Windows Vista need help with an internet explorer crash
U
Unregistered
Guest
i dont how it happened but everytime i right click an icon my internet explorer crashes. i thought i was because of what game i downloaded but when i got rid of it problem did fix. Can anybody help me? I have windows Vista home basic SP1
U
hey thanks for your help i had checked for a trojan and found one got rid of it but my problem was not solved so i downloaded and installed Spybot search and destroy ran the scan and found lots of problems and i had it fix it for me and now problem solved thanks guys for your help if yeah want google spybot its a really nice program once again thanks
"problem did fix" the did is supposed to be didn`t sorry about that
Have you checked for a virus or trojan? You can use "Hyjack This" Very good I'm told....Check this out Link Removed - Invalid URL
