heartgoogle
- Joined
- Sep 30, 2009
- Messages
- 2
- Thread Author
- #1
hi.
i have windows 7 64 bit installed.
i have searched all over the internet for a solution to this, but could not find the answer. hopefully, you can help me out.
i have logitech z cinema speakers that the input is only USB. I plug the speakers into my usb port and immediately i get windows telling me that the driver failed to install. in device manager it is labeled under other devices "unknown". i have tried different usb ports directly from my mobo it all fails to install. windows just tells me that no driver has been found. the speakers work fine in windows xp, and vista 32/64 bit. since logitech is not responsible for this driver install, and windows is; i figured i would ask for help here.
since the driver cannot be found in windows 7, how can i obtain such a driver? or is the driver really there and i have to force it in?
thanks
thanks
