]Много Ви моля за спешна помощ
Здравей те, наясно съм че едвали за първи път виждате подобна тема, но Ви моля да ми помогне те. Не съм сигурна какво точно се случва с лаптом ми, но напоследък блокира и нищо освен рестата не помага. Лошото е, че като прегледам Event Viewer ми показва няколко грешчици. Моля Ви да ми помогнете, защото имам спешна нужда от работещ лаптоп. Не знам точно какво Ви трябва затова ви давам тази информация, ако мога да направя още нещо ще го направя. Благодаря Ви.
Elmer
As per Google Translate:
Hey you, I am aware that only the first time you see a similar theme, but please help me they are. I'm not sure what happens to my laptom, but recently blocked and nothing but the change does not help. The bad thing is that as I review the Event Viewer shows several greshchitsi. Please help me, because I urgently need a working laptop. I do not know exactly what you need so I give you this information if I can do something else to do. Thank you.
Hi Akashy and Welcome to the Forum. Добре дошли на форума
Please note any links given are to English UK/US sites. You may have to find language specific drivers.
STOP 0x00000019: BAD_POOL_HEADER
Usual causes:
Device driver
STOP 0x000000D1: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Usual causes:
Device driver
Your dump files list athr.sys Mon Oct 05 17:31:48 2009 as the probable cause. This is your Atheros Extensible Wireless LAN driver for CB42/CB43/MB42/MB43 Network Adapter (D-Link AirPlus DWL-G520 Wireless PCI Adapter(rev.B) discontinued 2008). Atheros
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
Outdated Drivers. Update:
ATKACPI.sys Thu Dec 14 07:11:57 2006 ATK Hotkey ATK0101 ACPI Utility Driver
ASMMAP.sys Sun Feb 04 19:52:50 2007 LENOVO ATK Hotkey ATK0101 ACPI UTILITY
nvsmu.sys Mon Aug 25 11:22:50 2008 nVidia nForce chipset driver
Rt86win7.sys Thu Feb 26 09:04:22 2009 Realtek PCIe GBE Family Controller v7.046
sncduvc.SYS Mon May 12 04:20:30 2008
snp2uvc.sys Mon Aug 11 03:14:10 2008
Suyin USB 2.0 Webcam driver. Check with your O.E.M. Support
Drivers with Updates:
nvlddmkm.sys Wed Mar 17 02:45:14 2010 nVidia Graphics Drivers.
  • Download the latest Graphics Drivers
  • Download and install Driver Sweeper in normal mode.
  • Boot to Safe Mode
  • Uninstall your current Graphics Driver set up using Driver Sweeper.
  • Reboot to Normal Mode.
  • Install your new Graphics Driver set up.
Bugcheck Analysis:
BugCheck D1, {1c, 2, 1, 91cc38c5}
Unable to load image \SystemRoot\system32\DRIVERS\athr.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for athr.sys
*** ERROR: Module load completed but symbols could not be loaded for athr.sys
Probably caused by : athr.sys ( athr+c18c5 )
Followup: MachineOwner
1: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000001c, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, value 0 = read operation, 1 = write operation
Arg4: 91cc38c5, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from 82d69718
Unable to read MiSystemVaType memory at 82d49160
 0000001c
CURRENT_IRQL:  2
FAULTING_IP:
athr+c18c5
91cc38c5 c7401c00000000  mov     dword ptr [eax+1Ch],0
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
TRAP_FRAME:  b68a9b2c -- (.trap 0xffffffffb68a9b2c)
ErrCode = 00000002
eax=00000000 ebx=82d3b580 ecx=00000000 edx=870f8020 esi=00000040 edi=868b0c28
eip=91cc38c5 esp=b68a9ba0 ebp=b68a9ba8 iopl=0         nv up ei pl zr na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00210246
athr+0xc18c5:
91cc38c5 c7401c00000000  mov     dword ptr [eax+1Ch],0 ds:0023:0000001c=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from 91cc38c5 to 82c4781b
STACK_TEXT:
b68a9b2c 91cc38c5 badb0d00 870f8020 870f8020 nt!KiTrap0E+0x2cf
WARNING: Stack unwind information not available. Following frames may be wrong.
b68a9ba8 91cbdb2a 870f8020 870f6000 b68a9bcc athr+0xc18c5
b68a9bf8 91c7efd8 870f8020 00000001 870f6000 athr+0xbbb2a
b68a9c38 91c76704 870f4020 86c8d020 b68a9c6c athr+0x7cfd8
b68a9c48 91c38d40 86c8d020 868b0c28 00000040 athr+0x74704
b68a9c6c 91c048b8 8af8e028 b68a9ca8 00000000 athr+0x36d40
b68a9c88 91c07892 870e7028 b68a9ca8 8af79748 athr+0x28b8
b68a9cdc 8b31330a 8af79748 86b486b8 b68a9d00 athr+0x5892
b68a9cec 82e21b25 86cd0028 86b486b8 85cfed48 ndis!ndisDispatchIoWorkItem+0xf
b68a9d00 82c6f03b 868b0c28 00000000 85cfed48 nt!IopProcessWorkItem+0x23
b68a9d50 82e0f9df 80000000 8cfcfa25 00000000 nt!ExpWorkerThread+0x10d
b68a9d90 82cc11d9 82c6ef2e 80000000 00000000 nt!PspSystemThreadStartup+0x9e
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
STACK_COMMAND:  kb
FOLLOWUP_IP:
athr+c18c5
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  athr+c18c5
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: athr
IMAGE_NAME:  athr.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4aca1f74
FAILURE_BUCKET_ID:  0xD1_athr+c18c5
Drivers:
8b1b0000 8b1f8000   ACPI     ACPI.sys     Tue Jul 14 00:11:11 2009 (4A5BBF0F)
90c94000 90cee000   afd      afd.sys      Tue Jul 14 00:12:34 2009 (4A5BBF62)
91d94000 91da6000   AgileVpn AgileVpn.sys Tue Jul 14 00:55:00 2009 (4A5BC954)
8b2b0000 8b2b9000   amdxata  amdxata.sys  Tue May 19 18:57:35 2009 (4A12F30F)
8b2fe000 8b308000   AsDsm    AsDsm.sys    Fri Feb 13 06:13:31 2009 (49950F8B)
91ff9000 92000000   ASMMAP   ASMMAP.sys   Sun Feb 04 19:52:50 2007 (45C63992)
8b27a000 8b283000   atapi    atapi.sys    Tue Jul 14 00:11:15 2009 (4A5BBF13)
8b283000 8b2a6000   ataport  ataport.SYS  Tue Jul 14 00:11:18 2009 (4A5BBF16)
91c02000 91d2f000   athr     athr.sys     Mon Oct 05 17:31:48 2009 (4ACA1F74)
91d7f000 91d87000   ATKACPI  ATKACPI.sys  Thu Dec 14 07:11:57 2006 (4580F93D)
a5ef2000 a5f1a000   AVGIDSDriver AVGIDSDriver.Sys Tue Aug 03 23:24:21 2010 (4C589715)
8b91b000 8b924000   AVGIDSEH AVGIDSEH.Sys Mon Sep 13 23:46:35 2010 (4C8EA9CB)
a0b2e000 a0b38000   AVGIDSFilter AVGIDSFilter.Sys Tue Aug 03 23:23:18 2010 (4C5896D6)
a0b46000 a0b4f000   AVGIDSShim AVGIDSShim.Sys Tue Aug 03 23:25:56 2010 (4C589774)
910a7000 910e2d00   avgldx86 avgldx86.sys Wed Dec 08 02:00:20 2010 (4CFEE6B4)
8b976000 8b982000   avgmfx86 avgmfx86.sys Tue Sep 07 01:48:01 2010 (4C858BC1)
8b916000 8b91ab80   avgrkx86 avgrkx86.sys Tue Sep 07 01:48:16 2010 (4C858BD0)
90c1a000 90c61980   avgtdix  avgtdix.sys  Fri Nov 12 11:05:58 2010 (4CDD1F96)
91d39000 91d72000   ay9z8b9w ay9z8b9w.SYS Tue Jul 14 22:12:41 2009 (4A5CF4C9)
83200000 8320b000   BATTC    BATTC.SYS    Tue Jul 14 00:19:15 2009 (4A5BC0F3)
8b989000 8b990000   Beep     Beep.SYS     Tue Jul 14 00:45:00 2009 (4A5BC6FC)
91099000 910a7000   blbdrive blbdrive.sys Tue Jul 14 00:23:04 2009 (4A5BC1D8)
832be000 832c6000   BOOTVID  BOOTVID.dll  Tue Jul 14 02:04:34 2009 (4A5BD9A2)
a0a8a000 a0aa3000   bowser   bowser.sys   Tue Jul 14 00:14:21 2009 (4A5BBFCD)
99120000 9913e000   cdd      cdd.dll      unavailable (00000000)
8b957000 8b976000   cdrom    cdrom.sys    Tue Jul 14 00:11:24 2009 (4A5BBF1C)
83308000 833b3000   CI       CI.dll       Tue Jul 14 02:09:28 2009 (4A5BDAC8)
8b8f1000 8b916000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:11:20 2009 (4A5BBF18)
832c6000 83308000   CLFS     CLFS.SYS     Tue Jul 14 00:11:10 2009 (4A5BBF0E)
91d7b000 91d7e700   CmBatt   CmBatt.sys   Tue Jul 14 00:19:18 2009 (4A5BC0F6)
8b57a000 8b5d7000   cng      cng.sys      Tue Jul 14 00:32:55 2009 (4A5BC427)
8b000000 8b008000   compbatt compbatt.sys Tue Jul 14 00:19:18 2009 (4A5BC0F6)
91d87000 91d94000   CompositeBus CompositeBus.sys Tue Jul 14 00:45:26 2009 (4A5BC716)
9882c000 98839000   crashdmp crashdmp.sys Tue Jul 14 00:45:50 2009 (4A5BC72E)
9101d000 91081000   csc      csc.sys      Tue Jul 14 00:15:08 2009 (4A5BBFFC)
91081000 91099000   dfsc     dfsc.sys     Tue Jul 14 00:14:16 2009 (4A5BBFC8)
90dab000 90db7000   discache discache.sys Tue Jul 14 00:24:04 2009 (4A5BC214)
8b8e0000 8b8f1000   disk     disk.sys     Tue Jul 14 00:11:28 2009 (4A5BBF20)
91ef3000 91f0c000   drmk     drmk.sys     Tue Jul 14 01:36:05 2009 (4A5BD2F5)
91f25000 91f30000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:11:16 2009 (4A5BBF14)
91f3a000 91f4b000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:12:47 2009 (4A5BBF6F)
91f30000 91f3a000   dump_msahci dump_msahci.sys Tue Jul 14 00:45:50 2009 (4A5BC72E)
98817000 98821000   Dxapi    Dxapi.sys    Tue Jul 14 00:25:25 2009 (4A5BC265)
93125000 931dc000   dxgkrnl  dxgkrnl.sys  Tue Nov 02 02:37:53 2010 (4CCF7981)
90db7000 90df0000   dxgmms1  dxgmms1.sys  Thu Feb 03 03:34:49 2011 (4D4A2259)
8b2ed000 8b2fe000   fileinfo fileinfo.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
8b2b9000 8b2ed000   fltmgr   fltmgr.sys   Tue Jul 14 00:11:13 2009 (4A5BBF11)
8b5e5000 8b5ee000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
8b8ae000 8b8e0000   fvevol   fvevol.sys   Sat Sep 26 03:24:21 2009 (4ABD7B55)
8b7be000 8b7ef000   fwpkclnt fwpkclnt.sys Tue Jul 14 00:12:03 2009 (4A5BBF43)
83011000 83048000   hal      halmacpi.dll Tue Jul 14 00:11:03 2009 (4A5BBF07)
911b5000 911d4000   HDAudBus HDAudBus.sys Tue Jul 14 00:50:55 2009 (4A5BC85F)
91e74000 91ec4000   HdAudio  HdAudio.sys  Tue Jul 14 00:51:46 2009 (4A5BC892)
a5ff0000 a5ffb000   hiber_dumpata hiber_dumpata.sys Tue Jul 14 00:11:16 2009 (4A5BBF14)
a5e0a000 a5e1b000   hiber_dumpfve hiber_dumpfve.sys Tue Jul 14 00:12:47 2009 (4A5BBF6F)
a5e00000 a5e0a000   hiber_msahci hiber_msahci.sys Tue Jul 14 00:45:50 2009 (4A5BC72E)
a0a05000 a0a8a000   HTTP     HTTP.sys     Tue Jul 14 00:12:53 2009 (4A5BBF75)
8b8a6000 8b8ae000   hwpolicy hwpolicy.sys Tue Jul 14 00:11:01 2009 (4A5BBF05)
91116000 9112e000   i8042prt i8042prt.sys Tue Jul 14 00:11:23 2009 (4A5BBF1B)
91104000 91116000   intelppm intelppm.sys Tue Jul 14 00:11:03 2009 (4A5BBF07)
9112e000 9113b000   kbdclass kbdclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
80b9e000 80ba6000   kdcom    kdcom.dll    Tue Jul 14 02:08:58 2009 (4A5BDAAA)
8b3c9000 8b3fd000   ks       ks.sys       Thu Mar 04 03:57:52 2010 (4B8F2FC0)
8b567000 8b57a000   ksecdd   ksecdd.sys   Tue Jul 14 00:11:56 2009 (4A5BBF3C)
8b650000 8b675000   ksecpkg  ksecpkg.sys  Fri Dec 11 04:04:22 2009 (4B21C4C6)
91f80000 91f90000   lltdio   lltdio.sys   Tue Jul 14 00:53:18 2009 (4A5BC8EE)
91f4b000 91f66000   luafv    luafv.sys    Tue Jul 14 00:15:44 2009 (4A5BC020)
83235000 832ad000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:06:41 2009 (4A5BDA21)
9113b000 91148000   mouclass mouclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
8b264000 8b27a000   mountmgr mountmgr.sys Tue Jul 14 00:11:27 2009 (4A5BBF1F)
a0aa3000 a0ab5000   mpsdrv   mpsdrv.sys   Tue Jul 14 00:52:52 2009 (4A5BC8D4)
a0ab5000 a0ad8000   mrxsmb   mrxsmb.sys   Sat Feb 27 07:32:02 2010 (4B88CA72)
a0ad8000 a0b13000   mrxsmb10 mrxsmb10.sys Sat Feb 27 07:32:21 2010 (4B88CA85)
a0b13000 a0b2e000   mrxsmb20 mrxsmb20.sys Sat Feb 27 07:32:11 2010 (4B88CA7B)
8b2a6000 8b2b0000   msahci   msahci.sys   Tue Jul 14 00:45:50 2009 (4A5BC72E)
8b9e2000 8b9ed000   Msfs     Msfs.SYS     unavailable (00000000)
8b1f8000 8b200000   msisadrv msisadrv.sys Tue Jul 14 00:11:09 2009 (4A5BBF0D)
8b53c000 8b567000   msrpc    msrpc.sys    unavailable (00000000)
90da1000 90dab000   mssmbios mssmbios.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
8b896000 8b8a6000   mup      mup.sys      Tue Jul 14 00:14:14 2009 (4A5BBFC6)
8b312000 8b3c9000   ndis     ndis.sys     Tue Jul 14 00:12:24 2009 (4A5BBF58)
91dbe000 91dc9000   ndistapi ndistapi.sys Tue Jul 14 00:54:24 2009 (4A5BC930)
91fd6000 91fe6000   ndisuio  ndisuio.sys  Tue Jul 14 00:53:51 2009 (4A5BC90F)
91dc9000 91deb000   ndiswan  ndiswan.sys  Tue Jul 14 00:54:34 2009 (4A5BC93A)
91e63000 91e74000   NDProxy  NDProxy.SYS  Tue Jul 14 00:54:27 2009 (4A5BC933)
90d25000 90d33000   netbios  netbios.sys  Tue Jul 14 00:53:54 2009 (4A5BC912)
90c62000 90c94000   netbt    netbt.sys    Tue Jul 14 00:12:18 2009 (4A5BBF52)
8b612000 8b650000   NETIO    NETIO.SYS    Tue Jul 14 00:12:35 2009 (4A5BBF63)
8b9ed000 8b9fb000   Npfs     Npfs.SYS     Tue Jul 14 00:11:31 2009 (4A5BBF23)
90d97000 90da1000   nsiproxy nsiproxy.sys Tue Jul 14 00:12:08 2009 (4A5BBF48)
82c01000 83011000   nt       ntkrpamp.exe Wed Oct 27 03:30:44 2010 (4CC78ED4)
8b40d000 8b53c000   Ntfs     Ntfs.sys     Tue Jul 14 00:12:05 2009 (4A5BBF45)
8b982000 8b989000   Null     Null.SYS     unavailable (00000000)
93123000 93124040   nvBridge nvBridge.kmd Wed Mar 17 02:25:46 2010 (4BA03DAA)
92615000 93122c00   nvlddmkm nvlddmkm.sys Wed Mar 17 02:45:14 2010 (4BA0423A)
91148000 91151000   nvsmu    nvsmu.sys    Mon Aug 25 11:22:50 2008 (48B287FA)
91f90000 91fd6000   nwifi    nwifi.sys    Tue Jul 14 00:51:59 2009 (4A5BC89F)
90cf5000 90d14000   pacer    pacer.sys    Tue Jul 14 00:53:58 2009 (4A5BC916)
833e8000 833f9000   partmgr  partmgr.sys  Tue Jul 14 00:11:35 2009 (4A5BBF27)
833be000 833e8000   pci      pci.sys      Tue Jul 14 00:11:16 2009 (4A5BBF14)
8b24f000 8b256000   pciide   pciide.sys   Tue Jul 14 00:11:19 2009 (4A5BBF17)
8b256000 8b264000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:11:15 2009 (4A5BBF13)
8b5d7000 8b5e5000   pcw      pcw.sys      Tue Jul 14 00:11:10 2009 (4A5BBF0E)
a0b4f000 a0be6000   peauth   peauth.sys   Tue Jul 14 01:35:44 2009 (4A5BD2E0)
91ec4000 91ef3000   portcls  portcls.sys  Tue Jul 14 00:51:00 2009 (4A5BC864)
832ad000 832be000   PSHED    PSHED.dll    Tue Jul 14 02:09:36 2009 (4A5BDAD0)
8b308000 8b311200   PxHelp20 PxHelp20.sys Thu Mar 13 01:57:44 2008 (47D88A18)
91da6000 91dbe000   rasl2tp  rasl2tp.sys  Tue Jul 14 00:54:33 2009 (4A5BC939)
931dc000 931f4000   raspppoe raspppoe.sys Tue Jul 14 00:54:53 2009 (4A5BC94D)
91000000 91017000   raspptp  raspptp.sys  Tue Jul 14 00:54:47 2009 (4A5BC947)
90c00000 90c17000   rassstp  rassstp.sys  Tue Jul 14 00:54:57 2009 (4A5BC951)
90d56000 90d97000   rdbss    rdbss.sys    Tue Jul 14 00:14:26 2009 (4A5BBFD2)
91deb000 91df5000   rdpbus   rdpbus.sys   Tue Jul 14 01:02:40 2009 (4A5BCB20)
8b9ca000 8b9d2000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:01:40 2009 (4A5BCAE4)
8b9d2000 8b9da000   rdpencdd rdpencdd.sys Tue Jul 14 01:01:39 2009 (4A5BCAE3)
8b9da000 8b9e2000   rdprefmp rdprefmp.sys Tue Jul 14 01:01:41 2009 (4A5BCAE5)
8b869000 8b896000   rdyboost rdyboost.sys Tue Jul 14 00:22:02 2009 (4A5BC19A)
91fe6000 91ff9000   rspndr   rspndr.sys   Tue Jul 14 00:53:20 2009 (4A5BC8F0)
911d4000 911f9000   Rt86win7 Rt86win7.sys Thu Feb 26 09:04:22 2009 (49A65B16)
8b18a000 8b1b0000   SCSIPORT SCSIPORT.SYS Tue Jul 14 00:45:55 2009 (4A5BC733)
a0be6000 a0bf0000   secdrv   secdrv.SYS   Wed Sep 13 14:18:32 2006 (45080528)
989f3000 989fa000   sncduvc  sncduvc.SYS  Mon May 12 04:20:30 2008 (4827B77E)
98839000 989e4e80   snp2uvc  snp2uvc.sys  Mon Aug 11 03:14:10 2008 (489FA072)
8b861000 8b869000   spldr    spldr.sys    Mon May 11 17:13:47 2009 (4A084EBB)
8b088000 8b181000   sptd     sptd.sys     Thu Apr 08 02:28:24 2010 (4BBD3138)
a5f1a000 a5f6b000   srv      srv.sys      Fri Aug 27 04:31:26 2010 (4C77318E)
a5e39000 a5e88000   srv2     srv2.sys     Fri Aug 27 04:30:45 2010 (4C773165)
8b924000 8b945000   srvnet   srvnet.sys   Fri Aug 27 04:30:39 2010 (4C77315F)
989e5000 989f2180   STREAM   STREAM.SYS   Tue Jul 14 00:50:57 2009 (4A5BC861)
91df5000 91df6380   swenum   swenum.sys   Tue Jul 14 00:45:08 2009 (4A5BC704)
8b675000 8b7be000   tcpip    tcpip.sys    Mon Jun 14 04:36:59 2010 (4C15A3DB)
a0bf0000 a0bfd000   tcpipreg tcpipreg.sys Tue Jul 14 00:54:14 2009 (4A5BC926)
8b817000 8b822000   TDI      TDI.SYS      Tue Jul 14 00:12:12 2009 (4A5BBF4C)
8b800000 8b817000   tdx      tdx.sys      Tue Jul 14 00:12:10 2009 (4A5BBF4A)
90d46000 90d56000   termdd   termdd.sys   Tue Jul 14 01:01:35 2009 (4A5BCADF)
990f0000 990f9000   TSDDD    TSDDD.dll    unavailable (00000000)
910e3000 91104000   tunnel   tunnel.sys   Tue Jul 14 00:54:03 2009 (4A5BC91B)
92600000 9260e000   umbus    umbus.sys    Tue Jul 14 00:51:38 2009 (4A5BC88A)
91f0c000 91f23000   usbccgp  usbccgp.sys  Tue Jul 14 00:51:31 2009 (4A5BC883)
91f23000 91f24700   USBD     USBD.SYS     Tue Jul 14 00:51:05 2009 (4A5BC869)
911a6000 911b5000   usbehci  usbehci.sys  Sat Oct 24 04:58:55 2009 (4AE27B7F)
91e1f000 91e63000   usbhub   usbhub.sys   Sat Oct 24 05:00:05 2009 (4AE27BC5)
91151000 9115b000   usbohci  usbohci.sys  Tue Jul 14 00:51:14 2009 (4A5BC872)
9115b000 911a6000   USBPORT  USBPORT.SYS  Tue Jul 14 00:51:13 2009 (4A5BC871)
98800000 98817000   USBSTOR  USBSTOR.SYS  Tue Jul 14 00:51:19 2009 (4A5BC877)
833b3000 833be000   vdrvroot vdrvroot.sys Tue Jul 14 00:46:19 2009 (4A5BC74B)
8b990000 8b99c000   vga      vga.sys      Tue Jul 14 00:25:50 2009 (4A5BC27E)
8b99c000 8b9bd000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:25:49 2009 (4A5BC27D)
8b7ef000 8b7f8000   vmstorfl vmstorfl.sys unavailable (00000000)
8321b000 8322f000   vodafone_K3805_z_dc_enum vodafone_K3805-z_dc_enum.sys Mon Mar 01 18:31:49 2010 (4B8C0815)
8320b000 8321b000   volmgr   volmgr.sys   Tue Jul 14 00:11:25 2009 (4A5BBF1D)
8b204000 8b24f000   volmgrx  volmgrx.sys  unavailable (00000000)
8b822000 8b861000   volsnap  volsnap.sys  Tue Jul 14 00:11:34 2009 (4A5BBF26)
91d2f000 91d39000   vwifibus vwifibus.sys Tue Jul 14 00:52:02 2009 (4A5BC8A2)
90d14000 90d25000   vwififlt vwififlt.sys Tue Jul 14 00:52:03 2009 (4A5BC8A3)
91e00000 91e09000   vwifimp  vwifimp.sys  Tue Jul 14 00:52:09 2009 (4A5BC8A9)
90d33000 90d46000   wanarp   wanarp.sys   Tue Jul 14 00:55:02 2009 (4A5BC956)
8b9bd000 8b9ca000   watchdog watchdog.sys Tue Jul 14 00:24:10 2009 (4A5BC21A)
8b009000 8b07a000   Wdf01000 Wdf01000.sys Tue Jul 14 00:11:36 2009 (4A5BBF28)
8b07a000 8b088000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:11:25 2009 (4A5BBF1D)
90cee000 90cf5000   wfplwf   wfplwf.sys   Tue Jul 14 00:53:51 2009 (4A5BC90F)
98e90000 990db000   win32k   win32k.sys   unavailable (00000000)
91d72000 91d7b000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:19:16 2009 (4A5BC0F4)
8b181000 8b18a000   WMILIB   WMILIB.SYS   Tue Jul 14 00:11:22 2009 (4A5BBF1A)
91f66000 91f80000   WudfPf   WudfPf.sys   Tue Jul 14 00:50:13 2009 (4A5BC835)
a5f6b000 a5f8b480   WUDFRd   WUDFRd.sys   Tue Jul 14 00:50:44 2009 (4A5BC854)
Unloaded modules:
a5fe5000 a5ff0000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000B000
a5fbf000 a5fca000   hiber_pciide
    Checksum:  00000000
    ImageSize:  0000B000
a5fca000 a5fd4000   hiber_msahci
    Checksum:  00000000
    ImageSize:  0000A000
a5fd4000 a5fe5000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00011000
a5fb2000 a5fbd000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000B000
a5fbd000 a5fbf000   MSPQM.sys
    Checksum:  00000000
    ImageSize:  00002000
a5f8c000 a5f97000   hiber_pciide
    Checksum:  00000000
    ImageSize:  0000B000
a5f97000 a5fa1000   hiber_msahci
    Checksum:  00000000
    ImageSize:  0000A000
a5fa1000 a5fb2000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00011000
98821000 9882c000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000B000
a5e88000 a5ef2000   spsys.sys
    Checksum:  00000000
    ImageSize:  0006A000
a0b2e000 a0b46000   parport.sys
    Checksum:  00000000
    ImageSize:  00018000
8b924000 8b931000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
8b931000 8b93c000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000B000
8b93c000 8b946000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000A000
8b946000 8b957000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
Some other things you may wish to consider:
AVG is known to be a cause of BSOD's on Windows 7 systems. If you decide or need to uninstall it: Download the correct AVG Remover for your system (32 or 64 bit).
If you have AVG ID protection installed, download the AVGID Protection Remover from the above link as well (it wouldn't hurt to download and run it anyway). Download Microsoft Security Essentials as AVG's replacement. Re-boot to Safe Mode. In Safe Mode run the AVG Removal tools. Re-boot to normal mode and install MSE. Make sure your Windows firewall is enabled!
Just to let you know. The older version of the sptd driver used by Daemon Tools is notorious for causing BSOD's on Windows 7. I'm not sure of the 2010 version you have installed though.
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
