Windows 7 Monitor Hertz
JohnCiber
Hi everybody
I install windows 7 few minutes ago, and is sooo good jeje
0 problems for now, is fast and very cute Link Removed - Invalid URL xD
Just one little thing: In windows Xp i use my monitor in 1280x1024 with 75Hz without problems.
But here in Windows 7, i use the same resolution but with 60hz and i can't change to 75hertz
A Picture:
http://i39.tinypic.com/21epz5j.jpg
There's a way to use 75hz or "unlock" the rest of the hertz options?
My computer:
Nvidia GeForce 9600GSP 384mb
Intel Core 2 Duo E4500
2Gb Ram
Thanks!!
Dark Light
I have the same problem, I can't get my 2304 x 1440 res. I also can't get higher Hz, try lowwering the res (from Nvidia control panel), then changing it back to what it should be @ 75 Hz. You can "unlock" other option, by going to display settings (or what ever Windows 7 calls it), then find you way to monioter settings and uncheck hide mode.
