rronaldson
- Joined
- Oct 23, 2009
- Location
- UK
I installed W7 a few days ago but had problems so I reinstalled it today setting up the same user name as before.
I had my My Documents folder on my D drive and set that up as it's new location. On my new installation that My Documents folder is only readable. If I try and add anything to it or do anything with any files in it, even copy out, it says that I do not have permissions to do so. If I look in the Security tab of Properties it says that I have, or at least a User with the same name has, full permissions.
I have got around the problem by renaming it and setting up a new My Documents folder and populating that from a backup. My problem now is that I can't get rid of the old My Documents folder and it's taking up a lot of space.
My theory is that although I have set up my User name the same as the old one whatever identifies the owner of my old My Documents folder sees my current user as a different one. Would appreciate very much some advice on how to get rid of the folder.
