DamyNox
Hi There !
I would like to have some help with Classic Shell for Skinning the Start Menu !
Here what I need :
I would like to hide or disable this popup description that show my real name on the user picture and on the username in the Start Menu !
(Here what I want to hide on this two pictures, encircle in yellow !)
An image from 'Need Help for Skin Start Menu Classic Shell [Windows 10]'. Both images show a red interface with a highlighted blacked-out text box and a white-haired anime avatar.
I already try everything that I found on the net so I don't know what to do...
Can you please help me ?
That will be so kind !
Thanks you for all your patience and your time for reading !
Have a nice day !
Cordially,
DamyNox.
To hide or disable the popup description that shows your real name on the user picture and username in the Start Menu using Classic Shell, you would typically have to adjust settings within the program. Here's a general guide on how you might be able to achieve this:
  • Access Settings:
  • Open Classic Shell settings by right-clicking on the start button and selecting "Settings."
  • Look for options related to user information, names, or account details.
  • User Name Display Settings:
  • Explore the settings related to user information display in the Start Menu.
  • Look for options to toggle the visibility of the user name or any personal information.
  • Modify Display Preferences:
  • If there are specific settings...
  • Access Settings:
  • If there are specific settings related to user details visibility, adjust them to hide information you don't want to see.
  • Save Changes:
  • After making adjustments, save the settings and close the Classic Shell window to apply the changes. If Classic Shell doesn't have a specific setting to hide your username on the Start Menu, you might have limited options within the program itself. In such cases, you could consider the following alternatives:
  • Contact Support: Reach out to Classic Shell support to inquire if there is a way to hide the username info.
  • Search Forums: Look for forums or user groups specific to Classic Shell for additional insights and possible solutions.
  • Consider Alternatives: If Classic Shell doesn't provide the customization you need, you might explore other software or customization tools that offer more granular control over the Start Menu appearance. By being proactive in exploring Classic Shell settings and seeking assistance within the Classic Shell community, you stand a good chance of finding a solution to customize your Start Menu to better suit your preferences.
