MEMORY_MANAGEMENT
Hi all,
I'm getting MEMORY_MANAGEMENT Blue Screens very regularly for some reason.
I would be so glad if you could help me with this frustrating issue.
I attached the Minidump file.
Cheers!
Trouble
Noob Whisperer
First make sure your machine is configured properly to facilitate the collection of .dmp files.
Go to Start and type in sysdm.cpl and press Enter
Click on the Advanced tab
Click on the Startup and Recovery Settings button
Ensure that Automatically restart is unchecked
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be found later
Click OK twice to exit the dialogs, then reboot for the changes to take effect.
Then:
Please read the first post in this sticky thread here How to ask for help with a BSOD problem
Do your best to accumulate the data required.
Run the SF Diagnostic tool (download and right click the executable and choose run as administrator)
Download and run CPUz. Use the Windows snipping tool to gather images from all tabs including all slots populated with memory under the SPD tab.
Likewise RAMMon. Export the html report, put everything into a desktop folder that you've created for this purpose, zip it up and attach it to your next post (right click it and choose send to, compressed (zipped) folder.
Additionally, if you haven’t already, please take some time and fill out your system specs in your forum profile area http://windows7forums.com/windows-7...you-filling-your-system-specs.html#post235529 .
Good luck
Randy
Your bsod occurs within the first minute of login and occurs within a kernel driver therefore the kernel driver is the victim rather than the cause. Does this also happen in safe mode.
Elmer
Hi dionarap and another Welcome to The Forum.
STOP 0x0000001A: MEMORY_MANAGEMENT
Usual causes:
Device driver, memory, kernel
Your latest dump file lists win32k.sys as the probable cause.
This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
Random stop codes can often indicate hardware issues.
As a Priority:
Please:
Download and run CPU-Z. Take screenshots**/snips of the CPU tab, Mainboard tab, Memory tab and all the slot #'s under the SPD tab.
Go to Post Reply, click on the Go Advanced button and attach the screenshots**/snips to your post for all the RAM experts to see by using the paper clip you will find on the top toolbar. Do not zip them up.
If screenshots, please crop.
There's a very good chance you may need to run Memtest86+, but please don't try before we've seen the above screenshots. It may be your Ram just needs a tweak. But in anticipation, please note and see:
Run Memtest86+ overnight, after your computer has been off for about an hour or two so it has a cold start. Ideally let it run for at least 7 passes / 6-8 hours. If errors appear before that you can stop that particular test.
Note!! Any time Memtest86+ reports errors, it can be either bad RAM or a bad Mobo slot. Test RAM sticks individually. When you find a good one then test it in all slots. Post back with the results.
Your drivers are in pretty good fettle, the graphics driver though, pre-dates Windows 7. I'd suggest that needs updating.
atikmdag.sys Fri Apr 24 11:50:20 2009 AMD Graphics Drivers
  • Download and install DriverSweeper.
  • Uninstall your current Graphics setup through Programs and Features
  • Boot to (preferably) Safe Mode and run Driver Sweeper to clean up the remnants of your current Graphics set up.
  • Reboot to Normal Mode.
  • Install your new Graphics set up.
The info that this tool collects would, although not essential at this stage, be very helpful:
Please see: How to ask for help with a BSOD problem Following Method 2:
Download
and run the SF Diagnostics Tool. Right click the SF Diag tool and select Run as Administrator before running. When the reports have been created, zip them up and attach to a post.
Drivers that pre-date Windows 7. Update:
adfs.SYS Thu Aug 14 15:57:15 2008
This ones for info only. Its the Adobe Drive driver. I use Adobe, I've never used Adobe Drive. If you figure out what its for, let me know. Never found a use for it yet!
stwrt.sys Wed Jun 10 07:06:15 2009 SigmaTel Audio Driver. OEM.
Bugcheck Analysis:
Loading Dump File [D:\DOWNLOADS\ DUMPS\dionarap\022412-17971-01.dmp]
Symbol search path is: SRV*C:\Windows\WinDbgSym*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x86 compatible
Built by: 7601.17713.x86fre.win7sp1_gdr.111025-1505
Machine Name:
Kernel base = 0xe2c1b000 PsLoadedModuleList = 0xe2d644d0
Debug session time: Fri Feb 24 08:52:12.200 2012 (UTC + 0:00)
[COLOR=red][B]System Uptime: 0 days 0:01:47.932[/B][/COLOR]
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
0: kd> !analyze-v
No export analyze-v found
0: kd> !analyze
BugCheck 1A, {5003, c0802000, 4a61, d171045}
Probably caused by : win32k.sys ( win32k!memmove+33 )
Followup: MachineOwner
Drivers:
cf154000 cf181000   1394ohci 1394ohci.sys Sat Nov 20 10:01:11 2010 (4CE79C67)
c982d000 c9875000   ACPI     ACPI.sys     Sat Nov 20 08:37:52 2010 (4CE788E0)
e4d56000 e4d66e80   adfs     adfs.SYS     Thu Aug 14 15:57:15 2008 (48A447CB)
ceb44000 ceb9e000   afd      afd.sys      Mon Apr 25 03:18:00 2011 (4DB4D9D8)
cf181000 cf193000   AgileVpn AgileVpn.sys Tue Jul 14 00:55:00 2009 (4A5BC954)
c993c000 c9943000   amdide   amdide.sys   Tue Mar 30 15:48:21 2010 (4BB20F35)
cf12a000 cf13c000   amdk8    amdk8.sys    Tue Jul 14 00:11:03 2009 (4A5BBF07)
c99c1000 c99ca000   amdxata  amdxata.sys  Fri Mar 19 16:19:01 2010 (4BA3A3F5)
d81a2000 d81a4f00   aswFsBlk aswFsBlk.SYS Mon Nov 28 17:51:49 2011 (4ED3CA35)
d816a000 d81a2000   aswMonFlt aswMonFlt.sys Mon Nov 28 17:52:06 2011 (4ED3CA46)
ceb9e000 ceba4500   aswRdr   aswRdr.SYS   Mon Nov 28 17:52:17 2011 (4ED3CA51)
cea30000 cea9d000   aswSnx   aswSnx.SYS   Mon Nov 28 17:53:52 2011 (4ED3CAB0)
cf0be000 cf108b00   aswSP    aswSP.SYS    Mon Nov 28 17:53:33 2011 (4ED3CA9D)
ceb39000 ceb43d80   aswTdi   aswTdi.SYS   Mon Nov 28 17:52:14 2011 (4ED3CA4E)
e767e000 e7687000   asyncmac asyncmac.sys Tue Jul 14 00:54:46 2009 (4A5BC946)
c9995000 c999e000   atapi    atapi.sys    Tue Jul 14 00:11:15 2009 (4A5BBF13)
c999e000 c99c1000   ataport  ataport.SYS  Sat Nov 20 08:38:00 2010 (4CE788E8)
d0036000 d048a000   atikmdag atikmdag.sys Fri Apr 24 11:50:20 2009 (49F1996C)
c9e11000 c9e19000   AtiPcie  AtiPcie.sys  Wed Mar 10 14:33:41 2010 (4B97ADC5)
dac40000 dac8d000   ATMFD    ATMFD.DLL    Sat Feb 19 04:34:53 2011 (4D5F486D)
ceaa4000 ceaab000   Beep     Beep.SYS     Tue Jul 14 00:45:00 2009 (4A5BC6FC)
cf0b0000 cf0be000   blbdrive blbdrive.sys Tue Jul 14 00:23:04 2009 (4A5BC1D8)
c9646000 c964e000   BOOTVID  BOOTVID.dll  Tue Jul 14 02:04:34 2009 (4A5BD9A2)
e4cab000 e4cc4000   bowser   bowser.sys   Wed Feb 23 04:47:32 2011 (4D649164)
dac20000 dac3e000   cdd      cdd.dll      Sat Nov 20 11:56:35 2010 (4CE7B773)
c9de0000 c9dff000   cdrom    cdrom.sys    Sat Nov 20 08:38:09 2010 (4CE788F1)
c9690000 c973b000   CI       CI.dll       Sat Nov 20 12:05:17 2010 (4CE7B97D)
c9d89000 c9dae000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:11:20 2009 (4A5BBF18)
c964e000 c9690000   CLFS     CLFS.SYS     Tue Jul 14 00:11:10 2009 (4A5BBF0E)
c9b8f000 c9bec000   cng      cng.sys      Thu Nov 17 03:36:35 2011 (4EC48143)
d0025000 d0032000   CompositeBus CompositeBus.sys Sat Nov 20 09:50:21 2010 (4CE799DD)
d80bd000 d80ca000   crashdmp crashdmp.sys Tue Jul 14 00:45:50 2009 (4A5BC72E)
cf034000 cf098000   csc      csc.sys      Sat Nov 20 08:44:32 2010 (4CE78A70)
cf098000 cf0b0000   dfsc     dfsc.sys     Sat Nov 20 08:42:32 2010 (4CE789F8)
c960a000 c9616000   discache discache.sys Tue Jul 14 00:24:04 2009 (4A5BC214)
c9e00000 c9e11000   disk     disk.sys     Tue Jul 14 00:11:28 2009 (4A5BBF20)
d2d8e000 d2da7000   drmk     drmk.sys     Tue Jul 14 01:36:05 2009 (4A5BD2F5)
d80d5000 d80de000   dump_atapi dump_atapi.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
d80ca000 d80d5000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:11:16 2009 (4A5BBF14)
d80de000 d80ef000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:12:47 2009 (4A5BBF6F)
d80b3000 d80bd000   Dxapi    Dxapi.sys    Tue Jul 14 00:25:25 2009 (4A5BC265)
d048a000 d0541000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:08:14 2010 (4CE78FFE)
d0541000 d057a000   dxgmms1  dxgmms1.sys  Thu Feb 03 03:45:05 2011 (4D4A24C1)
c9600000 c960a000   ElbyCDIO ElbyCDIO.sys Thu Dec 16 22:57:56 2010 (4D0A9974)
c9800000 c9811000   fileinfo fileinfo.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
d809c000 d80b2880   fireface fireface.sys Tue Jan 17 11:05:13 2012 (4F1555E9)
c99ca000 c99fe000   fltmgr   fltmgr.sys   Tue Jul 14 00:11:13 2009 (4A5BBF11)
c9a00000 c9a09000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:11:14 2009 (4A5BBF12)
c9d57000 c9d89000   fvevol   fvevol.sys   Sat Nov 20 08:40:22 2010 (4CE78976)
c9f66000 c9f97000   fwpkclnt fwpkclnt.sys Sat Nov 20 08:39:08 2010 (4CE7892C)
e302d000 e3064000   hal      halmacpi.dll Sat Nov 20 08:37:38 2010 (4CE788D2)
d057a000 d0599000   HDAudBus HDAudBus.sys Sat Nov 20 09:59:28 2010 (4CE79C00)
d2d0f000 d2d5f000   HdAudio  HdAudio.sys  Sat Nov 20 10:00:19 2010 (4CE79C33)
d8113000 d8126000   HIDCLASS HIDCLASS.SYS Sat Nov 20 09:59:37 2010 (4CE79C09)
d8126000 d812c480   HIDPARSE HIDPARSE.SYS Tue Jul 14 00:50:59 2009 (4A5BC863)
d8108000 d8113000   hidusb   hidusb.sys   Sat Nov 20 09:59:38 2010 (4CE79C0A)
e4c26000 e4cab000   HTTP     HTTP.sys     Sat Nov 20 08:40:17 2010 (4CE78971)
c9ff7000 c9fff000   hwpolicy hwpolicy.sys Sat Nov 20 08:37:35 2010 (4CE788CF)
c9616000 c9623000   kbdclass kbdclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
d812d000 d8139000   kbdhid   kbdhid.sys   Sat Nov 20 09:50:10 2010 (4CE799D2)
e0ba7000 e0baf000   kdcom    kdcom.dll    Tue Jul 14 02:08:58 2009 (4A5BDAAA)
d2c78000 d2cac000   ks       ks.sys       Sat Nov 20 09:50:17 2010 (4CE799D9)
c9b7c000 c9b8f000   ksecdd   ksecdd.sys   Thu Nov 17 03:15:56 2011 (4EC47C6C)
c9d05000 c9d2a000   ksecpkg  ksecpkg.sys  Thu Nov 17 03:37:34 2011 (4EC4817E)
d0599000 d05aa000   l160x86  l160x86.sys  Tue Oct 13 03:08:17 2009 (4AD3E111)
d81bf000 d81cf000   lltdio   lltdio.sys   Tue Jul 14 00:53:18 2009 (4A5BC8EE)
d814f000 d816a000   luafv    luafv.sys    Tue Jul 14 00:15:44 2009 (4A5BC020)
c962a000 c9635000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 00:13:13 2009 (4A5BBF89)
d8139000 d8144000   monitor  monitor.sys  Tue Jul 14 00:25:58 2009 (4A5BC286)
d2c37000 d2c44000   mouclass mouclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
d8144000 d814f000   mouhid   mouhid.sys   Tue Jul 14 00:45:08 2009 (4A5BC704)
c9943000 c9959000   mountmgr mountmgr.sys Sat Nov 20 08:38:09 2010 (4CE788F1)
e4cc4000 e4cd6000   mpsdrv   mpsdrv.sys   Tue Jul 14 00:52:52 2009 (4A5BC8D4)
e4cd6000 e4cf9000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:17:20 2011 (4DB77CB0)
e4cf9000 e4d34000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:29:57 2011 (4E17BD25)
e4d34000 e4d4f000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:17:26 2011 (4DB77CB6)
ceafd000 ceb08000   Msfs     Msfs.SYS     Tue Jul 14 00:11:26 2009 (4A5BBF1E)
c987e000 c9886000   msisadrv msisadrv.sys Tue Jul 14 00:11:09 2009 (4A5BBF0D)
c9b51000 c9b7c000   msrpc    msrpc.sys    Tue Jul 14 00:11:59 2009 (4A5BBF3F)
c9822000 c982c000   mssmbios mssmbios.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
c9fe7000 c9ff7000   mup      mup.sys      Tue Jul 14 00:14:14 2009 (4A5BBFC6)
c9c10000 c9cc7000   ndis     ndis.sys     Sat Nov 20 08:39:19 2010 (4CE78937)
cf1ab000 cf1b6000   ndistapi ndistapi.sys Tue Jul 14 00:54:24 2009 (4A5BC930)
cf1b6000 cf1d8000   ndiswan  ndiswan.sys  Sat Nov 20 10:07:48 2010 (4CE79DF4)
d2cfe000 d2d0f000   NDProxy  NDProxy.SYS  Sat Nov 20 10:07:39 2010 (4CE79DEB)
cea00000 cea0e000   netbios  netbios.sys  Tue Jul 14 00:53:54 2009 (4A5BC912)
ceba5000 cebd7000   netbt    netbt.sys    Sat Nov 20 08:39:22 2010 (4CE7893A)
c9cc7000 c9d05000   NETIO    NETIO.SYS    Sat Nov 20 08:40:03 2010 (4CE78963)
ceb08000 ceb16000   Npfs     Npfs.SYS     Tue Jul 14 00:11:31 2009 (4A5BBF23)
c9c00000 c9c0a000   nsiproxy nsiproxy.sys Tue Jul 14 00:12:08 2009 (4A5BBF48)
e2c1b000 e302d000   nt       ntkrpamp.exe Wed Oct 26 03:21:40 2011 (4EA76EB4)
c9a22000 c9b51000   Ntfs     Ntfs.sys     Fri Mar 11 03:21:11 2011 (4D799527)
cea9d000 ceaa4000   Null     Null.SYS     Tue Jul 14 00:11:12 2009 (4A5BBF10)
cebde000 cebfd000   pacer    pacer.sys    Tue Jul 14 00:53:58 2009 (4A5BC916)
cf13c000 cf154000   parport  parport.sys  Tue Jul 14 00:45:34 2009 (4A5BC71E)
c98bb000 c98cc000   partmgr  partmgr.sys  Sat Nov 20 08:38:14 2010 (4CE788F6)
e4d4f000 e4d56000   parvdm   parvdm.sys   Tue Jul 14 00:45:29 2009 (4A5BC719)
c9886000 c98b0000   pci      pci.sys      Sat Nov 20 08:37:57 2010 (4CE788E5)
c9927000 c992e000   pciide   pciide.sys   Tue Jul 14 00:11:19 2009 (4A5BBF17)
c992e000 c993c000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:11:15 2009 (4A5BBF13)
c9bec000 c9bfa000   pcw      pcw.sys      Tue Jul 14 00:11:10 2009 (4A5BBF0E)
e4d67000 e4dfe000   peauth   peauth.sys   Tue Jul 14 01:35:44 2009 (4A5BD2E0)
d2d5f000 d2d8e000   portcls  portcls.sys  Tue Jul 14 00:51:00 2009 (4A5BC864)
c9635000 c9646000   PSHED    PSHED.dll    Tue Jul 14 02:09:36 2009 (4A5BDAD0)
cf193000 cf1ab000   rasl2tp  rasl2tp.sys  Tue Jul 14 00:54:33 2009 (4A5BC939)
cf1d8000 cf1f0000   raspppoe raspppoe.sys Tue Jul 14 00:54:53 2009 (4A5BC94D)
cf000000 cf017000   raspptp  raspptp.sys  Tue Jul 14 00:54:47 2009 (4A5BC947)
cf017000 cf02e000   rassstp  rassstp.sys  Tue Jul 14 00:54:57 2009 (4A5BC951)
c97ba000 c97fb000   rdbss    rdbss.sys    Sat Nov 20 08:42:44 2010 (4CE78A04)
cf1f0000 cf1fa000   rdpbus   rdpbus.sys   Tue Jul 14 01:02:40 2009 (4A5BCB20)
ceae5000 ceaed000   RDPCDD   RDPCDD.sys   Sat Nov 20 10:22:19 2010 (4CE7A15B)
ceaed000 ceaf5000   rdpencdd rdpencdd.sys Tue Jul 14 01:01:39 2009 (4A5BCAE3)
ceaf5000 ceafd000   rdprefmp rdprefmp.sys Tue Jul 14 01:01:41 2009 (4A5BCAE5)
c9d2a000 c9d57000   rdyboost rdyboost.sys Sat Nov 20 09:00:07 2010 (4CE78E17)
d81cf000 d81e2000   rspndr   rspndr.sys   Tue Jul 14 00:53:20 2009 (4A5BC8F0)
d2c50000 d2c76000   SCSIPORT SCSIPORT.SYS Sat Nov 20 09:50:55 2010 (4CE799FF)
e4c00000 e4c0a000   secdrv   secdrv.SYS   Wed Sep 13 14:18:32 2006 (45080528)
d001b000 d0025000   serenum  serenum.sys  Tue Jul 14 00:45:27 2009 (4A5BC717)
cea0e000 cea28000   serial   serial.sys   Tue Jul 14 00:45:33 2009 (4A5BC71D)
c9fdf000 c9fe7000   spldr    spldr.sys    Mon May 11 17:13:47 2009 (4A084EBB)
e762c000 e767e000   srv      srv.sys      Fri Apr 29 03:46:30 2011 (4DBA2686)
d2da7000 d2df7000   srv2     srv2.sys     Fri Apr 29 03:46:13 2011 (4DBA2675)
d8000000 d8021000   srvnet   srvnet.sys   Fri Apr 29 03:46:08 2011 (4DBA2670)
d8035000 d809c000   stwrt    stwrt.sys    Wed Jun 10 07:06:15 2009 (4A2F4D57)
d2c76000 d2c77380   swenum   swenum.sys   Tue Jul 14 00:45:08 2009 (4A5BC704)
c9e1c000 c9f66000   tcpip    tcpip.sys    Thu Sep 29 04:22:11 2011 (4E83E463)
e4c0a000 e4c17000   tcpipreg tcpipreg.sys Sat Nov 20 10:07:13 2010 (4CE79DD1)
ceb2d000 ceb39000   TDI      TDI.SYS      Sat Nov 20 08:39:18 2010 (4CE78936)
ceb16000 ceb2d000   tdx      tdx.sys      Sat Nov 20 08:39:17 2010 (4CE78935)
c9811000 c9822000   termdd   termdd.sys   Sat Nov 20 10:21:10 2010 (4CE7A116)
daff0000 daff9000   TSDDD    TSDDD.dll    unavailable (00000000)
cf109000 cf12a000   tunnel   tunnel.sys   Sat Nov 20 10:06:40 2010 (4CE79DB0)
d2cac000 d2cba000   umbus    umbus.sys    Sat Nov 20 10:00:23 2010 (4CE79C37)
d80ef000 d8106000   usbccgp  usbccgp.sys  Fri Mar 25 02:58:06 2011 (4D8C04BE)
d8106000 d8107700   USBD     USBD.SYS     Fri Mar 25 02:57:53 2011 (4D8C04B1)
d000c000 d001b000   usbehci  usbehci.sys  Fri Mar 25 02:57:58 2011 (4D8C04B6)
d0000000 d000c000   usbfilter usbfilter.sys Wed Dec 15 10:34:42 2010 (4D0899C2)
d2cba000 d2cfe000   usbhub   usbhub.sys   Fri Mar 25 02:58:34 2011 (4D8C04DA)
d05aa000 d05b4000   usbohci  usbohci.sys  Fri Mar 25 02:57:58 2011 (4D8C04B6)
d05b4000 d05ff000   USBPORT  USBPORT.SYS  Fri Mar 25 02:58:05 2011 (4D8C04BD)
d2c44000 d2c50000   VClone   VClone.sys   Sat Jan 15 16:20:14 2011 (4D31C93E)
c98b0000 c98bb000   vdrvroot vdrvroot.sys Tue Jul 14 00:46:19 2009 (4A5BC74B)
ceaab000 ceab7000   vga      vga.sys      Tue Jul 14 00:25:50 2009 (4A5BC27E)
ceab7000 cead8000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:25:49 2009 (4A5BC27D)
c9959000 c9982180   vmbus    vmbus.sys    Sat Nov 20 09:14:58 2010 (4CE79192)
c9f97000 c9f9f380   vmstorfl vmstorfl.sys Sat Nov 20 09:14:37 2010 (4CE7917D)
c98cc000 c98dc000   volmgr   volmgr.sys   Sat Nov 20 08:38:06 2010 (4CE788EE)
c98dc000 c9927000   volmgrx  volmgrx.sys  Tue Jul 14 00:11:41 2009 (4A5BBF2D)
c9fa0000 c9fdf000   volsnap  volsnap.sys  Sat Nov 20 08:38:13 2010 (4CE788F5)
c9a09000 c9a1c000   wanarp   wanarp.sys   Sat Nov 20 10:07:45 2010 (4CE79DF1)
cead8000 ceae5000   watchdog watchdog.sys Tue Jul 14 00:24:10 2009 (4A5BC21A)
c973b000 c97ac000   Wdf01000 Wdf01000.sys Tue Jul 14 00:11:36 2009 (4A5BBF28)
c97ac000 c97ba000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:11:25 2009 (4A5BBF1D)
cebd7000 cebde000   wfplwf   wfplwf.sys   Tue Jul 14 00:53:51 2009 (4A5BC90F)
dad90000 dafe0000   win32k   win32k.sys   Sat Jan 14 03:35:31 2012 (4F10F803)
c9983000 c9995000   winhv    winhv.sys    Sat Nov 20 08:38:15 2010 (4CE788F7)
c9875000 c987e000   WMILIB   WMILIB.SYS   Tue Jul 14 00:11:22 2009 (4A5BBF1A)
d81a5000 d81bf000   WudfPf   WudfPf.sys   Sat Nov 20 09:58:55 2010 (4CE79BDF)
Unloaded modules:
c9dae000 c9dbb000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
c9dbb000 c9dc6000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000B000
c9dc6000 c9dcf000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
c9dcf000 c9de0000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
