Need help with random BSOD Ntoskrnl.exe
Hey Guys.... for the past couple days i've been experiencing some strange issues with my new laptop. to be clear, it's actually a mid 2010 Macbook Pro 15.4" that i bought to use exclusively as a PC laptop. long story short, i got fed up with low quality built PC laptops and wanted something that's higher physical quality and better built. and since i hate OSX, i decided to run bootcamp for windows 7. the new intel macs have come a long way, now it natively supports windows without emulation. anywho.
so far everything seems to work VERY well, and this thing blazes through in Win 7 environment. however in the past few days, i've had a couple BSOD in what seems to be Ntoskrnl.exe related BSOD. i read the FAQ section on this subforum on how to dissect the probable cause by going to the Event Viewer, as well as downloading the minidump debugger/viewer, which both confirmed to be related to Ntoskrnl.exe. but that's about all i know.
two strange issues, which might help finding the culprit of this problem. in my device manager, the built-in bluetooth adaptor device has shown a problem giving out error Code 43. as well as everytime Arcsoft total media theater launches, it causes the "system" process (also known as "NT Kernel & system" to rack up more CPU cycle than usual. (usual is 0~1%, racked up would be 6~8%). only way i can make this system process to go back down to normal is with a reboot of the system. so far i've decided to uninstall Arcsoft TMT and uninstall the driver for the bluetooth built-in adaptor and disabled the bluetooth adaptor itself. but unfortunately with my limited knowledge this is as far as i can go in regard to pin pointing down the issue.
can anyone take a look at my mini dump files and let me know exactly which program, or file is causing this BSOD? both BSOD occurred while putting the laptop to sleep, or waking it back up.
the macbook pro specs are: intel i5 520M (2.4ghz), 4GB ram, nvidia 330m graphics on 64bit Win7
much appreciated.
bump. (10 characters) :teeth:
Joe S
You should have the posted in BSOD I put in a post kink to here.
Joe
much appreciated.
X64_0x9F_4_nt!KiSwapContext caused by system kernel file.
Update drivers:
Broadcom NetXtreme Gigabit Ethernet
b57nd60a.sys Thu May 28 21:57:35 2009
Broadcom.com - Ethernet NIC Driver Downloads
Broadcom 802.11g Network Adapter - Dell Wireless 1390 WLAN Mini-Card
bcmwl664.sys Fri Aug 21 20:17:40 2009
Broadcom.com - Downloads & Support
IR Remote Driver - Boot Camp
IRFilter.sys Wed Jul 02 15:53:12 2008
inpoutx64.sys Fri Oct 17 19:01:16 2008
Apple - Support - Downloads
WinRing Driver - many different programs that center around the using of the WinRing libraries
WinRing0x64.sys Sat Jul 26 09:29:37 2008
If crashes persist, uninstall all Apple-related software and uninstall RTCore:
RTCore
RTCore64.sys Wed May 25 02:39:12 2005
Boot Camp 3.0, Mac OS X 10.6
AppleMNT.sys Fri Oct 15 02:37:17 2010
Apple Mac HAL
MacHALDriver.sys Sun Feb 21 20:51:34 2010
If crashes again, replace Avast with MSE:
Virus, Spyware & Malware Protection | Microsoft Security Essentials
CRASH DUMPS
Loading Dump File [F:\DMP\032911-23836-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02e66000 PsLoadedModuleList = 0xfffff800`030a3e50
Debug session time: Tue Mar 29 23:50:24.275 2011 (UTC - 4:00)
System Uptime: 0 days 23:39:15.500
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 1000009F, {4, 258, fffffa800452e680, fffff80000b9c510}
Probably caused by : ntkrnlmp.exe ( nt!KiSwapContext+7a )
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000004, The power transition timed out waiting to synchronize with the Pnp
	subsystem.
Arg2: 0000000000000258, Timeout in seconds.
Arg3: fffffa800452e680, The thread currently holding on to the Pnp lock.
Arg4: fffff80000b9c510
Debugging Details:
DRVPOWERSTATE_SUBCODE:  4
FAULTING_THREAD:  fffffa800452e680
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff80002edd992 to fffff80002edc5da
STACK_TEXT:
fffff880`031c4720 fffff800`02edd992 : fffffa80`0452e740 fffffa80`0452e680 00000000`00000000 fffff800`00000009 : nt!KiSwapContext+0x7a
fffff880`031c4860 fffff800`02ed9d4b : 00000000`00000003 fffff800`030da220 fffffa80`00000000 fffffa80`0452e830 : nt!KiCommitThreadWait+0x1d2
fffff880`031c48f0 fffff800`03142b58 : 00000000`00000003 fffff880`031c4bf8 00000000`00000001 00000000`00000000 : nt!KeWaitForMultipleObjects+0x271
fffff880`031c4ba0 fffff800`03351974 : 00000000`00000000 fffffa80`05ab32f0 fffff8a0`13f8d010 fffffa80`05ab32f0 : nt!PnpNotifyUserMode+0x158
fffff880`031c4c20 fffff800`0323ca1c : 00000000`00000000 fffffa80`05ab32f0 fffff8a0`13f8d010 00000000`00000001 : nt!PnpProcessTargetDeviceEvent+0x94
fffff880`031c4c50 fffff800`02ee3961 : fffff800`031414f0 fffff8a0`13f8d010 fffff800`0307b5f8 fffff800`0308ae80 : nt! ?? ::NNGAKEGL::`string'+0x58b2b
fffff880`031c4cb0 fffff800`031797c6 : c7f0001a`981d7321 fffffa80`0452e680 00000000`00000080 fffffa80`04515890 : nt!ExpWorkerThread+0x111
fffff880`031c4d40 fffff800`02eb4c26 : fffff880`02fe7180 fffffa80`0452e680 fffff880`02ff1fc0 1ec521f5`0310aaa0 : nt!PspSystemThreadStartup+0x5a
fffff880`031c4d80 00000000`00000000 : fffff880`031c5000 fffff880`031bf000 fffff880`031c3340 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  .thread 0xfffffa800452e680 ; kb
FOLLOWUP_IP:
nt!KiSwapContext+7a
fffff800`02edc5da 488d8c2400010000 lea     rcx,[rsp+100h]
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!KiSwapContext+7a
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4cc791bd
FAILURE_BUCKET_ID:  X64_0x9F_4_nt!KiSwapContext+7a
DRIVERS
fffff880`04591000 fffff880`045cf000   1394ohci 1394ohci.sys Fri Apr 02 23:36:00 2010 (4BB6B7A0)
fffff880`00f90000 fffff880`00fe7000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`029a1000 fffff880`029ab000   acpials  acpials.sys  Mon Jul 13 20:00:24 2009 (4A5BCA98)
fffff880`02c50000 fffff880`02cda000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0427f000 fffff880`04295000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00c4d000 fffff880`00c58000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`04231000 fffff880`04254000   AnyDVD   AnyDVD.sys   Wed Dec 01 14:06:20 2010 (4CF69CAC)
fffff880`013e8000 fffff880`013fb000   AppleHFS AppleHFS.sys Fri Oct 15 02:37:20 2010 (4CB7F6A0)
fffff880`00df7000 fffff880`00dfe000   AppleMNT AppleMNT.sys Fri Oct 15 02:37:17 2010 (4CB7F69D)
fffff880`04bb5000 fffff880`04bbf000   applemtm applemtm.sys Wed Sep 29 15:19:02 2010 (4CA39126)
fffff880`04ae3000 fffff880`04af4000   applemtp applemtp.sys Wed Sep 29 15:19:03 2010 (4CA39127)
fffff880`03f41000 fffff880`03f90000   ArcSec   ArcSec.sys   Mon Sep 20 20:38:32 2010 (4C97FE88)
fffff880`0291b000 fffff880`02924000   aswFsBlk aswFsBlk.SYS Wed Feb 23 09:54:56 2011 (4D651FC0)
fffff880`028e1000 fffff880`0291b000   aswMonFlt aswMonFlt.sys Wed Feb 23 09:55:04 2011 (4D651FC8)
fffff880`02cda000 fffff880`02ce4000   aswRdr   aswRdr.SYS   Wed Feb 23 09:55:11 2011 (4D651FCF)
fffff880`01800000 fffff880`01880000   aswSnx   aswSnx.SYS   Wed Feb 23 09:56:59 2011 (4D65203B)
fffff880`03ef6000 fffff880`03f41000   aswSP    aswSP.SYS    Wed Feb 23 09:57:02 2011 (4D65203E)
fffff880`0101e000 fffff880`0102e000   aswTdi   aswTdi.SYS   Wed Feb 23 09:55:51 2011 (4D651FF7)
fffff880`00c1a000 fffff880`00c23000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00c23000 fffff880`00c4d000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff960`00840000 fffff960`008a1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`040da000 fffff880`04128000   b57nd60a b57nd60a.sys Thu May 28 21:57:35 2009 (4A1F410F)
fffff880`00e5e000 fffff880`00e6a000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`042b6000 fffff880`04591000   bcmwl664 bcmwl664.sys Fri Aug 21 20:17:40 2009 (4A8F3924)
fffff880`01889000 fffff880`01890000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03ee5000 fffff880`03ef6000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`04754000 fffff880`04772000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00790000 fffff960`007b7000   cdd      cdd.dll      unavailable (00000000)
fffff880`01975000 fffff880`0199f000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00d20000 fffff880`00de0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`0190f000 fffff880`0193f000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cc2000 fffff880`00d20000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04254000 fffff880`04258500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`010fe000 fffff880`01171000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`00e55000 fffff880`00e5e000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`0426f000 fffff880`0427f000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`041f1000 fffff880`041ff000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04a5a000 fffff880`04a65000   CS420x64 CS420x64.sys Sun May 02 21:46:40 2010 (4BDE2B00)
fffff880`03e44000 fffff880`03ec7000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03ec7000 fffff880`03ee5000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02c0c000 fffff880`02c1b000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`018f9000 fffff880`0190f000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04b8d000 fffff880`04baf000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`03fcf000 fffff880`03fd8000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`03fc3000 fffff880`03fcf000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`03fd8000 fffff880`03feb000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`04a99000 fffff880`04aa5000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`10ac6000 fffff880`10bba000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`10bba000 fffff880`10c00000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`02c00000 fffff880`02c0c000   ElbyCDIO ElbyCDIO.sys Thu Dec 16 17:58:13 2010 (4D0A9985)
fffff880`01080000 fffff880`01094000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01034000 fffff880`01080000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01200000 fffff880`0120a000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`018bf000 fffff880`018f9000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0159f000 fffff880`015e9000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02e1d000 fffff800`02e66000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`0fe00000 fffff880`0fe24000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`04af4000 fffff880`04b50000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`04ac1000 fffff880`04ada000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`04ada000 fffff880`04ae2080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`04ab3000 fffff880`04ac1000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`04600000 fffff880`046c8000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`0120a000 fffff880`01213000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`06543000 fffff880`0654a000   inpoutx64 inpoutx64.sys Fri Oct 17 19:01:16 2008 (48F9193C)
fffff880`04259000 fffff880`0426f000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`041e5000 fffff880`041f1000   IRFilter IRFilter.sys Wed Jul 02 15:53:12 2008 (486BDCA8)
fffff880`0416e000 fffff880`0417d000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04bed000 fffff880`04bfb000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bae000 fffff800`00bb8000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`0654a000 fffff880`06552000   KeyAgent KeyAgent.sys Tue Sep 14 23:37:02 2010 (4C903F5E)
fffff880`04aa5000 fffff880`04ab3000   KeyMagic KeyMagic.sys Thu Mar 25 12:22:55 2010 (4BAB8DDF)
fffff880`04000000 fffff880`04043000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013bd000 fffff880`013d7000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01574000 fffff880`0159f000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`04baf000 fffff880`04bb4200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`029dc000 fffff880`029f1000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`028be000 fffff880`028e1000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`06552000 fffff880`0655c000   MacHALDriver MacHALDriver.sys Sun Feb 21 20:51:34 2010 (4B81E326)
fffff880`00c6a000 fffff880`00cae000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`06a09000 fffff880`06a17000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0417d000 fffff880`0418c000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04055000 fffff880`04062000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00c00000 fffff880`00c1a000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`04772000 fffff880`0478a000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`0478a000 fffff880`047b7000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`064d2000 fffff880`06520000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`06520000 fffff880`06543000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`019ef000 fffff880`019fa000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00ff0000 fffff880`00ffa000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010a0000 fffff880`010fe000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02df3000 fffff880`02dfe000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01408000 fffff880`0141a000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01422000 fffff880`01514000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`045f3000 fffff880`045ff000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`04729000 fffff880`0473c000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`04200000 fffff880`0422f000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04a65000 fffff880`04a7a000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02d58000 fffff880`02d67000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02ce4000 fffff880`02d29000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01514000 fffff880`01574000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`0189e000 fffff880`018af000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02de7000 fffff880`02df3000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02e66000 fffff800`03443000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`0121a000 fffff880`013bd000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01880000 fffff880`01889000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`10ac4000 fffff880`10ac5180   nvBridge nvBridge.kmd Mon Feb 14 05:48:54 2011 (4D590896)
fffff880`0fe29000 fffff880`10ac3d80   nvlddmkm nvlddmkm.sys Mon Feb 14 05:55:25 2011 (4D590A1D)
fffff880`046d6000 fffff880`04729000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02d32000 fffff880`02d58000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00e40000 fffff880`00e55000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00de0000 fffff880`00de7000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00de7000 fffff880`00df7000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`013d7000 fffff880`013e8000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`06400000 fffff880`064a6000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`04b50000 fffff880`04b8d000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cae000 fffff880`00cc2000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`01094000 fffff880`0109fe00   PxHlpa64 PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)
fffff880`045cf000 fffff880`045f3000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04295000 fffff880`042b0000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04128000 fffff880`04149000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04149000 fffff880`04163000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02d96000 fffff880`02de7000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`04163000 fffff880`0416e000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`019d4000 fffff880`019dd000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019dd000 fffff880`019e6000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019e6000 fffff880`019ef000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`011bd000 fffff880`011f7000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`0473c000 fffff880`04754000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06b45000 fffff880`06b4b000   RTCore64 RTCore64.sys Wed May 25 02:39:12 2005 (42941D90)
fffff880`0419b000 fffff880`041ca000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`064a6000 fffff880`064b1000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`01400000 fffff880`01408000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`06aaf000 fffff880`06b45000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`06a48000 fffff880`06aaf000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`0655c000 fffff880`06589000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`042b0000 fffff880`042b1480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01603000 fffff880`01800000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`064b1000 fffff880`064c3000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`018af000 fffff880`018bc000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`01000000 fffff880`0101e000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02d82000 fffff880`02d96000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00520000 fffff960`0052a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03f90000 fffff880`03fb6000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`06b52000 fffff880`06ba6000   udfs     udfs.sys     Mon Jul 13 19:23:37 2009 (4A5BC1F9)
fffff880`04043000 fffff880`04055000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`04a7a000 fffff880`04a97000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`04a97000 fffff880`04a98f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`040c9000 fffff880`040da000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04a00000 fffff880`04a5a000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04073000 fffff880`040c9000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`041ca000 fffff880`041e5000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`04bbf000 fffff880`04bec200   usbvideo usbvideo.sys Wed Mar 03 23:40:57 2010 (4B8F39D9)
fffff880`0418c000 fffff880`0419b000   VClone   VClone.sys   Sat Jan 15 11:21:04 2011 (4D31C970)
fffff880`00e33000 fffff880`00e40000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01890000 fffff880`0189e000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`0199f000 fffff880`019c4000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`015e9000 fffff880`015f9000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00e6a000 fffff880`00e7f000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e7f000 fffff880`00edb000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01171000 fffff880`011bd000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02d67000 fffff880`02d82000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`019c4000 fffff880`019d4000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00edd000 fffff880`00f81000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f81000 fffff880`00f90000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d29000 fffff880`02d32000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00050000 fffff960`00360000   win32k   win32k.sys   unavailable (00000000)
fffff880`06b4b000 fffff880`06b52000   WinRing0x64 WinRing0x64.sys Sat Jul 26 09:29:37 2008 (488B26C1)
fffff880`00fe7000 fffff880`00ff0000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`02924000 fffff880`02945000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`029ab000 fffff880`029dc000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`06bda000 fffff880`06be8000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`06a00000 fffff880`06a09000   cpuz135_x64.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`06589000 fffff880`065fa000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  00071000
fffff880`02800000 fffff880`0288c000   bthport.sys
    Checksum:  00000000
    ImageSize:  0008C000
fffff880`06be8000 fffff880`06c00000   BTHUSB.sys
    Checksum:  00000000
    ImageSize:  00018000
fffff880`06bca000 fffff880`06bd6000   AppleBtBc.sy
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  0008C000
fffff880`06bb2000 fffff880`06bca000   BTHUSB.sys
    Checksum:  00000000
    ImageSize:  00018000
fffff880`06ba6000 fffff880`06bb2000   AppleBtBc.sy
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00071000
fffff880`06be8000 fffff880`06bf1000   cpuz135_x64.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`06bcc000 fffff880`06bda000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`06bed000 fffff880`06bfb000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`06bc3000 fffff880`06bcc000   cpuz135_x64.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`06b52000 fffff880`06bc3000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`06bdf000 fffff880`06bed000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`02832000 fffff880`028be000   bthport.sys
    Checksum:  00000000
    ImageSize:  0008C000
fffff880`03e00000 fffff880`03e18000   BTHUSB.sys
    Checksum:  00000000
    ImageSize:  00018000
fffff880`03feb000 fffff880`03ff7000   AppleBtBc.sy
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`02971000 fffff880`02981000   BthEnum.sys
    Checksum:  00000000
    ImageSize:  00010000
fffff880`02945000 fffff880`02971000   rfcomm.sys
    Checksum:  00000000
    ImageSize:  0002C000
fffff880`02981000 fffff880`029a1000   bthpan.sys
    Checksum:  00000000
    ImageSize:  00020000
fffff880`06b60000 fffff880`06b6e000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`06b6e000 fffff880`06bdf000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`06b52000 fffff880`06b60000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  00071000
fffff880`04062000 fffff880`04070000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0193f000 fffff880`0194d000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0194d000 fffff880`01959000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01959000 fffff880`01962000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01962000 fffff880`01975000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`03fb6000 fffff880`03fc3000   usbuhci.sys
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`045cf000 fffff880`045d9000   acpials.sys
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`04200000 fffff880`04231000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
Thank you so much Sr.... i'll give that a try. :)
Joe S
#7
i am sorry, you lost me :(
If you looked through forum topics there is a section for BSOD and it will get noticed sooner.
Joe
#8
The thread is already there, thank you very much Joe. : )
