Windows 7 Monitor won't work......
kevinkrg6
My old crt will work, but my 22" lcd won't work (dvi). It works until after the windows boot screen with the little fairy things, then it's blank. The crt is vga as opposed to dvi, should I try the vga connection on my lcd and see if that works?
Works, used vga connection, can't get full resolutions, but its better than my CRT. Now if I could only get the internet to work.....:mad::mad::mad::mad:
Sometimes it helps turning the monitor on/off - i know it sounds ridiculous.. Also, is your video card updated?
