Windows 7 My Documents from XP 32 bit to 7 64 bit
WilliamP
Would it be possible to download (My Documents) from my XP 32 bit system to a flash drive and load it in my Win.7 64 bit system?
Hi
That shouldn't be any problem at all.
The difference between 32 bit and 64 bit has more to do with how software runs, (some old software may not run in 64 bit) but it doesn't have much to do with how it reads data files from a practical standpoint.
It should see your files just as your old computer did.
Mike
Hi
Mike
