Windows 7 Memeo AutoBackup
mevensen
I have been using Memeo AutoBackup with Vista (came with my Free Agent external HDD) without much issue. I didn't even think about it when switching to Win7. Now that I have, however, it won't run. Not much problem, just uninstall and use someting else, right? Well, the installer won't run either, stating that AutoBackup isn't deisgned for this version of Windows. I tried compability, but it still won't budge. Any ideas?
reghakr
You won't be able to restore that backup with out the original software.
For future use, you can get a very good backup program called Link Removed - Not Found
You have to provide your email and they will send you a registration key:
mevensen
For future use, you can get a very good backup program called Free Paragon Drive Backup 9.0 Personal Edition
Yeah, I realize that I won't be able to restore the backup on this computer. I'm just trying to get the program out.
Probably not a huge deal, since I'll end up doing a clean install at some point in time...
reghakr
Sorry, but when you stated
I assummed you were trying to re-install
Actually a "clean" install is the only way to go.
Why not download it direectly from MS, this will then remove all the leftovers from the upgrade.
That's exactly why a 'clean" instll is the perferred method:)
norcalstuff
Removing Memeo
I have done all of this myself and had the same problem. I did an upgrade to Win7, I wanted to see how the upgrade behaved and know it is not the preferred method. When it became apparent that Memeo was not going to run, I began trying to uninstall and that is what I want to do. I was unsuccessful at uninstalling and so went to the registry and removed every reference to Memeo. Now every time I start windows, the Win installer begins with no reference to a particular program, eventually the installer just goes away. Its irritating and I have downloaded and run the win ofc installer cleanup, no effect.
xiezhoupeng351
There are many good backup tools
Norton Ghost, Acronis True Image Home 2010, Symantec Backup Exec System Recovery 2010
Dropbox, Live Mesh, SkyDrive
They have been discussed in this tip Link Removed - Not Found
