Windows 8 Microsoft Wireless Display Adapter not pairing with hdtv
Gengo
Greetings,
I have recently bought Microsoft Wireless Display Adapter and am unable to sync it with my hdtv. I plugged in the adapter and powered it through a USB extension but when I add a wireless display, it says "No devices found". My computer is unable to pair with the display adapter and it is very troublesome.
Methods I have tested:
Resetting the display adapter
Scanning multiple times
Turning off the firewall
Updating Windows 8
I downloaded the MWDA's app and it will not activate until connected so it is useless for now. Am I missing something? Do I need to download drivers for the adapter? Also, I think it is important to note the computer did scan some phones nearby so that confirms it is not broken.
Any advice would be appreciated!
Make/model of adapter? Are there any special required for your HDTV for such an adapter? Is there a firmware update for your HDTV, if it's a smart TV?
Make/model of adapter: Model number is 1628
There is nothing special required for my hdtv that I know of.
No updates required because it is not a smart tv.
Hi Gengo, who makes your tv: hp, samsug, sony?
Vizio is the brand of my television.
Edit: Clarification -> Vizio VX32L HDTV10A
I would sugest setting it up by cable first... There is nothing about wireless useage in the user manual = Link Removed
Yes, the television does connect with the computer via hdmi. I suppose I cannot use the adapter on the television then?
