Windows 7 memory_management BSOD mini dump attached Please help!!
haz
hey everyone,
if someone could please have a look at the attached file and tell me what they think it would be muchly appreciated, i for some reason think it could be the ram?
thank you,
haz :)
I have learned to listed to users when they post :0) Most BSOD's are solved by the user - not by those of us doing the analysis.
As such, try this free memory diagnostic procedure: Link Removed - Invalid URL
The file collection app (from here: Link Removed ) didn't complete. It's missing the MSINFO32 report (which I use a lot!). Please rerun the report and have it generate the MSINFO32 report (then zip it up and upload it with your next post).
Not a whole bunch to see in the single memory dump file.
Please un-install your Apple Charger software - they have been known to cause BSOD's on some Win7 systems.
Please update your Razer Synapse drivers from the Razer website. Older versions (yours are from 2010) are known...
Please update your Razer Synapse drivers from the Razer website. Older versions (yours are from 2010) are known to cause BSOD's in some Win7 systems.
Realtek High Definition Audio drivers date from 2009, please get an updated version from Realtek here: Link Removed
I'm not real sure, but the USB filter driver (usbfilter.sys) dates from 2009. It's a part of your AMD chipset drivers and should be updated.
If the BSOD's continue, please zip up and upload the new memory dump files (they're located in C:\Windows\Minidump). If you have no further minidump files (but are still getting BSOD's), then please post back and let us know.
Analysis:
[FONT=lucida console]**************************Wed Sep  5 07:39:50.612 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090512-23649-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 0:01:26.767[/B]
BugCheck Code: [B]BugCheck 1A, {3452, 7fefe14d000, fffff70001081be8, 2ec00001d266c004}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+356c3 )[/B]
BugCheck Info: [B]MEMORY_MANAGEMENT (1a)[/B]
BUGCHECK_STR:  0x1a_3452
PROCESS_NAME: [B]svchost.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1a_3452_nt!_??_::FNODOBFM::_string_+356c3[/B]
  Manufacturer                  To Be Filled By O.E.M.
  Product Name                  To Be Filled By O.E.M.
  BIOS Version                  P1.50
  BIOS Release Date             11/17/2011
[/FONT]
3rd Party Drivers:The following is for information purposes only. Any drivers in red should be updated.
MBfilt64.sys        Thu Jul 30 23:40:32 2009 (4A7267B0)
usbfilter.sys       Wed Oct  7 03:44:08 2009 (4ACC46C8)
amdxata.sys         Fri Mar 19 12:18:18 2010 (4BA3A3CA)
AsrAppCharger.sys   Fri Jun 11 02:37:12 2010 (4C11D998)
tmtdi.sys           Tue Jul 20 04:58:07 2010 (4C45651F)
tmcomm.sys          Wed Jul 21 03:31:15 2010 (4C46A243)
tmevtmgr.sys        Wed Jul 21 03:31:15 2010 (4C46A243)
tmactmon.sys        Wed Jul 21 03:31:24 2010 (4C46A24C)
RzSynapse.sys       Wed Dec 15 05:32:19 2010 (4D089933)
EtronXHCI.sys       Fri Jan 28 16:46:43 2011 (4D433943)
EtronHub3.sys       Fri Jan 28 16:46:45 2011 (4D433945)
k57nd60a.sys        Tue May 10 00:42:30 2011 (4DC8C236)
RTKVHD64.sys        Tue May 24 08:32:39 2011 (4DDBA567)
nvhda64v.sys        Wed Apr 18 13:07:54 2012 (4F8EF4EA)
nvlddmkm.sys        Tue May 15 03:35:36 2012 (4FB20748)
[/FONT]
