Windows 7 Need to Print from Laptop to Desktop Printer via WiFi
wilhelm1
Well-Known Member
Both machines are Win7 and both are on the same network. How can I print from the Lap to the Desk printer? At one time, I believe I was able to do this. .
You need to get the install utility for your printer install it on the lap top. When you get the proper setup utility it should ask you if the printer is local or on the network. The utility should them search your network for the printer and do the setup for you.
I have a Canon at home and HP laser and Lexmark laser at church and they were able to install via the utility to all the PCs wired and wireless.
Well, at least I was happy for a day. Went to print from my laptop to my printer and it would not work. I am done with this
problem, will be moving on to others. Thanks all.
