PC more than ever. I was afraid about possible security vulnerabilities.
I'm begging you, please help me not get fired. A trillion thanks in advance.
You’re not alone—what you’re seeing is a very common failure mode when an in‑place upgrade hits a reboot boundary while BitLocker protection is still active. The good news: since you have the recovery key, your files are almost certainly fine, and the fastest path (given your priorities) is to force Windows to roll back to the pre-upgrade state.
Below is the “do-this-first” path, then fallbacks if it loops.
What’s happening (in plain English)​
That guide’s Step 4 (“BitLocker Safety”) was there to suspend BitLocker protectors before the upgrade (manage-bde -protectors -disable C:). Without suspending, Windows sees the boot/upgrade environment as a “trusted boot change” and throws you into...
Super glad you got it sorted out. This particular security update has been unusually prone to tripping over inconsistent component‑store states, and it’s not entirely clear why it exposed so many underlying servicing anomalies across different systems. Whatever the root cause, it definitely highlighted how sensitive the PSFX and component‑based servicing pipeline can be when even a single directory or manifest is out of alignment
Now that you’re back on 25H2 (26200.7840) and stable, the only “housekeeping” I’d do is the safe, boring stuff that reclaims space and reduces future update trouble:
That was anything but boring! Settings → System → Storage → Temporary files only removed a few MBs. But Disk Cleanup did show me the Previous Windows installation(s) option, and yes, there was a C:\Windows.old folder, which Disk Cleanup took care of. I "won" 32 GB (now C: has 233 GB free of 475 GB). A "known good" system restore point has been created. EXCELLENT.
Unless I run into an unexpected relevant settings change that I can't deal with, I believe we can declare victory. Domo arigato, Mr. Roboto (in the best possible way; I know the Styx song isn't kind to robots).
That’s a clean win.
  • Build: You’re now on Windows 11 25H2 (OS Build 26200.7840), which is exactly where KB5077181 was supposed to land you.
  • Space: Reclaiming ~32 GB by removing C:\Windows.old via Disk Cleanup is normal after a repair install / rollback cycle, and that’s the right way to remove it.
  • Safety net: Creating a restore point is the perfect “I never want to relive this week” move.
A couple of final “close the loop” items (quick checks, not mandatory if you already did them):
1) BitLocker status
  • Just confirm once: manage-bde -status C:
  • If anything still shows “Protection Off”, re-enable: manage-bde -protectors -enable C:
2) Clean boot undone
  • If you used msconfig / disabled startup items for troubleshooting, make sure you’re back to your normal startup configuration.
3) ESET
  • Now that you’re patched and stable, you’re good to keep ESET installed again (you already re-imported settings—perfect).
If you want to help the next person who hits the same nightmare, the key “solution summary” for this thread is essentially:
  • Offline KB install + DISM still failed with 0x800f0993 / PSFX hydration candidates missing
  • The fix was Settings → System → Recovery → Fix problems using Windows Update → Reinstall now, which brought you to 26200.7840, and then cleanup (Windows.old) recovered space.
If anything odd pops up over the next day or two (file associations, default apps, missing drivers), post what changed and we’ll tune it back—but you’re absolutely justified in calling this victory.
Thanks — and nice work on documenting it so thoroughly. Your ISO sanity-check + BitLocker suspend/re-enable notes are exactly the kind of details that prevent people from getting stuck (or triggering recovery prompts) when they try the repair-install route.
If anything odd comes back later (e.g., Windows Update offering KB5077181 again, or new servicing errors), just post the new winver + the top CBS error lines and we can zero in quickly.
Perfect—then you’re genuinely finished:
  • You’re on the target build (26200.7840),
  • BitLocker is back to normal,
  • startup/services are back to normal,
  • ESET is restored,
  • Windows.old is gone and space reclaimed,
  • and you’ve got a restore point.
If anything changes (Windows Update starts offering a newer cumulative, or you see BitLocker recovery prompts again), start a new reply here with the exact build number from winver and we’ll keep it clean and safe.
A million thanks to you. I screwed up by not following your guide correctly, but the fact that you posted it in the first place was what brought me to the right place. Those random tips on YouTube and some such can do you in.
I actually ran into the same issue myself! I got locked out of my own laptop because BitLocker wasn’t suspended before I tried renaming the Catroot folder, and it completely shut me out. Once I finally figured out the correct servicing fix, I wanted to post it here right away because I knew there was no way I was the only one getting hit by this. Really glad it helped you get everything sorted.
